Looking for a diagram for a hp laserjet 4000n
  • 4,338 Answers
HP 4000n spitting out extra toner. Replaced cartridge and still having the same issue. Any suggestions?
The laser printer actually has a collection area for excess toner located under the toner cartridge. When that is full you will get extra toner coming out and streaking your paper. Take the collection chamber out and clean that out or replace it and you should be good.
Oct 10, 2012 | HP LaserJet 4000n Printer
How do i fix my hp laserjet 4000n error code 53.11.03
Dear Percy
Thanks for posting. Try the below steps to solve your printer problem
1. Turn the printer off, and reseat or replace the specified DIMM.
2. Try the DIMM in another slot.
3. Replace the DIMM that caused the error.
regards
Saleem
May 17, 2012 | HP LaserJet 4000n Printer
I have a HP 4000n printer and want it to print from tray 3 when tray 2 is empty. It doesn't do that now.
I don't have a 4000n, but I do have a 4200n that should be relatively similar. On the 4200n you can change this behavior by going to the menu, then Configure Device->System Setup->Tray Behavior->Use Requested Tray, then setting that value to First. My guess is you have that setting on your 4000n set to Exclusively, which will then prevent the job from going to a different tray. It also requires that you have the same type and size of paper registered in both trays if you want the job to automatically switch over.
If that menu path is different on your 4000n you just need to dig around in that menu to find the tray behavior setting.
Jun 09, 2011 | HP LaserJet 4000n Printer
How to change from tray 1 printing to main tray 2 on hp 4000 printer
On the printer drivers, if you go to the settings, you can change the default. It should be under a setting called paper.
thanks adi
Feb 23, 2010 | HP LaserJet 4000n Printer
I have a Hp Laserjet 4000n printer. Whenever i try to print the paper is printed but it does not come out and is jammed under the catridge and it displays error 13.5 all the time. can someone please help...
It sounds like the fuser roller is not turning.
Remove two small caps, unscrew the fuser fuser and remove it.
Rough up the red roller with Scotch Brite
Oil the black bearings on the top roller.
Jul 11, 2009 | HP LaserJet 4000n Printer
Printing problem
The printer itself is printing, but when I stalled Laserjet 4000 and try to print it shows ERROR even printing test page. I do not know why my HP laptop Vista cann't recognize the printer!
Thanks,
Iyaad09
Nov 23, 2008 | HP LaserJet 4000n Printer
Can't get it to print
plese select its paper size and also check the paper sensor
Sep 19, 2007 | HP LaserJet 4000n Printer
169 people viewed this question
jasbo
jasbo
