Question about Panasonic DMR-E80H DVD Recorder
Panasonic dmr es35v
Shows no read wont read cleaner unit has only been used about 15 times
  • 1 more comment
  • sbettwy Nov 08, 2008
    I have the same problem after 15 months of usage. I cleaner the laser eye thoroughly. It makes funny grunting noises and then says "no read"
  • offroadhusky Nov 30, 2008
    Same unit same issue. Tried cleaning, reboot etc. Unit will not reset or spin the disk so it can read. Buzzes four times and "no read" is displayed.
  • izidod6979 Jan 13, 2009
    Same problem. Same noises. No read.
SOURCE: IS MY DVD COMBO REGION FREE
If my combo is region free it does not play region 2
Posted on Feb 07, 2008
Slinteriors
  • 8617 Answers
SOURCE: panasonic dmr-es35v dvd recorder
It can be repaired however I am not sure if the hard drive is available for that unit or not. I would contact panasonic to inquire as to the availability of a new drive.Sorry I couldnt help you more with it.
Posted on Apr 06, 2008
  • 12 Answers
SOURCE: PANASONIC DMR-ES35V CANNOT READ ANY
i thing its a laserunit you need open that dvd and try cleen laser,but very very easy,its a little pot on back laserunit its can be set to,but if that not help,find laserunit number and try find new on internet :o(
Posted on Aug 14, 2008
shinma
  • 5 Answers
SOURCE: Error code U61 on a
The manual refers to the U61 as being a recovery mode. Have you left it at U61 for a period of time while it tries to recover?
U61 ≥There was a power failure or the AC plug was disconnected while the unit was on. The unit is
carrying out its recovery process. This process restores the unit to normal operation. The unit is not
broken. Wait until the message disappears.
You could always try to force it into standby mode and back out again:
Press [í/I, POWER] on the main unit to switch the unit to standby.
Now press [í/I, POWER] on the main unit again to turn the unit on.
If that doesn't take care of it, everything thing I've found points toward a replacement of components inside the system by a repair service. Hopefully you are still under warranty!
Posted on Sep 21, 2008
SOURCE: WHEN I TRY TO USE
I called tech support and their answer was simple!
Error Code U30 1.......the fix, press and hold the number one (1) on your remote and at the same time press and hold the ENTER button for 10 seconds while pointing the remote at the units sensor.
Automatically, my unit returned to normal and all my buttons on my remote returned to operational mode!
So, it was confirmed by Vincent at Panasonics tech support, that error codes U30's are rare, but it's a system safety feature. If you were to come across an error U30 2, you would push and hold the number 2 while pressing and holding down the ENTER button....so on and so forth.
I hope this helps someone else out there!
Shelley
Posted on Jan 08, 2009
My dmr-es35v can't read any kind of dvd. what can be wrong?
Laser pickup unit fault. Check and replace it. Contact any service technician. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Feb 18, 2017 | Panasonic DMR-ES35V Multisystem Code free...
Panasonic DVD-RAM "Invalid Disc"
This would suggest the disc is defective, especially when all others work. I would return the other.
Mar 12, 2012 | Panasonic DMR-ES35VS
I have a Panasonic VHS-DVD player/recorder model DMR-ES35V. I was recording and playing back at the same time using a DVD-RAM disk (using the time slip feature). After about an hour of viewing I got an...
FOR AL THOSE WHO HAVE A PANASONIC DMR-ES35VS THERE ARE MAJOUR PROBLEMS WITH THE RAM DRIVE WHEN IT IS DEFECTIVE THE DVD PLAYER WILL MAKE A SOUND LIKE IF ITS TRYING TO READ OR YOU WILL HERE A SORT OF SCRATCHING SOUND THIS MEANE YOUR RAM DRIVE IS DEFECT IT WILL COST 200 DOLLARS FOR THE PART
Oct 21, 2010 | Panasonic DMR-ES35VS
DMR-ES35VS: How do I connect my Panasonic DMR-ES35V through a ...
Put the main aerial into the set top box,then take a male to female fly lead and connect it to your panasonic,then take another fly lead from the panasonic into the tv.If you have two scart sockets on each unit and the tv you can connect one into the tv from the box and one from the panasonic into the tv,then you can connect the box to the panasonic so you could record from the box.
May 05, 2010 | Panasonic DMR-ES35VS
Panasonic dmr-es35v dvd/vcr recorder reads hello, then u61, then
Plug AC power cord to wall electric socket if it is plugged into a surge protector or extension, if not try a different socket, if issue still exist have unit service.
Sep 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-ES35V
I have a dmr-ez25eb DVD recorder and it has stopped Recording and playing back , the screen on the TV says that its a none recordable disc but I have been useing them from the time I purchased the DVD
Aug 31, 2008 | Panasonic DMR-ES10 DVD Recorder
Panasonic dmr-es35v
Is the Remote Control sensor in direct fluorescent lamp light or other strong
sources of light?
Press unit POWER button down over 7 seconds. The POWER indicator goes
out. If the Power was On, the screen will also disappear. After 5 seconds, turn
Power On and operate unit normally. If the steps above do not restore normal
operation, disconnect then reconnect the AC plug and turn the power On.
If that does not work, Panasonic offers free tech support 6 days a week 1-800-211-7262 (pana).
Jul 29, 2008 | Panasonic DMR-ES35VS
Panasonic dmr-es35v dvd recorder
Apr 06, 2008 | Panasonic DMR-ES35VS
On my DMR-ES35 Panasonic after perfect operation for 18 months, I'm getting a NO READ message, on disks already recorded on this unit,and several new disks of different makes. The main sympton now is
Same problem. "NoREAD" after about 15 months of moderate usage. Cleaned laser eye thoroughly. Solution is a class action lawsuit against Panasonic.
Jan 21, 2008 | Panasonic DMR-ES35VS
Panasonic DMR-E80H DVD Recorder Logo
145 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
