Question about Car Audio & Video
D3000/1 precisionpower amp mono
Burned 2 circurt on the power cable side on the top and on the board the number is d310 and the right next to it, if i can get the 2 circurt serial # i can replace it myself
    Sergeant:
    Champion:
  • 341 Answers
Caution: even if you have the part to replace it be sure that you know what you're doing. Check for dc voltage at the output line before even connecting/soldering the power transistors. You might fry it again if you don't. hope this helps.
Posted on Oct 17, 2008
I got a ppi d1000/1 amp cant get any sound out of it?
Make sure your remote wire is hooked up in the right spot, also check your rca plugs and consider replacing them, check all fuses to make sure their not blown, a loose or not good ground wire or power supply wire will also cause this problem. If a power wire has a cut in it, that will also cause fuses to blow, as well as with a ground wire cut, ur amp will not be properly grounded.
Sep 26, 2010 | PPI PrecisionPower D1000/1 Subwoofer Mono...
We are having problems with a Behringer PMP5000 board. We have the switch setting on Mon1/Mono. We can get sound out of the monitor output, but the mono output is almost silent. Do you have suggestions...
It is NOT clear what configuration you have set up and what you consider the MONO output is, whether it is the power amp MONO side output or the line level MONO 1/4 inch jack on the top of the unit (this jack is NOT speaker output). If you can run normal stereo speakers using both sides of the power amp in the AB mode, the problems you are having is pilot error.
REMEMBER the main out 1/4 inch jacks are BALANCED TRS jacks... DO NOT put mono plugs into these.
A WARNING: If you use Speakon to 1/4 inch speaker cables, remember that the BARREL of side A is HOT, not the tip!!! You can fry the amp if you inadvertently ground that barrel someplace. (Side B has the barrel grounded) This information is NOT readily available in the manual and results in many a blown amp. They do this to implement the "Bridged" mode easily.
I have schematics and can unravel most any problem you are having.
Aug 20, 2010 | Behringer Europower Pmp5000 Powered Mixer...
We are having problems with a PMP5000 board. We have the switch setting on Mon1/Mono. We can get sound out of the monitor output, but the mono output is almost silent. Do you have suggestions for...
Do you mean the SPEAKER mono output or the top mounted 1/4 inch jacks?
The A side power amp is used to drive monitor speakers and the B side the mains.
All other connnections of speakers require amplifier OR powered/active speakers.
Aug 20, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
What would be the best amp to push 2 kicker 15 L7s
find the ohms on each subwoofer and how much it can handle. If you have two 4 ohm subs get a powerful MONO AMP and hook it up in parallal. If you have two 2 ohm subs get a (1 ohm stable) Powerful MONO AMP and hook it up in parallel or a powerful 2 CHANNEL AMP but the wiring can be a little complicated cause you've got to connect the subs in series and bridge it on the positive of 1 channel and the negative of 2nd channel for maximium benefit without burning out the 2 channel amp. If you got two 500 Watt subs then you got to find an amp that can put out 1000Watts anything less wont sound good and may burn out the subs because of too much distortion cause of lack of power.
Apr 06, 2010 | Phoenix Digital PD-397 Car Amp
Black line going vertical through portion of
Connections on c boards, c board bad or bad panel. Disconnect power supply from sus boards on sides before attemting to disaconnect connectors from c board to flex cables. arc from stored energy on power board will burn cables. reseat the connector closest to the bar . reconnect power supply. Next replace that c board by strip. next replace plasma panel.
Dec 03, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Do i just put the 2 osetive and the 2 negatives
That's pretty much it. I would get two ground distrubution blocks (1 large guage in / 4 smaller out). Use one on the power side and one on the ground side. the extra "outs" can be used to add a cap or another amp later if needed.
Nov 12, 2009 | PPI PrecisionPower DCX1000.1 Car Amplifier...
How to get amp status to come up on the screen of alpine d 310
you have to have an alpine kce-510m amp link module. You must also have a compatible amp, such as mrd-m300, mrd-m500, or the mrd-m1000. The amp link module plugs into the (ext) plug on the iva-d310 and the other end of the cable into an alpine kce-060m y-cable. The shorter of the y-cable plugs into the amp with the lowest id #.
Feb 11, 2009 | Alpine IVA-D310 Car DVD Player
Power Acoustic A3000DB mono amp problems
Broken legs on the rectifiers or an intermittently shorted common mode inductor would be the likely suspects. The common-mode inductor is just to the right of the capacitors in the photo. Install a single 15 amp fuse in ONE of the 4 fuse holders (other 3 fuse holders empty) and power up the amp. Twist the inductor to see if the amp draws excessive current (which would blow the fuse) or to see if it sparks.
Let me know if you have any other questions.
Oct 31, 2008 | Power Acoustik A3000DB Car Audio Amplifier
Optronica amp one channel out.
disconnect any input cable and test-----------if you still have a problem connect your right speakers cables(which supposed to be good)instead of left speakers cable and test------ if the problem solved you will have a problem in left side(cables or speaker)-------if not solved you will have a problem in your amp it self. and needs hardware repair.
Jul 31, 2008 | Audio Players & Recorders
Sub hook up to PPI D3000 amp
I'm not familiar with this amplifier but in most cases, if a mono amp has more than one positive speaker terminal and more than one negative speaker terminal, the positives are directly connected and the negatives are directly connected. So  as long as you connect the speaker positive to a positive speaker terminal of the amp and the speaker negative to a negative speaker terminal of the amp, it will work properly.
Oct 12, 2007 | PPI D3000/1 Car Audio Amplifier
Car Audio & Video Logo
62 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
