Question about Bryant Heating & Cooling
Roll out switch default
I have a new bryant package unit installed by our company! Have a led light code calling for roll out switch fault!! with switch bypassed combustion air comes on with no blower! do i have a bad switch or board! I have 24 volts to switch
  • 182 Answers
Are you jumping the switch out at the board or at the switch?Is the switch closed?grounded wire?
Posted on Sep 25, 2008
Ac unit model # 2HP13L48P-1A
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, or the LED light stationery; the main board is faulty./
Jun 17, 2018 | Televison & Video
Led light of indoor unit blinks 14 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure.
http://electrotechnician.blogspot.com/
http://homenol.blogspot.com/
Sep 09, 2016 | Heating & Cooling
What is the trouble when led light fault is lighted. and also zone 3 led lights is blinking?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 19, 2014 | Televison & Video
Bryant furnace plus 90 led code is blinking once then 3 times fast. What does it mean?
these codes are on the inside panel of the front cover of the furnace. lift off and look inside.there should be a code explain chart on the panel by the light. this panel will need to be replace correctly for the furnace to work as there is a door switch.
Jan 31, 2011 | Heating & Cooling
Need installation instructions for aerosharp HR-INV-XOI-030 solar inverter
My HR-INV-X01 PV Invertor LCD Display has nothing. No power, run or fault lights however the blue safty switches note ON. What could be the problem?
Jan 07, 2011 | Solar Grid-tie Budget Package: Panels,...
Installed new heater it ran for 15 minutes and the gas cut off. The combustion fan and the fan keeps running, the only way to stop them from running is to throw the breaker. LED light blinks 4 times, book...
the high limit is an over heat switch that could mean the unit is over fired. you would need to time input or check manifold pressure. the roll out switch is a switch that shuts the unit off if combustion is spilling at the divitor on the unit where the vent connects. with this you need to check your venting
Jan 05, 2011 | Mr. Heater MHU75NG
Code #33 on Bryant 355MAV 90i Furnace
'Limit or flame rollout switch is open'. In my case, the flame rollout switch had tripped due to an overheating? I had to push the button between the wire leads to reset the switch. Then when I turned the power back on, the furnace started up like normal.
Why did the switch overheat and trip? My current theory is that there was a rubber grommet around a pipe near the switch that had slid down and was no longer sealing the furnace?
If you need further help, reach me via phone at https://www.6ya.com/expert/robert_6c29b8565d620da3
Mar 01, 2009 | Goodman CLJ30AR32 Air Conditioner
Bryant 36E93 gas package (pilot won't stay lit)
If your unit has a thermo-coupling this is most likely the issue This little sensor sends a milli-voltage to the gas valve telling it to keep sending gas for the pilot since its lit and all is good. They wear out and the gas valve thinks the flame has gone out (whick is hasnt) and kills the gas flow.
Jan 21, 2008 | Bryant 462AJC021BA Air Conditioner
Goodman HVAC Package Unit
Cycling the external switch on the GMS series will not help you. That switch is for A/C only. At the unit found inside the house, remove the front cover. If there is a door switch, tape it closed. Now if the thermostat is calling for heat, the unit will cycle as you mentioned. When the unit does not start, check for a blinking light on the circuit board. After three unsuccessful tries, the light will blink a code (2 blinks then a pause up to 9 blinks than a pause). Make a note of how many blinks you see. On the reverse side of the access panel you will find a diagnostic schematic. It should tell you a fault code corresponding with your blinking. This will give you a starting point where to look. If the codes are not found there, check inside your owner's manual. Or you can call Goodman at 713-861-250.
Get back to us with those codes and maybe we can help you further.
Oct 30, 2007 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
231 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Bill Long
Mike Squire
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
