Question about HP PSC 1210 All-In-One InkJet Printer
Print images bad
Need to print a new sheet like you get when you replace a ink.
    Guru:
  • 558 Answers
It might be due to the cartridge is not properly recognised by printer.
Or may be the printer is set on Fast Draft.
In either case Let me know if I can assist you further.
Regards
Ellin
Posted on Sep 26, 2008
  • Puneet Jain
    Puneet Jain Oct 18, 2008
    Reply please if the soluton work for you.
    Give your rating to the solution either Helful or Fixya.
    If you dont fix the problem yet by the solution given then I would suggest you more options, let me know for it.
    Since your voting is precious to me in providing the help for others.
    Have a Nice day.
    Regards,
    Ellin
WE HAVE A KODAK ESP-3 AND HAVE PUT IN NEW INK (BLACK) AND IT WON'T PRINT. THE COLOR SHOWS EMPTY BUT IT'S ALSO NEW. ONLY WANT TO PRINT BLACK BUT IT WON'T PRINT EITHER JUST SHOWS LOW INK ETC.
First: you need both ink cartridges for the printer to function properly.
Second: You may have a bad printhead, do the following:
Clean the print head then print a demo sheet.
  1. Verify that inkjet paper is loaded in the paper trays.
  2. On your desktop, start the KODAK All-in-One Home Center, then select the Help [?] icon.
  3. From the Help menu, select Maintenance, then select Print head Cleaning. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows a steady green, press Photo and Copy simultaneously to print a demo sheet.
If the Demo print is bad- IE: no black, blurry print etc., then you may need to replace the print head:
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/printhead/AUR1780-9_UE_RevC.pdf
Contact Kodak:
All-in-One Printer Phone Support Live telephone support is available in English and Spanish at 1-800-421-6699, 9 A.M. to midnight, Eastern Time, 7 days a week. The expected wait time for phone support is 15 minutes.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 27, 2011 | Office Equipment & Supplies
My mfc-240c won't print red, even with a new cartdrige.
Try running a few cleanings on the color.
Press the ink button and select cleaning,, do about five cleanings. Print the ink quality test page (from the ink button as well) and see the quality if it improved.
If it still doesnt print its possible the ink is clogged and may need servicing to replace the printer head
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
U053 error code,tried removing and replacing cartridges, but code still present,cartridges are compatible as come with printer.
Printing with an empty ink cartridge may cause printer malfunction. U051 / U052
U053 / U059 The ink cartridge may not be set properly, or an ink cartridge not supported by the printer is installed.
Install the proper ink cartridge.
Make sure to install both the ink cartridges even when you set the printer to use only one ink cartridge (Color or Photo) in printing.
If one of the ink cartridges is missing, this error will occur. U075 / U076 The ink cartridges are not installed in the proper position.
Install each ink cartridge in the proper position. U140 An ink cartridge not supported by the printer is installed.
Install the proper ink cartridge. U161 / U162 A used ink cartridge may be installed, or the ink cartridge may be empty.
Replace the ink cartridge.
By pressing the OK button, printing can be done without replacing the ink cartridge. However, the remaining ink amount cannot be detected properly, so the function to detect the remaining ink amount does not operate. READ/WRITE MODE Since the memory card is currently write-enabled, printing is not possible.
Set READ-ONLY MODE ON. NO PHOTOS ON CARD Some images in the memory card may not be in a supported format. images listed below cannot be printed directly from a memory card. Print them from a computer.
- images edited on the computer
- images in a format other than JPEG or TIFF
- images with double-byte characters used in the file name
- images saved in a folder nested 4 or more layers deep INCOMPATIBLE CAMERA The printer cannot communicate with the connected camera.
Disconnect the cable between the printer and the camera to clear the error.
Confirm the following items and print again.
1. Confirm that the camera you are using supports PictBridge or Canon Bubble Jet Direct.
If the camera does not support either one, the printer cannot print directly from the camera.
2. Set the camera in PictBridge print mode before it is connected to the machine. This is required before printing for some cameras that support PictBridge.
Please refer to the camera instructions for more information about procedures required before and after connection to the printer.
3. There may have been no response from the camera for the prescribed time.
Re-connect the cable between the camera and the printer. WASTE INK NEAR FULL The waste ink absorber is getting full.
Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and printer maintenance.
The waste ink absorber is a part inside the printer, which absorbs ink used in the cleaning operations, etc. CHECK PRINTER Turn the printer off, and remove the power plug from the outlet.
About ten minutes later, plug it in again, and turn the printer on.
If the problem is not resolved, the printer may require servicing. Please contact your local Service Center. HEAD ALIGNMENT ERROR Automatic print head alignment failed.
Press the OK button to release the error.
Check the followings and do automatic print head alignment again.
- Check if A4/Letter-sized paper is loaded in the auto sheet feeder.
- Check if the paper output slot is not exposed to a strong light source
- Print the nozzle check pattern to check the status of the print head.
If the problem continues, do manual print head alignment. LOAD PAPER If paper is not set, set paper and press the OK button. When paper is set, check each item and do printing again.
1. Confirm that unusable paper is not set.
2. Confirm that paper is set properly.
3. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
4. Cleaning the paper feed roller may resolve the error.
If the problem persists, the printer may require servicing. Please contact your local Service Center. PAPER JAMMED Remove the jammed paper.
If paper jam frequently occurs, check the following:
1. Confirm that no foreign material is inside the printer.
2. Confirm that unusable paper is not set.
3. Confirm that paper is set properly.
4. Confirm that recommended paper is used, and the number of sheets set in the auto sheet feeder is within the limit.
Dec 27, 2009 | Canon Office Equipment & Supplies
Error Message U053
Error messages displayed on the LCD and how to handle them
When an error has occurred in the printer, the error / check message is displayed on the LCD.
Take the appropriate action to return to the normal condition.
Error / Check message How to correct CHECK INK
U041 An ink cartridge is empty.
To cancel printing, press the Stop/Reset button.
To continue printing, press the OK button.
After the printing finishes, replace the empty ink cartridge.
Sep 15, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer will not print anything. Ink levels are
If it has been longer than 3 or 4 weeks since anything last printed, the problem may be clogged print heads. Run thru several cleaning cycles and see if anything begins to appear on the paper. If not, changing the ink cartridges may solve the problem. If it's been quite a long time since last printing, you may need new (and expensive) printheads. If that's the case, replacing the printer would be more cost effective. Sorry for the bad news.
Aug 13, 2009 | Epson Stylus C88 InkJet Photo Printer
Replaced print head and cartridges and still not printing.
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost..
Jul 04, 2009 | Kodak ESP 5 Printer
Bad streaking on print xerox 8550 phaser tried the troubleshooting feature/eliminate light stripes with no luck
The best way to tell if your problem is clogged jets, or bad maintenance kit, or something blocking jets. Is to look at light stripes test, and see if missing jets are all in a straight row or all over the place. If the missing jets number less that 10 you can use jet substitution to avoid the streaks. If you are using Media Sciences or some other after market ink, check that most of your problems are not in the cyan area. Media Sciences produced a bad batch of cyan which clogged the jets pretty bad. The good news is that if their ink caused the problem they will pay for some one to come out and replace your printhead. If you LST (Light stripes test) has a smear the entire vertical lenght of the page. You have either a bad maintenance kit, or a piece of paper, lable etc..rubbing against the drum while printing
Jun 04, 2009 | Xerox PHASER 8550 COLOR Printer
HP PSC 1210 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
