Question about Pioneer CDX-P1280 12-Disc CD Changer
Pioneer CD changer doesn't play all tracks
I have a CD-P670 6-disk changer which exhibits 2 problems, possibly related. When it's hot, it will either not play at all or will play a few tracks & play intermittently or display error 11. In moderate temperatures it plays the first 7 or 8 tracks, but not the remainder. Tried cleaning the lens multiple times with 3 different cleaning disks, inserting different audio CDs (commercially made & CD-Rs) & using other magazines with the same result. Inasmuch as the laser reads the first 7 or 8 tracks & the sound is good, I don't think that it's the problem.
I opened the changer & lubed the worm gear that moves the lens assembly with white lithium grease & it appears to move freely when driven by its motor. All other functions are OK & nothing looks worn or warped.
I'm stumped. HELP!
3 Suggested Answers
  • 65 Answers
SOURCE: Pioneer cdx fm653 6 disk changer won't power up
first try to get another display, maybe it's broken (could be the cable cutted), the changer with a motor noise in the moment you plug it, tell me that its ok (95%).
Posted on Sep 17, 2007
  • 44 Answers
SOURCE: CD changer problem
According to the manual, error 11 means the disc is inserted upside down.
Posted on Feb 05, 2008
U70 error message on cd player
U70 error message on cd player - Fixya
www.fixya.com/support/t12308553-u70_error_message_cd_player
Apr 5, 2012 - U70 error message on cd player Cd player doesn't work at all. Displays 0 track, 0:00 (min,sec). The play - Technics CD Players question.
Technics error code f 70 CD Players Questions & Answers ...
www.fixya.com > Forum > Tags > error code f 70 > CD Players
Technics cd players error code f 70 related questions and answers. ... won't play cds changer turns on ok, reads error message I have the same problem.
Apr 05, 2012 | Technics Audio Players & Recorders
I Have a Pioneer PD M602 6 disc changer, and I just bought it used. And I cant get it playing. Sometimes say "no disk" ( but the tray is full discs applyed as it schould. It loads one disk after...
To my surprise, CD cleaner disc did it for me. It's a very old Philips one with a bit of furry stuff on the track side. I was amazed it even played, but it did and after letting it run for 20 secs, tried proper discs and it works fine. And this Pioneer PD-M603 is at least 15 years old!Looks like it would be hard to clean the lens manually because it's a long way inside.
Jul 27, 2011 | Pioneer PD-M603 6-Disc CD Changer
The tray will not open. I loaded the cd's into the changer, closed the tray and it sounded like one of the cd's may have slipped. It does not change or play.
my friend u r going 2 have 2 take it apart. you will have 2 unscrew 4 or 6 screws from the side or bottem 2 take off the top a take out the cds yourself. its not hard 2 do.just remember tht a disk changer can b off track. its possible 2 pull it open but dnt do it if u will break the door track
May 09, 2011 | Denon DCM-290 5-Disc CD Changer / Player
10 disk player inconsitently plays or reports "err" for each disk position. How to fix?
Please remove the cartridge and check all the discs on it ., It is possible that over a period of time the disc could have warped. The disc while loading could be going into the wrong track and hence the mechanism needs a check on the path . Alignment of the loading tracks must be checked or corrected.
Feb 25, 2011 | Cherokee Jeep Grand CD Changers - 10-Disc
Getting 'no disc'
HI.This will occur when the optical assembly becomes unstable. this ((Whole One Piece)), assembly incorporates the spin/load motor, optics housing /arm, tracking device and tracking rail. This is connected to the loading dock assembly. This 'NO Disc', code is the result of a failed or burned out lens. It is possible that you have a dirty lens cap. you can try using a cleaning disk in this case to confirm actual lens failure. if the cleaning doesn't restore normal reading capabilities, this will confirm my diagnosis.
You will need to have the optical assembly replaced in this case. once replaced, your unit will be able to read and track once more.
Jul 25, 2009 | Pioneer PD-F1007 301-Disc CD Changer
Error Message
sounds like the lens is dirty -try this out you kow them cans of stuff they use to clean keyboards with its like filtered air or something -try to blow out the guts of the cd changer with one of them cans and maybe it will help with functionality do the same with the cartridge emtied out and then run a cd lens cleaner disc and see if that does the trick-
May 21, 2009 | Kenwood KDC-C669 6-Disc CD Changer
Error 11
Error 11 and or Error 17 is mean that CD is dirty or scratch, and the optic can not detect CD track.
Solved problem:
1. Clean the CD
2. Change open source by push knob going to "CD" display or push "search" from remote to "CD" display
3. If still come out Error 11, change the MP3 CD by Original CD with clean track CD.
4. For the last step, clean the optic sensor by CD cleaner for a few minute.
5. Check and try to play the CD again.
Apr 26, 2009 | Pioneer Car Audio & Video
IT is Pioneer PD-M430 6-Disk CD changer
turn the cd, the silver side must be look down
Sep 16, 2007 | Pioneer PD-M406 6-Disc CD Changer
Pioneer cdx P1280 error11
pnoman: Your code means an electrical/mechanical failure. Follow this: 1. If the cartridge is stucked try to force it out slowly with a fine screwdriver. 2. Once is out or if already out without forcing it, remove all remaining CD's. 3. Insert a laser lens CD cleaner. 4. Clean it at least 3 times. 5. The unit must be disconnected from the 12V signal to be reset it at least 5 minutes, then reconnect. 6. If problem re-appears repeat procedure once more. If problems still, your laser lens is damaged and need replacement. Probably from $40.00 to $55.00. SithPitt
Jul 04, 2007 | Pioneer CDX-P1280 12-Disc CD Changer
Pioneer KEH-P6600 diplays "error-11"
use your user guide to read the problem related to error 11 .. most probably your wire connecting your changer witht he head uint is either cut or not functionall ... hope that answers the question
Jun 25, 2007 | Pioneer KEH-P6600 Cassette Player
Pioneer CDX-P1280 12-Disc CD Changer Logo
94 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
