Mobile home coleman - evcon furnace model EB23B vandalized. I think what is called the Evaporator coil?? (Copper A shape) was taken from the home. All that remains is the blower. Now...was the copper coil for a/c or heat? and isn't there supposed to be some additional heating element that also goes with this furnace used for auxiliary heating that I must replace? I would appreciate any advice as to the parts I must get and possible cost...Thank You.
    Scholar:
  • 121 Answers
What a shame! An a coil runs about $500-$600 and an elec. heater kit about $100 plus labor and if the coils are missing then you Will have to replace refrigerant at $20 per lb.. I would replace the unit for about $1000 and then you'll have warranties on it. Sorry for your misfortune.
Posted on Sep 27, 2008
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
Coleman evcon furnace in mobile home works fine during the day but not at night. What could cause this?
I suspect water in the fuel that is freezing up due to the pressure difference across the jet and causing a blockage.
Feb 16, 2013 | Tools & Hardware - Others
I have a Coleman Evcon Elec Furnace with the added AC Unit. The blower works great with the AC but only on & off with the heat, what could this be?
Replace the sequencer...which is just a series of snap disc relays that are staged. The first snap disc should kick on the first element & low speed of blower. Depending on how many elements you have, determines how many snap discs are on the sequencer. It could be a 2,3,4, or 5 stack. Generally the coil is 24 volts.
Dec 01, 2012 | Coleman Evcon Furnace Control Circuit...
I have a coleman evcon furnace that wont work. The electrical box green light is not on at all so it cannot pinpoint what the error is. Any thoughts?
Hi, I would just make sure you have power to the furnace. Check breakers or look for the power switch on the electrical box. Also, some mobile homes have a wall switch that cuts power to the furnace.
Jan 16, 2010 | Coleman Propane Forced Air Heater...
I JUST BOUGHT A USED COLEMAN EVCON FURNACE MODEL #BGU09516 AND I NEED TO KNOW HOW TO VENT IT. PLEASE HELP, THANKS
It should have a two part chimmney with a 4 inch inner exhaust section and a larger 6 inch outer section that goes over the flange on the top of the furnace. If your existing chimmney does not have this you may have to buy a chimmney kit for a mobile home application.
Dec 11, 2009 | Coleman Propane Forced Air Heater...
My furnance is acting up you turn it on it clicks on then lights the flame gets big then seconds later the flames go out and the blower kicks on what could be the problem ive had several people look at it...
If the fan takes too long to come on, the high temp limit may be opening. Could be a defective limit, hard to say without more info. Another possibility is a mis-adjusted heat anticipator. A normal setting would be around .45 amp. The heat anticipator is inside the cover of the thermostat (older, analog style). Good luck.
Nov 28, 2009 | Tools & Hardware - Others
Heating & Cooling Logo
174 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
