SOURCE: Drop and Broadcast Spreaders comparison
There are two common types of lawn spreader: drop or broadcast. The drop spreader is a familiar sight at garden centers and hardware stores. If you are a homeowner with less than 5,000 sq.ft. of lawn area, an inexpensive drop spreader may be all you need. Drop spreaders tend to be more manueverable in tight, awkward spaces and are relatively easy to use. Broadcast spreaders throw the material out in a wider swath, sometimes as wide as 8'. If you have a large area to cover, they can make short work of it. They are, however, a little trickier to use, since you need to keep up a steady walking speed (usually 3 mph) and you need to be moving when you activate the spreader. It's also harder to get a clean edge, although some broadcast spreaders come with side deflectors, which let you get close to side-walks, beds and driveways without spreading material on these adjacent areas. There are also small, hand-held broadcast spreaders suitable for smaller areas.
SOURCE: Need to replace a headlight assembly for a 2006 Subaru Outback.
No, you just remove the radiator grill and the side marker light and the headlight housing bolts and it comes out. Not a real hard job and is Real straight forward. Good luck and have a good day.
SOURCE: Earthway broadcast spreader C22HD conversion tables
Earthway is located in Bristol Indiana. The last contact number I have for them is (218) 848-7491 - according to the product information I recieved with my Broadcast spreader Model 2000B.
SOURCE: lost agitater for my Scotts Spreader
I replaced mine with a clip-in cotter key, the kind they use for farm implements to keep a pin in place. I bought a stainless steel one at Lowe's for ~$1. Works at least as good as what I had.
Best regards, --W/D--
SOURCE: I have a Scotts Accugreen 3000 Drop Spreader. How
I found drop-rate tables at http://www.vigoro.com/ProductCategories/WeedInsectControl/SummerFertilizer/ProductDetails/Spreader+Settings.htm and http://www.bayeradvanced.com/media/productlabel/502840A_label.pdf. I don't know how accurate they are, but they are consistent with one another so I'm using them :)
