Question about Garmin Nuvi 360 Bilingual GPS Navigator and Personal Travel Assistant GPS Receiver
Instructions on replacing nuvi speaker
Hi
YOu mentioned that you would post instructions on how to replace the speaker. That was back in march I think. I just noticed that the new software I added to my nuvi 360 included something to "prevent speaker blowout". Darn... Too late.
Anyway, my speaker is certainly damaged and I need to find a replacement and figure out how to open the case.
My email is mccall.jim@gmail.com thanks Jim
  • 3 more comments
  • elasticmedia Sep 26, 2008
    To clarify, I would appreciate knowing how to open up the case, perhaps with a kitchen knife or putty knife? Any disassembly hints would be appreciated. Particularly, I am interested in a source to purchase a replacement speaker.
    It sounds like the speaker is mounted with adhesive - was this hard to remove.
    finally, there were contradictory comments on testing the speaker: Jim mentioned 1500 K ohms for his speaker (but thought his was good) and Jim measured 7.8 ohms for his speaker (which he doesn't say but it is implied that the speaker is good). I would have thought that the speaker should be around 8 ohms.
    thanks
    JIM
    OK Jim - this info is great. Where can I get a replacement speaker, what size torx is it, and is it a generic case separator or specific (where to get the separator?
    I gather that you didn't have to much difficulty in disassembling the device without damaging the cables - I assume that careful work will prevail?
    thanks
    Jim
  • kushal mehta Dec 02, 2008
    Where can I find a case separator?
  • SHARCNET-USA
    SHARCNET-USA May 11, 2010
    The original poster "Bruce" said his was 1500 ohms. I (Jim), said that was too high and actually measured a working one which showed 7.8 ohms, which was probably some tolerance reading. The speaker for all practical purposes is 8 ohms.
    There are specific tools to open the Nuvi (torx screwdriver & case separator). Using anything else could damage your Nuvi. The case separator tool prevents the case from being dented using any other tool that is harder than the plastic case.
    There are (3) internal flex cables, (1) for the touch screen, (1) for the LCD display and (1) for the antenna. These can be damaged if your not careful. I've had several emails from people who have damaged these cables trying to get their Nuvi apart.
    In the 360, there is an additional set of wires for the bluetooth condenser microphone. If you don't plug it back in the same way as you unplugged it, your mic won't work.
    I have sucessfully second sourced a replacement speaker for the Nuvi and have verified that it works.
    The original speaker was not hard to remove. However, the new speaker does not have wires. You will have to unsolder the wires & plug from your original speaker and solder them to the new one.
    - Jim
  • SHARCNET-USA
  • Garmin Master
  • 2,130 Answers
I have given you the proper information as requested. Good luck!
Posted on Sep 26, 2008
Hi just up dated my garmin nuvi but now cant locat satellites pleaSE help
I can help you reset and fix your Garmin Nuvi 265W.
A new webupdater was released at the end of March, so you might want to check below that you used that version. I also recommend backup up your favorites and performing a hard reset after the update. Detailed instructions for both are below.
There are three steps to take to get your Nuvi 265W running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_____________________________
Nuvi 265W Manuals here.
Mar 30, 2010 | Garmin Nuvi 265W GPS Receiver
Garmin Nuvi 200 - continually updates firmware
I can help you fix your Garmin Nuvi 200W. You will find the newest version WebUpdater if you follow my links, released March 31, 2010. I think you will find between a Hard Reset and the new software, your Nuvi will be better than new again.
There are three steps to take to get your Nuvi running like new:
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Mar 22, 2010 | Garmin nuvi 200W GPS Receiver
My nuvi 200w turns on with an error message that says " No detailed maps found that support routing. The Nuvi cannot be used without them. " Please advise on a fix. I have downloaded the most current...
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
There was a WebUpdate release on March 31, 2010, so even if you have downloaded it before, I recommend you do it again.
I hope that helps.
___________________
Feb 16, 2010 | Garmin nuvi 200W GPS Receiver
Downloaded and installed Bluetooth firmware update - Won't Pair
I recommend rerunning the webupdate software available below, which was updated March 30, 2010. Run through the update steps again.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
After successful webupdating, a hard reset is often helpful at this time, too.
I hope that helps.
Nuvi 265WT Manuals here.
Sep 09, 2009 | Garmin nuvi 265 Car GPS Receiver
Driver's side visor on 2006
Check this out. Your vehicle may be covered at no charge to you.
2006-2007MY SONATA SUN VISOR
REPLACEMENT (SERVICE CAMPAIGN T64)
CAMPAIGN APPLIES TO VEHICLES LOCATED IN THE WESTERN, PC, AND SOUTHERN REGIONS ONLY. THIS WOULD INCLUDE
THE STATES AL, AR, AZ, CA, CO, FL, GA, HI, KS, LA, MS, NC, NM, NV, OK, OR, SC, TN, TX UT, AND WA.
VEHICLES AFFECTED:
Model: 2006-2007MY Sonata (NF)
Applicable vehicle production date range:
• NFA: Produced from March 31, 2005 to March 31, 2007 (Alabama built - HMMA)
• NF: Produced from March 21, 2005 to December 23, 2005 (Korea built - HMC)
Applicable VIN range:
• NFA: Produced from Job#1 to 5NPET46C47H297390
• NF: Produced from KMHET46C06A062020 to KMHET46C86A185600
SERVICE PROCEDURE:
NOTE: Before conducting procedure, confirm vehicle is within the affected VIN
range.
Jun 06, 2009 | 2000 Hyundai Sonata
Nuvi 310 faulty internal speaker
Give the salesman some good oral sex.
Hope this helps!
Sep 30, 2008 | Garmin Nuvi 610 GPS Receiver
Nuvi 660 Speaker
Hi Dave,
Please read the article I wrote on this problem. You should now have the info I gave you to find a replacement speaker. I would appreciate you voting on my solution for you.
Thanks,
- Jim
Sep 27, 2008 | Garmin Nuvi 660 GPS Receiver
Adapter for AC is broken
Your post title says the adapter for "AC" is broken but your description mentions the cigarette adapter. The cigaretter adapter is DC. An AC adapter plugs into the wall outlet in your home.
If you are looking for a replacement car adapter, try Ebay:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=150279323123
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=310072797582
Jul 31, 2008 | Garmin nuvi 350 GPS Receiver
Audio gone from my gps garmin nuvi 660
If you can hear audio through the headphone jack but not the internal speaker jack, then the speaker is bad.
This is a problem I have seen many times before. I will be posting an article soon on how to replace the internal speaker, however this is not a repair that just anyone can do.
You have to have skills in dissassembly & soldering.
- Jim
Jun 09, 2008 | Garmin Nuvi 660 GPS Receiver
Nuvi 350 blown speaker
When you tap the GPS it is probably doing one of two things:
1. The tapping is temporarily reconnecting the broken voice coil in the speaker (speaker will need to be replaced)
2. The tapping is temporarily reconnecting a bad solder joint from the GPS motherboard to the speaker. (The solder joint will need to be resoldered)
You can either send the unit back for repair or purchase a FM modulator and retrieve the audio through your FM car stereo.
You can purchase an external FM modulator like those used on IPODS and CD players. I am using one on my Nuvi 350 and it works well. Just plug it into the headphone jack. Advice: Be sure to buy one that is crystal (PLL) controlled and NOT using a tuning dial. The FM modulators that use a tuning dial often tend to drift and they will also change frequency when you hit a bump in the road.
If you decide to send it back for repair, be sure to have your serial number handy. Register it online https://my.garmin.com/mygarmin/marketing/register.htm
if you haven't already done so.
Hours:
Monday - Friday
8 a.m. - 7 p.m.
Central time (closed holidays)
1-800-800-1020 (U.S.)
1-866-429-9296 (Canada) or (913) 397-8200
Good Luck,
- Jim
Nov 25, 2007 | Garmin nuvi 350 GPS Receiver
GPS Logo
2,645 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
