Question about Refrigerators
Old (65 years) ge freezer was just moved to new location and is not freezing anymore, I have already checked outlet to ensure power, si there something that might have gotten jossled that I can adjust or tighten...??
  • 943 Answers
Hi thanks for the question i will assume that this is a chest freezer if it is what happens with those freezers is if you move them after years . the condenser lines that are located between the wall rust out and sometimes a good jar will just advance the problem it would have happened in a short time anyway thanks for the question the appliance doc
Posted on Sep 26, 2008
Ge side by side refrigerator GSS25XSRDSS freezer not freezing
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 04, 2012 | Refrigerators
GE SIDE BY SIDE MODEL #GSH22JFRE CC FREEZER COIL FREEZING AND REFRIG NOT COOLING. DEFROST MANUALLY AND REFRIG COOLS FOR A COUPLE DAYS, THEN FREEZER COILS FREEZE AGAIN
We have a GE side by side that was only 4 years old before it starting giving us problems-coiling freezing over. The warranty period was only one year on all parts, including the compressor. Through our research we learned that profile appliances have or did have a better warranty. I believe it is 5 years on all or certain components. Either way it may be worth contacting GE customer service to help you with the issue and determine if repairs and parts for your appliance are still covered under warranty. They were very helpful in our case and ultimately discounted the parts I ordered and replaced myself. Replaced the the temperature sensors on the freezer side, the defroster thermostat and defroster heater before finally breaking down and replacing the control board. The control board was the problem. It was very easy to replace. While working through the issue, we would defrost the coils located on the inside of the freezer side with a hair dryer. It would get us by until the parts came in or they frosted over again and prevented air from circulating over them, thus causing the freezer not to cool. Good luck. Hope this helps you.
Nov 23, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
GE Fridge PSS25MGNAWW freezer problem
ok you right all the way :)
but the main thing is when the unit is not in defrost power should come to the fan ?
the board # is WR55X10174 and it is 149$
the fan is 65$ so it is still worth the price then a new unit.
Dec 31, 2009 | Refrigerators
GE Profile Series - Side by Side Refrig - No Water Dispensing
Tubing/resevoir is coiled behind the crispers and can freeze.
Eric
Jun 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezes up in the back of the freezer..won't hold cooling
you have defrost problem 1 timer may be 2 heater 3 defrost thermostart call service
Apr 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Do I need a compressor on side by side fridge
u might have a dfrost problem ge well known for that try unplugging for 4 or 5 hrs leave doors open plug back in if works fine its the defrost then u will nered defrost heater tstat and main board vey expensive cheaper to get new
Mar 18, 2009 | GE GSL25JFPBS Side by Side Refrigerator
GE Profile refrigerator model PFCS1NJWA is freezing items in back
slow air flow will cause it to freez check air flow from freezer in at the top and back at the bottom
Nov 30, 2008 | Refrigerators
Freezer coils and water in drain tube frozen
check to see if the fan running first, if yes than you may be losing freon. if not , try a new fan motor
Jul 29, 2008 | GE GTH18KBM Top Freezer Refrigerator
If your light inside does not light when you open the door you problem could be power related. Your description sounds as a power supply problem. Try moving the power cord to another outlet.
Apr 29, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
51 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
