Question about Epson Stylus C66 Photo InkJet Printer
Epson c66 the spring as come out of the printer and the paper will not feed through I just do not know the spring comes from
  • Gerry Millward
    Gerry Millward May 11, 2010
    Look at the row of rollers in the main print area - where you lift up the front lid. Are there rollers or springs missing? If so, this is where your rollers/springs came from. If this is the case, do a repost and let us know.
  • Gareth Hale Jan 12, 2013
    The Epson C66 is notorious for losing the spring which is situated directly behind the plastic paper feed panel. If this panel does not have a 'springiness' about it that is where it is from. The spring is about 1.5 inches long and one inch in diameter. It fits directly between the 'hinged' panel and back panel where you feed the paper in. If you remove the hinged part (it comes off with gentle persuasion) you will see a grove where the spring slots in. The job of the spring is to give the paper a 'gentle nudge' onto the rollers.
  • 353 Answers
My clarification request is really a solution.
Posted on Feb 28, 2009
Epson c66 not feeding paper
Main reasons for a paper feed problem like the one you describe are:
-. One of the sensor actuators (normally It will be a little plastic lever on the path of the paper) is either broken or blocked. It could happend if you attempt to remove a paper in the opposite direction of the normal paper movement path. Check if you can see something like that near the point where the paper stops.
-. The second option will be dirt on the feed rollers. If you can remove them easily the you can try to clean them using water and soap. In that case what is happening is that the paper reaches the first sensor but the printer doesn't knows the paper is stuck until It detects that the paper arrives later than expected to the last sensor (a timing issue). As the printer keeps printing this is the most probable cause to your problem.
I don't know that model of printer in particular but I hope this serves you as a guide to pinpoint the issue.
Jul 07, 2012 | Epson Stylus C66 InkJet Photo Printer
Paper wont feed through myepson c66 printer..please help..is it the way i'm loading it ?
Some times the paper is the problem. it may damp or old replace it. else the rubber finger that grabbs the paper may need to be replaced.
Aug 29, 2011 | Epson Stylus C66 Inkjet Printer
Both the ink and paper feed button are flashing (Epsom c66 printer)
check for a paper jam or an ink cartridge jam which was not properly aligned. usually thse are reasons. also check your ink levels and never touch the part of the ink cartridge connected to the printer. just keep pressing cancel or X, cancel the documents, then load another paper then press on start copy. this should work.
Jul 08, 2009 | Epson Stylus C66 Inkjet Printer
Epson stylus c66 is new but in printing paper comes out blank
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Epson Stylus C66 Inkjet Printer
Epson Stylus C66 inkjet Printer does not print !
Have you tried a cleaning cycle? If not, try one. Now run a nozzle check using the status monitor (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back.
Nov 12, 2008 | Epson Stylus C66 Inkjet Printer
I've got a epson photo stylus c66
There must be something wrong with the paper roller of your printer.
Oct 19, 2008 | Epson Stylus C66 Inkjet Printer
EPSON TM T88IV
The TM-T88IV printer is a thermal printer and does not have ink or a ribbon.
If the printer is not printing you may have the wrong type of paper in the printer. You must have thermal paper in order for the printer to work. Paper for a dot matrix printer will not work in this printer.
The printer has a self-test that you can perform by turning the printer off, holding down the Feed button and turning the printer on. A test strip will print. Press the Feed button again to print a longer test strip.
May 14, 2008 | Epson Stylus C66 Photo InkJet Printer
Loose spring on epson c66 - paper loading problem (hardware issue)
Hi-
yep chances are those spring might not be available for replacement, try compass micro visit their web for an exploded diagram of the printer or parts. this is one of their parts distributor.
Hope this helps
Mar 22, 2008 | Epson Stylus C66 Inkjet Printer
Epson Stylus C66 Photo InkJet Printer Logo
51 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
