Question about SanDisk Sansa MP3 Player
Mp3 player wont come on/computer won't recognize it
When i push the power button on my mp3 player the sandisk logo flashes on and then turns completely off sometimes the logo won't even come on at all. I can't tell if its charging anymore when its plugged into the computer and now the computer wont recognize it at all.
  • 728 Answers
First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
Posted on Nov 26, 2008
Sansa SanDisk is frozen ''on''
the software files of your player is corrupt.
you need to flash if for your player to work well again.
Best regards
Feb 10, 2010 | Audio Players & Recorders
My sandisk sansa wont charge or turn on after plugging in to charge
Does the computer recognize it at all? These mp3 players have a problem with the power button which you push up to turn on,,,, the switch some times become dislogged and require the consumer to either open it or replace it... you can try to reset the device by holding the power button in on position for 10-20 seconds
Jan 18, 2010 | SanDisk Sansa Clip MP3 Player
SanDisk sansa clip mp3player 1gb
press hold the home logo for 15 sec or power for 15 sec.
Jul 28, 2009 | SanDisk Sansa Clip MP3 Player
Won't come on
Your device battery might be defective..since you said the device is not charging when you connected to the computer..Ill strongly recommend that you call sandisk to see if they can set up an RMA for you...I hope that helps..
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Sep 25, 2008 | SanDisk Sansa MP3 Player
Sansa c250 wont boot up
The screen of the device turns on and the monster logo appears but it won't go to the menu anymore. It just stays on that screen
Sep 20, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Help me
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 27, 2008 | SanDisk Sansa MP3 Player
Help my mp3
i just turned off the mp3 then switched the position to "hold" then hooked it up to the computer turned the mp3 back on then pressed and holded the center button until the connection signal came on.
Apr 01, 2008 | SanDisk Sansa Clip MP3 Player
Sandisk sansa e250 only sandisk logo on powerup
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. http://sandisk.com/assets/file/downloads/firmware/e200fw01.00.12.exe You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Again, select format when prompted. Best of Luck.
Sep 10, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa MP3 Player Logo
82 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
