Ok, please elaborate your situation what dvd model do u have u can check this my going to my computer right clicking on your dvd drive and then properties and going to the harware tab and it will tell u
on away to fix this would be to go to my comp then right clik on an empty space and hit properties then the hardware tab then then device manager
then click ont he plus sign on ide ata controlers then right click primary ide controllerss and go to properties and then go to advanced settings then look down and make sure it says DMA if available on transfers then hit ok after c cahnging it to dma
and then go on seconadary ide channel properties advance setings and also make sure that it syas dma if available and not POI if it says POI thts a problem just change it and ur speed will improove dramatically
another solution
make sure that ur hard drive isnt connected to the same ribbon cable (IdDE cable) as the dvd rom
u can check this by oening up ur pc and if they share a cable put the dvd drive as secondary master and the hard drive master
