Compressor is not activated techniques and pointers in in repair
    Scholar:
  • 121 Answers
To check the compressor remove the wire cover and wires from compressor. Mark or remember which wire goes where. Ohm out between run and start, run and common, you should have a reading across all terminals if not compressor is bad. Although you could still have a winding that is touching one another
Posted on Sep 27, 2008
What FN combo key to activate / deactivate computer pointer?
Should be a icon on your keyboard that shows a mouse or touch pad icon - Just use your FN (Function key) and that icon to activate and to deactivate the pointer or touch pad.
Hope this information helps ya.
Nerd Tech-Junkie Will
Dec 04, 2016 | Computers & Internet
How do I copy part only of an email to send to someone else?
put mouse pointer at start of amusing article and then hold left mouse button down and drag mouse pointer to end of amusing article. Then press CTRL - C if windows. Compose a new email click in big white message area and press CTRL - V if windows.
on apple pc it most likely is apple key and C you may find copy and paste under the edit option menu.
you might be able to click on Forward and delete the information you do not want seen using the drag technique and pressing del key.
Feb 25, 2015 | Computers & Internet
A/c not blowing air
Possibly a leak in the AC system. When refrigerant pressure drops a switch shuts down the AC system completely to prevent damage to the compressor.
Check cold / heat on incoming / outgoing pipe of the compressor. If temperature on both sides is the same the clutch of the compressor isn't activated.
Check with your local repair workshop for leaking AC pipes / coupling
Jun 26, 2011 | 1992 Nissan Pathfinder
No keyboard no touchscreen,no mouse
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines.
dust causes static which causes lots of problems with a computer and its parts or
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
or if this does not fix the problem
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which willscan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Jan 21, 2011 | Panasonic Computers & Internet
The cluch doesn't work. The gear pointer doesn't
Do you have a model number? Front tine or rear tine? I will try to help you.
May 29, 2010 | Mtd Products Yard Machines 158CC Tiller
Motor will not turn on, just buzzes
Thanks for the pointer concerning using a little force on the cooling fan spindle. I actually had to add some fresh oil and take the fan off and use a wrench to rotate the spindle a few times. Once I plugged it in, it worked like a champ! greggloaj
Jan 12, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
The close door message stays on my Gagia Titanium coffee machine even when the door is closed. I have tried reloading the factory settings but even this does not help
HI
There are 2 things that give the close door message. On the back side of the door towards the hinge, there is a pointer that activates a switch. If that pointer is broken, it won't touch the switch. Replace the door or modify the pointer to touch the switch. If the pointer is not broken, there is an adjustment inside the machine on the steam manifold mount that has 2 screws that can be loosened to move the mount forward (bringing the switch forward) so the pointer can touch the switch.
Jun 30, 2009 | Gaggia Titanium Espresso Machine
When i turn on my camper ac, the fan will come on but nothing else.... the compresser does not come on. could it be the starting capacitor? do you sell parts? if so how much does a starting capacitor cost?
Most of these little compressors don't have a start cap on them. The motors in these little hermetics don't need them. You need to check that athe compressor is getting voltage to it. Check to see if rodents haven't tried to get on top and chew wires. Squirrels can and do cause lots of damage. If the compressor is being "told" to come on, and it doesn't, the compressor is bad. Parts are hard to come by on these little units. You will probably have to contact the manufacturer for a location neer you that sells parts.
Mar 30, 2009 | Heating & Cooling
Keyspan remote control (mouse) Model TSAM - 004
Press and hold the two buttons (small pink and clear pie shaped) for 4 seconds. the lower button will flash red once every three seconds to show laser pointer enabled. Laser pointer turns itself off after 10 minutes on non-use.
Jan 13, 2009 | Keyspan Presentation Remote Control
How to adjust touchpad and pointer settings on satellite l30 10y. at present the pointer activates commands when not wanted
Go to Control Panel, then select Mouse/Touch pad Icon. You will see there the MOUSE POINTER OPTION. Just adjust your desired settings for the mouse and pointer settings.
Nov 30, 2008 | Toshiba Computers & Internet
Heating & Cooling Logo
128 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
