Question about Danby DWC044BLP Wine Cooler
Looking for parts
Where can I find the part to change the door opening from left opening to right opening?
  • 943 Answers
Hi thanks for the question is there not small plugs on your door on the Right if so remove those plugs unscrew the handle change the top and bottom hinges to the other side it should be made to just change over if its not you really cant buy a kit to change thanks the appliance doc
Posted on Sep 26, 2008
3 Suggested Answers
  • 1075 Answers
SOURCE: Change the door opening from left to right. Can it be done?
on most refrigertators this is possable;take a look at the opposate side you should be able to see the holes already in place they might have little plastic covers in them remove and keep.if this is the case its not a big job compared to the kitchen job you done.simply remove the door and move the hinges to the oppisate side, the only thing that would consern me would be the handle position if there is one some doors open by pulling the door from the bottom if this is the case it might not be problem but check the hinges first if the opposite side has indeed holes in place i dont see a problem if you fitted a kitchen im sure a small matter of a handle will not stop you.hope this helps.adrian
Posted on Feb 16, 2009
  • 323 Answers
SOURCE: Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Posted on Oct 24, 2009
How do I switch the door opening to the other side? I would like to change the dryer door opening from the left side to the right side. By looking at the dryer it appears this is possible.
Hello, Frazer -
Without knowing the make and model of you clothes dryer, it is a challenge to provide you with the precise directions for changing the swing of your dryer door. With that being said, this YouTube video may prove helpful to you: .
How did I find the YouTube video? Using Google I entered the following search statement, with quotation marks, as indicated: "clothes dryer door swing" .
This web page with written directions may also prove helpful: .
Best wishes.
Dec 17, 2017 | Dryers
I own a Kenmore HE 5T washer. I washing clothes, as normal. Out of no where, when I went to open the door it was like it was sticking or wanting to hang up. I can open it, but it is not smooth as it was, I...
If the door swings smooth after it is opened it is not the hinge. In most cases it will be on of the 2 parts of the door latch. Look at the door first. There should be a plastic pointed arrow looking part sticking out. See if any of it broke off or got chipped. That is an easy part to change. If not that, it will probably the door latch switch which is the part the pointed part goes into. You will probably need a tech to change it. The hard part is getting to it which in some cases involves unhooking the door boot wire retainer on the outside edge of the cabinet.
Sep 05, 2011 | Kenmore Elite HE5t Washer
Looking to change right hand open door to left hand?
It is not possible to switch the washer door directions, but is is possible with the dryer door.
Jun 12, 2010 | Maytag NFW7200TW Front Load Washer
Installing 8 x 7 garage door, when they say left
May 13, 2010 | liftmaster Chamberlain Garage Door Opener...
How do you change the dryer door from a left to right opening to a right to left opening. Thid is a series 90 kenmore
Open the dryer door. There should be approximately three screws that hold the hinges on there on the right side (as you said yours currently is a left to right opening). Remove the screws that hold the door on. As you hold the dryer door removed from the dryer, turn it counter clockwise so that the handle is now on the opposite side. Lay it on the floor. Now, remove the screw hole covers from the opposite side of the dryer opening ( the left side) (these can be removed with a fingernail or a thin flat tipped screw driver to pry them out). This will expose the screw holes on the opposite (left)side of the dryer. Take the removed covers and place them in the original screw holes on the right side. Now simply reinstall the door hinges in the newly exposed screw holes on the left side. This will only work if your dryer is designed to have both types of openings. Good Luck!
Feb 27, 2010 | Kenmore 659 Electric Dryer
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
How do you change the door on a Maytag 200 dryer to open right to left instead of left to right? Is that something that a homeowner can do?
Please specify the numbers on to machine data plate (serial, part #, etc.).
Some models do not have that option, but most Maytags do.
Aug 12, 2008 | Maytag Dryers
Need to change door from left hand to right hand open on kenmore HE2
I am looking for the same answer on the washer. You can definitly change the dryer. The holes are on the other side under black tape.
Nov 16, 2007 | Kenmore 43142 Front Load Washer
Danby DWC044BLP Wine Cooler Logo
144 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
