Question about Linksys Wireless-G Broadband Router
I am unable to get ip address for wireless g adapter? what do i do
I cant seem to get the adapter to work, it just opens the internet but will not allow me to check mail or connect to other sites
  • Anonymous Sep 26, 2008
    i am unable to get an ip address for Dvr security recorder its a 9 ch an i would like it to work with my internet what do i do
    Problem Solver:
  • 18 Answers
I have the exact same router. Go to and make sure you have the latest firmware for your model . After that I used the setup adviser and it did everything for me no problems. If you have done this already open your router settings by typing in your ip in your browser (if you do not know what your ip is, then hit start and run type in "cmd" and then press enter when the command prompt box opens type "ipconfig" there is all info about your connection) make sure you do not have any sites listed in the restricted sections. There is a tab to check your connections and settings also. Also make sure your windows firewall is not conflicting with any of your settings.
Posted on Sep 27, 2008
Aspire 5470 can connect to wireless network but cannot open pages in the internet explorer
May be you need to provide IP address to your Wireless Adapter or may be there is already some other group IP address.
Disable your wireless adapter and enable it once and see what haooens
Aug 14, 2012 | Acer Aspire AS5742-6413 Notebook Intel...
Recent got the wireless usb adapter for my Dell Desktop. I have run the software and the device is detecting the internet but it keeps telling me there is a problem because it is unable to renew the ip...
First, make sure that that wireless card is configured to obtain an IP address automatically, unless you are at work and they give you a static IP address. You can check the configuration by going to the properties page of the wireless adapter. You get to this page through Control Panel > Network and Internet(or something similar depending on version of windows) Right click on the wireless connection and go to properties. Right click on TCP IPV 4 and the settings should be set to auto obtain ip address.
If you are using a static IP address, then you have to manually type in the ip address in the window above.
Try the following to renew the IP address.
Turn off the cable modem, the router and your computer. After 10 seconds, plug in the cable modem, after 20 seconds, plug in the router, after 20 seconds, turn on your computer and see if this helps.
Another option to renew the ip address is the following,
Go to Start > Run and type "command" or "cmd"
Then type "ipconfig /release" once this is done type "ipconfig /renew"
If this helps thumbs up my solution!
May 04, 2011 | NetGear WNA1100 WirelessN 150 USB Adapter...
I cant connect my dell laptop nor detect D-Link dlink Wireless N 150 Router through wifi but my mobile devices can and my desktops can also. please help me able to connect in the internet using wireless...
Try assigning your laptop a static IP. To do this in Windows:
  • Open Windows Start menu.
  • Open Control Panel.
  • Classic view: Open Network Connections
    Category view: Select Network and Internet Connections, and thenNetwork Connections.
  • Double-click on your active LAN or Internet connection.
  • Click Properties
  • In the General tab, highlight the Internet Protocol (TCP/IP) item, and clickProperties.
  • In the General tab, click Use the following IP address, and enter: - IP address. The static IP address you want to assign to this computer (try to start). - Subnet mask. Subnet mask used by your router (try to start). - Default gateway. IP address of your router's default gateway (try to start).
  • In Use the following DNS server addresses, enter all the IP addressses for the DNS servers your router uses (or you can try your router's address, probably
  • Click OK.
Please leave feedback for this answer, thanks.
Mar 10, 2011 | D-Link dlinkgo Wireless N 150 Router...
I am unable to connect to the internet using a wireless connection (signal strength good) When I use the repair wizzard I get a message telling me unable to renew IO address
If the Wi-Fi access point is a DHCP enable router, you should be able to browse the internet as DNS address will be automatically fixed in the Router firmware.
to check what IP address is assigned and more information on your wireless adapter
go to Command prompt by typing "cmd" in RUN.
type "ipconfig /all" without the quote.
you should be able to see IP address of your wireless network adapter plus default gateway and DNS address which are much needed in order to have internet access.
you can still assigned IP address etc manually.
Go to "Control panel"
Click on "Network and Sharing Center"
Click on "Change Adapter setting"
Now, right click on the wireless adapter and select "Properties"
Select "Internet Protocol version 4 (TCP/IPv4)" and "Properties"
In General tabs,select the radio button with " use the following IP address"
IP address : 192.168.1.x    (if the router IP address is 192.168.1.y)
                                        x=1 to 254, y=1 to 254 but x should not be                                           equal to y )
Subnet Mask :
Default gateway : 192.168.1.y ( IP address of the Wireless access point)
Preferred DNS address : Ask the Internet service provider
Alternate DNS address : Ask the Internet service provider
Click "OK" twice.
Your Internet should work now.
Jan 26, 2010 | Fujitsu Siemens LifeBook N3520 Notebook
Abit wireless adapter unable to locate wireless network
well!! I have an answer for you.your comp is loosing the IP address.connect your computer through cable then goto start - programmes - accessories - dos prompt. type`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default DNS server address type the default gateway in primary DNS and in secondary your connection won`t drop after this.
Jun 26, 2009 | Abit (WLP-01) Wireless Adapter
try to check the ip address before accessing the internet.
if you not getting a valid ip address then try to reset you d link router.
Apr 13, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Wireless connection, but no internet
Verified that the Internet connection is working good
- Now if your connected to the wireless network but unable to access a website try this:
- Open the control panel
- Open the network connection
- Right click on wireless networks (Choose properties)
- Choose Internet protocol then click properties
- Assign DNS Server address (Preferred DNS:, Alternate DNS:
- Leave the DCHP as obtain IP address
Mar 04, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Replaced Linksys Wireless-B 2.4GHz 807.11b Router and Wireless B 2.4GHz 802.11b Wireless-B Notebook Adapter with Linksys-N Ultra Range Plus Wireless-N Gigabit Router, and Wireless N Ultra Range plus Dual...
Try resetting your IP address:
The laptop may be trying to use the IP address from the old router.
1) Click Start (assuming Windows 2000, XP, or Vista)
2) Click Run
3) Type in CMD
This will take you to a black command box
4) Type in: ipconfig/release
The chart should show your IP address as
Once this has happened, proceed to step 5
5) Type in: ipconfig/renew
You should now see a new IP address listed.
Also note that you need to set up your network key (assuming that you are using one) on both the router and laptop.
Make sure that your router is set up to perform as DHCP server.
Apr 30, 2008 | Computers & Internet
Unable to open internet page
let you router allocate the ip addresses manually by enabling DHCP and restart the router,and remove the usb adapter from the usb port and reconnect it, but when you right click on the taskbar on the little pc icons for your connection click enable WZC windows wireless Zero configuration as this will dissable the software you got with the usb adapter and hopefully make the connection more stable, but ensure you have a strong signal.
Jun 01, 2007 | U.S. Robotics MAXg USR5421 802.11g/b...
Linksys Wireless-G Broadband Router Logo
29 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
