Question about Sony Handycam DCR-TRV240 Digital Camcorder
Sondy Camcorder DCR-TRV240 rubber roller loose in tape door
Door would not open right away to remove tape. When it finally did, a small rubber roller came out with the tape. I wondered if anyone had a pic of the inside of the camera so I would know where it went and how it connnected.
  • Anonymous Dec 26, 2008
    I had the same problem and fixed it by placeing the roller into its place. In contrary to what one of the responses claimed, this is totally fixable. The only thing is that you have to find something to replace the white pin that may have been lost. This pin keeps the roller in place,
  • Anonymous Jan 11, 2009
    The tape door would not open on my DCR-TRV 240. Please help.
    Harvinder
  • 10,594 Answers
See below picture and find location of small rubber roller.
Posted on Sep 25, 2008
  • 4,234 Answers
If a rubber roller came out and it is about 1/4" in diameter, that is the pinch roller and it can not be re-inserted without replacing the assembly that contains it. This is not a really expensive part, but getting to it and actually replacing it requires dis-assembly of the camera. This should not be attempted by anyone without experience. I'll look up the part number and cost and post it here.
Dan
I want free driver dcr trv240 sony digital 8
Are you looking for Picture Motion Browser software or some thing else for DCR-TRV240 camcorder?
Let me know to help you out.
Thanks.
Jan 28, 2011 | Sony Handycam DCR-TRV240 Digital Camcorder
Tape loading mechanism jammed
Hi...Tape jam inside your Camcorder ...fi you look careful on the side of the door tray look for a little hole it release manually the door but carefully remove the tape.. it possible the tape is unroll around the mecanism see if you cant release the pinch roller inside it a little black roiling rubber,it holding the ribbon tape
Oct 18, 2010 | Sony HVR-Z1 Mini DV Digital Camcorder
Cassette deck will not open
It could be three things: 1) This can occur for when the image reading head of the camera is dirty and dusty, and the rubber rollers that drive the tape get contaminated as well. Either can result in the tape itself becoming caught on a rubber roller, (it wraps around the roller 10 or so times because the roller is driven by a motor) until the tape rolls expand the rollers outer diameter until it jams, and then jams the opening lever, or mechanism.
Fixing is difficult, as access to the (usually 2) screws that connect the cassette holder to the opening mechanism may only be accessible when the door is open. Look under stickers or plugs on the front of the door, and if the screws are there, carefully remove the door and unwind the jammed tape. Your cassette will play again after you clean the rollers and heads with a suitable cleaning kit from the supplier, but there will be image damage when the crumpled part of the tape gets played.
Be aware that forcing the door will usually snap the tape
which would then require re-splicing back together, and
it can also damage the heads and roller, but sometimes sacrificing the tape and taking this risk may be the only option.
Possibility 2) The internal 'door release clip' may have bent, broken or snapped a spring. Try toggling the 'open' button (if it is a mechanical buttonl) whilst gently prising open the cassette door with a thin knife. 3) If all buttons are electronic press buttons, try fresh batteries.
Failing all the above, consider a full service from your service depot or store.
Apr 07, 2010 | Canon MV600i Mini DV Digital Camcorder
I have a sony dcr v240. A black rubber roller
well this has been sitting for some time now. but the solution would be wd40! well the straw off of it really, put your roller on and then cut a peice the straw sometimes a can of air staw works to and carefully slide it on.
Jan 15, 2010 | Sony Handycam DCR-TRV240 Digital Camcorder
My sony handycam dcr-hc26 door won't close. error C:32:11
Remove battery/ power source from camcorder for minute, reattach battery/ power source and close the tape door.
If that does not solve problem then I'm afraid, tape mechanism got defective and will be replaced.
Let me know if you need tape mechanism part number info.
Thanks.
Dec 09, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
I have a tape in my Sony dcr-trv 350. It will not eject out for me. Door will open but tape will not come out. I can still record on my tape. How can I get this tape out? I don't want to loose what I have...
the camera has been dropped
or pressed by a heavy object or person
open the door
put down on the tape
move back and forth with significant pressure
caring not to destroy the eject lock mechanism
do it several times
I had the same problem with my sony
Nov 03, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
My sony dcr trv240 will not eject the tape
I'm having the same dang problem... error C32:11. Any suggested repairs???
Jul 03, 2009 | Sony Handycam DCR-TRV240 Digital Camcorder
Missing piece, camera will not turn tape
the pinch roller goes here:
you are missing the snap spring too, which is used to lock the pinch roller.
May 21, 2009 | Sony Handycam DCR-TRV240 Digital Camcorder
My camcorder tape door won't close
Try removing the battery for a few seconds, and then re-inserting. This seems to reset something on my DCR-TRV20, and it starts closing properly.
Jun 15, 2008 | Sony Handycam DCR-HC48 Mini DV Digital...
Video camera displaying Error code C:31:23
I have been fighting the same problem. I just now picked up the camera and a small rubber roller fell out of the tape door area. I was not sure where it came from but looking closer there are 4 small rods sticking up on the right side inside the area where the tape is located. It looked like this was where the roller went so I placed it on the center rod and replaced the tape. This solved the problem and I am now able to view and recored as before. There most likely is a part that has either fell or broken off or is loose inside the tape area.
Feb 17, 2008 | Sony Handycam DCR-TRV740 Digital Camcorder
Sony Handycam DCR-TRV240 Digital Camcorder Logo
664 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
