Hi my reply was too long heres the second half..and ill retype the first as a comment
Try printing lighter prints, heavy toner saturation causes paper to stick to fusers and try to keep leading edge of print blank with no big blobs of colour for the same reason, ensure page sizes are set correctly in driver and machine tray settings and dont print outside margins , if you are about to print outside margins your printer driver should warn you, dont click ok if it does
Here is your user manual for your oki. and a link to oki print drivers to suit 610
Here is a link to Magic touch Australia that i thought has some good info re transfer paper use
Ensure your printer works ok with plain paper so we know it aint a printer fault but I'd say it due to how we are feeding the paper and how we have the paper type set and not feeding out the rear as I also think we should be.
Oki does the best colour prints nice and glossy, I dont think many come close to such great colour prints in fact I only like Oki and Kyocera stuff in Colour toner laser machines. Stear clear of cheap non oki toners and supplies because they cause heaps of issues and wreck printers and give many print quality issues, I dont work for OKI directly just telling you how it is in the field ;)
Let me know if you need more help and how you go
Cheers
Steve
Hi Kyla, cool name...sorry I just got home from work and spent an hour typing you a reply and the darn thing was too big and I lost the first half, so I do it again but in bits in case is dissapears too;)
Ensure you have paper/media type set to glossy as it changes the speed at which paper is feed which in turn effects amount of heat generated in the paper, ie If it is set to heavy, paper is feed slower so we gwet more heat in heavy paper so toner can stick to it properly. transfer paper need to be set at glossy setting I beleive.
Feed sheets one at a time via the bypass tray (manual feed or MP tray). ensure page size is set correctly in printer for MP tray and in driver paper type and size.
I also think you should feed out the back, which is know us face up printing, to do this on yours you just open rear tray and extend the paper catching arm like this pic that I cant post as a comment now;( but look in the manual I provided for your printer it was from there.
Please read this guide to transfer paper use.. cant link now either so here is the web addresshttp://www.themagictouch.com.au/transfer...
Please run just plain paper for a few prints in your machine to clear any toner still stuck inside from the jamming and to ensure your print isn't jamming on normal paper so we know it only the paper giving us grief not the printer itself. (please excuse so so many typos Im getting tired and trying to type too quick.;)
When you go to print ensure you are not printing outside the margins your computer should warn you if you are once you have page sizes set correctly in document (ie word page size) and the printer driver (oki icon/ printer properties/preferences) and printer itself (menu settings).. I'm going to leave it there but please come back to me with results or issues and we will sort it one way or another. oh and ensure paper is for laser not inkjets... big difference, inkjets dont use a fuser to melt toner to paper..but I think DCT 4.5C or w is for laser so we have the right gear so it seems.
cheers
Steve
Thank you for ALL of your tips! You have given me more advice in one day that their tech support has given me in TWO MONTHS! Unfortunately, I am still having the same problem after taking all of your advice. I am printing a light green floral print and changed the settings to glossy, and it is still sticking to the entire roll. The printer is plugged into the wall socket and I am using a USB port cable... OH! And I got a Fatal Error #928 the other night as well...
Also, it prints just fine on 5x7s... just not A4
Hi Kyla the error isnt too much of a concern i guess. It refers to the machine not being able to turn the fuser unit so I'm thinking you got that when you had a jam in it.
Does it print a4 paper ok? If it does then the issue is, I think, that you need special A4R transfer paper, not A4. A4 is for printing sideways ie long edge first and A4R is for feeding short edge first as you must due to limits of your OKi as it is not a A3 printer which can feed a4 sideways.. see this
"4. A4 size paper must not be fed short edge first! SEF feeding can lead to damage of the fuser rollers. All MagicTouch paper products can be obtained in A4R/SEF format if required ie for A4/Letter size printers." thats from magictouch link i posted before.. I would also for the fun of it try printing with paper type light or thin to see if that helps the problem but it may well stop the powder sticking to the paper properly. What is the exact codes on your paper and I'll check if it does indeed need to be A4R stuff
Steve
Link to service manual , please note this is not your exact machine as service info is confidental but this one is already onthe web, so i cant be told off cause i didnt put it up, and the codes if you need them are pretty much all the same as this older model.http://www.a2itgeek.com/service/OKIDATA/...
I cant find A4R DCT anywhere but i read it is available just dont know where...I wish I could see it..anyway with what we have.I'd feed it from bypass, out the back, I'm guessing normal paper isnt a issue but your DCT stuff folds the corner when it hits the fuser and the jams up, could try getting tricky and cutting like 2cm of the long edge and sticking that in to if it works
I saw that too... I think that you are right about the paper needing to be A4R. I am about to go to bed (dern time change), but will try it in the morning. THANK YOU SO MUCH FOR YOUR REAL HELP!!!
If you want technical support of Okidata, you can contact us on Okidata Customer Service 1-866-877-0191. We are always available with technical experts for your help. For more information, click https://goo.gl/d2sZbZ
If you need Okidata Printer Customer Service, then you can contact with us, okidata printer support 1877-778-8**9@[email protected] are always here with tech team for your help. For further Info Click:https://goo.gl/Ltis3S
