Question about Toshiba Portege M200 Notebook
Mouse movement when not touching the mouse
It seams that a lot of laptops have this problem but my mouse move to the top left hand corner of my screen and it wobbles sometimes in one spot.
I was wonder any chance of any advice of how to repair it without spending a lot of money it is do it now....Please help as this makes typing rather annoying and surfing the web any sugestions
  • 68 Answers
is this an external mouse or a mouse pad/nipple in the laptop.
If the former have you tryed using a different mouse? I have had similar problems with optical mice in the past.
Posted on Sep 27, 2008
Mouse arrow shows but won't move with touch pad or button
Hi Wayne ,
If it fell off the edge of your bed last night it is likely that you have damaged the mouse track pad in some way.
you might have to order a new one off of ebay and have someone fit it for you !!
Or it might be as simple as the ribbon cable in the track pad has come loose and will need to be refitted.
can you see the movement of the track pad in the right hand bottom corner of the screen when you move the mouse with the track pad and by using an external USB mouse to get to the desktop?
Dec 29, 2012 | Dell Latitude D810 PC Notebook
How do I disabled the touch pad and only use an external mouse and the keyboard on the lap top?
You do not have to actually disable the touch pad on this laptop to use an "external" mouse. Just plug in your mouse and it will install the drivers if needed and viola, your good to go. If you insist on disabling your touch pad however, you can do that by double tapping the top left hand corner, when you do this correctly, a little orange light will show and the screen will show a notification the the touch pad is disabled. To enable the pad back on, just repeat the same step you used to disable, and the on screen notification will indicate the touch pad is enabled!
Aug 04, 2011 | Compaq Presario CQ56-115DX Laptop
Curser stuck in upper left hand corner
If you want to use a mouse with your laptop, find the preference that ignores the trackpad when the mouse is present. Go to System Preferences in the Apple menu (upper left corner of screen). Click Keyboard and Mouse" or Trackpad (depending on what you see). Un-check the option that says something like "Ignore the trackpad when the mouse is present."
(I don't see it in anymore 10.6, which won't run on your PowerBook anyway.)
Apr 08, 2010 | Apple PowerBook G4 17" 1.33GHz Mac...
HP TX1000 Tablet The cursor on my screen keeps going to the bottom left hand corner and stays there. The problem remains even when I used a USB mouse. Anyone knows what the cause?
click start button in lower left hand corner, then a pop out menu will come up, click control panel, then find mouse, click it, then go to pointer options and click it, see if theres a box checked that says something like (automatically move pointer to the default button in a dialog box). uncheck that box......hope this helps you.......
Jan 06, 2010 | HP Pavilion TX1000Z 12.1" Touch Screen...
The cursor moves randomly while I use the trackball
this problem is caused by a defective mouse, replace it.
Sep 09, 2009 | Logitech Marble Mouse Trackball
After trying to change the resolution on my monitor to maximum screen resolution it has just gone blank. the start up menu works ok but then when desk top and start menus should come on the screen is...
Move the mouse so it is way, way down in the lower right corner. Place a penny or dime on the mousepad touching the upper left corner of the mouse. Pull the mouse diagonally down to the right a distance equal to the diameter of the coin. Then back up to the coin.
Right Click
Take your hand off the mouse because the rest is on the keyboard.
up <arrow>
hold <Shift> press <Tab>
right <Arrow> 10 times.
left <arrow> (decreases resolution, right arrow to increase)
By the by if you can find a monitor that will accept the resolution you selected on the 'Properties' window you can switch it back the normal way
Aug 04, 2009 | HP Pavilion F1523 15" LCD Monitor
Mouse pad
you would be better off using an optical mouse that has a usb or ps2 connector ( depending on what your laptop supports ) usb would be better though less chance of pins bending as there are none on a usb connection ( at least not like a ps2 connector )
Also download the latest drivers for the touchpad and make sure that the scrolling options for or on the touchpad are not configured too thickly which will be in the touch pad settings.
Apr 15, 2009 | Dell Inspiron 8200 Notebook
My mouse pointer is unstable. it automatically parks itself at the start button or parks itself at the top right hand corner of the screen & can't be seen in either position without a lot of sweeping...
Nov 29, 2008 | Computers & Internet
Moving cursor.
well there is a few things that could possibly be happening. if it is a touch pad or a wireless mouse something like a cell phone sitting close enough to them could be causing some interference. the second one is that you could possibly have the mouse keys turned on where you can control the mouse with the keyboard.
Apr 29, 2008 | Dell Latitude D800 Notebook
Mouse cursor moving by itself
i have latitude c610 and same problem happens with me too. i think that happens when i finish my brakfat and without cleaning my hands start using the touch pad. what happens according to me is that small particles of food(eg bread/dust particles) stuck in the corners or the body wall where the touch pad ends and keeps pressing the touchpad, thus causing the mouse to move to one direction. when i clean the corners and sides of the touchpad, it starts working ok !!
Dec 12, 2007 | Dell Latitude C610 Notebook
Toshiba Portege M200 Notebook Logo
81 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
