Question about Memorex 32023252 Internal 52x CD-ROM Drive
Defragment data file missing
When I go to tools and attempt to defrag. It says file does not exist or I do not have access,
Thank for any help,
Carol
  • Seasumner Sep 25, 2008
    NO, I'm sorry I'm trying to defrag my hard drive not my CD Rom it is fixed thanks to yawl!
    Carol
    Sergeant:
  • 359 Answers
You don't defrag a cd drive... there is nothing to defrag.
You only defrag your harddrive, not a cd/dvd drive
Posted on Sep 25, 2008
Why my lenovo g640 so slow, how to fix it???
If you are using windows, use the "clean up" tools to delete all redundant files including logs etc. Then run the defrag tool.
If you are running Win Vista or older, consider an upgrade.
May 09, 2014 | E-Machines Computers & Internet
How do i speed up my laptop
Slow computer If you have a virus program installed, it is most likely is running a scan on your hard disk. It can slow down your computer especially if you have a large hard drive. After scanning is completed then the computer will be faster.
To make your computer (hard disk) lean and mean, uninstall any programs you do not use.
Also you need to maintain your hard disk by running Disk Cleanup this will remove old temp files and old compressed files etc.
This will reduce the number of files the virus scanner has to scan. Plus running Defrag. this makes your files contiguous so the system can access files off the hard drive quicker because it does not work as hard.. Disk Cleanup and Defrag should be carried out at least once a month.
If you have 512Mb of RAM installed then installing more RAM will speed up your computer. After installing your graphics card, you may need to disable the built-in graphics card in the BIOS for the new graphics card to work properly.
Mar 21, 2013 | Computers & Internet
I couldent format my computer when the computer restart the error mssage apper the massage says disk read error
1: Download a disk read error repair tool,install this error repair tool.
2: Open disk read error repair tool and scan you computer for free
3: Then click the Repair All Button again and your done! It is very easy to repair disk read error.
Here are the url of disk read error repair tool:http://www.RepairErrorInstantly.com/ttfi...
or rather than doing this try the alternative which is windows own repair
click start right click on my computer you should see your drive usually C: select properties click tools check now tick both boxes automatically fix files and scan for and attempt recovery on any
bad sectors or you could tick one box and wait until its finished then return and tick the other box
then select check now start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
also download a registry cleaner
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
hope this helps
Oct 16, 2012 | E-Machines emachines (emachinees) CD-ROM...
Blue screen
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical
power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer ram make sure they are securely seated with no dust built up or in the sockets
although on some motherboards the cmos batteries are soldered in
you might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang also uninstall some unnecessary programs and run the chkdsk utitlity
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
you should have no input while the chkdsk utility is I progress any input might damage your computer
then defragment your hard drive
hope this helps
Dec 04, 2011 | Dell Computers & Internet
Slow downloads and freezes
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
then click start all programs accessories system tools defragment your hard drive
you might have to install more RAM random access memory to check how much ram you have
to check the details on your computer
click start all programs accessories system tools system imformation you will see all of your computers imformation from there another way of doing this
click start right click on my computer select properties you will see all imformation about your computer including installed ram
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer if you see something running that you don
Jun 02, 2011 | Dell Inspiron 8000, 8100, 8200 Series...
My laptop asked me to insert original Compaq cd drive to repair the Failure occurred to my computer but i don't have the drive yet so i need an assistance
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
or if its a problem with the cd drive itelf
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
May 14, 2011 | Compaq Computers & Internet
My Dell Inspron 8500 runs really slow how can I speed it up
Lowest cost solution is defrag and clean-up. Go to My Computer, right click on the c: drive and select properties. First do the clean-up, then click on the tools tab and defrag the disk.
If you have less than a quarter of your hard drive space free, consider a new hard drive as well. Or just uninstalling the programs you don't use and archiving the music and pictures to cds (or DVDs if you have an external burner--the 8500 has a DVD reader only, if I remember right.) Gives you back-up and access.
Next would be ram. I'd recommend at least a gig for XP sp3 any more.
Lastly, If you do need a hd and ram, see what specials are available on new laptops. What you get from selling yours, plus what you'd save from not doing the upgrades will probably buy you a machine that has 10x the hard drive and 6-8x the ram of your old one. Plus a DVD burner.
Jun 22, 2010 | Dell LATITUDE D400 D500 D505 D600 D800...
My computer is running slow it takes 10 mins to load up from start
things to try ,
1 depending if you have windows vista or xp or 7
if vista start, all programs, accessories, Command and prompt, Right Click it then run as administrator.
if xp just click it,
then Type chkdsk /f
this is a command to scan the computer for errors and fix them. reboot the computer and wait for it to do the scan this should make it a bit faster , try defragment , delete your browser history and cookies, disk cleanup on accecoties,system tools
Feb 17, 2010 | Computers & Internet
Slow Laptop Performance
a virus effect!!
plz download avira its free and start scanning NOW!!
plz rate this post.
Feb 10, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Hang up
What is the system configuration? How old is the system? Is it a dual boot? Do you have any programs running when running defrag or scandisk?
Mar 09, 2007 | Sony (CDU5211-10/10S) Internal 52x CD-ROM...
Memorex 32023252 Internal 52x CD-ROM Drive Logo
50 people viewed this question
Top Memorex Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Jax Planet
Jax Planet
Gareth Cockram
Gareth Cockram
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
