Question about LaCie Computers & Internet
LaCie 1TB USB Hard drive no longer recognized on my Mac G5. The blue light flashes and makes a strange beeping noise, eventually the noise stops and light glows steady. But, still not recognized.
  • 3 more comments
  • chrisprof Sep 25, 2008
    I already tried moving the drive to another Mac computer. Same problem. So, it must be the drive.
    I tried the drive on a different Mac computer, same problem. So it must be the drive.
    Drive is about 2 years old; out of warranty.
    Removing drive from the case and placing it in the computer sounds like brain surgery to me! Of course, I'm getting pretty desperate. Can you give me any tips for doing this? I'd hate to kill the patient during surgery! My first patient, I might add....
    I think I got all the help that is possible without actually getting the hard drive tested. And a video from Ekse on how to remove the hard drive is forthcoming... I'll let you know how the surgery goes!!
  • 6,487 Answers
If you already tried connecting the hard drive to another computer and still the same, you can also try to put the hard drive to a different hard drive enclosure to make sure its not a problem with it, but if still the same the last thing to do is to take the hard drive out of the enclosure and put it inside the computer and hopefully it will be detected...
Hope that helps..............
Posted on Sep 25, 2008
  • Mark Gil
    Mark Gil Sep 25, 2008
    First thing to do is to unscrew the enclosure so you can take the hard drive out from it, then after that you can put it inside your computer and if its detected by the computer that will be good so you can still recover the files inside it also you will have a chance to format the drive.....
  • 4,472 Answers
How long have you owned the drive once we know if it is under warranty I can give you your best options moving forward. Once I have more information I can assist you further.
Thanks,
Lee
  • 5 more comments
  • Lee A.
    Lee A. Sep 25, 2008
    It is likely the drive. Do you have information that you need to get off of it?
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 25, 2008
    It is still likely worth it to have the drive serviced, as 1TB drives have only become more common since then and should still be less then replacement.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 25, 2008
    Are you against trying to have it fixed? Do you have critical data on the drive. I do not recommend the average consumer to do things like that because most times it leads to more damage. I can assist you in finding an authorized service center. Please take a moment and accept and rate my solution if you found it helpful and I can assist you further.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 25, 2008
    https://www.lacie.com/mystuff/login.htm?...
    contact technical support and inquire about getting it serviced, they should also be able to provide you with an estimate. You can also take it to your local geek squad or your local comparable shop and they can take it out and test it for you but also make sure to get an estimate or total before hand on that as well. If you still need assistance let me know.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 25, 2008
  • Lee A.
    Lee A. Sep 25, 2008
    http://www.ehow.com/how_2098180_external...
    Its actually quite easy. Hope you will reconsider the rating and give it to me but either way good luck,
    Lee
  • Lee A.
    Lee A. Sep 25, 2008
    http://www.associatedcontent.com/video/3...
    and also here is a video. I don't blackmail you into accepting my solution. I give you the best solution and only ask you rate it accordingly. if you still need assistance let me know.
    Thanks,
    Lee
  • LaCie Master
  • 13,433 Answers
Please try the drive on another computer to norrow the problem down to the pc or the usb device.
  • 4 more comments
  • Ekse Sep 25, 2008
    Theres not much you can do if the usb harddrive converter is broken, best to take it in for warranty repair / replacement, or you can take it to a computer repair shop for it to get tested, I suspect the harddrive itself might still work fine, if the usb converter in the middle of broken.
    This requires testing.
  • Ekse Sep 25, 2008
    I could make you a video in few hours of how exactly do it. but if you want me to put in all that effort, you will need to accept my solution. I will make the video, if I don't make it and post it on this page you can file in for a refund.
  • Ekse Sep 25, 2008
    I will get to work, I'l post it on this page in a few hours.
  • Ekse Sep 25, 2008
    If you post me more detailed information about your usb hdd, Im sure I could find you some helpful information on how to take your spesific case apart.
    I don't own the same drive you got, so this will be general help on the subject.
    The video is being processed by youtube and Il post it here soon.
  • Ekse Sep 25, 2008
    Here we go
    I also happened to find another video on youtube, I didn't make this extra video so I can't attach it here but if you want to view it, here you go
    http://www.youtube.com/watch?v=kqnnUm9Am...
    Its about how to build a external hard drive, so its going in the other direction you want to go but, it might be helpful.
    And as I said in the video, your mac might not have the connectors or room required for the hard drive, it might be best to get a pc, or take the hdd to someone for testing. if the harddrive itself works fine alone, connected to a computer. then the usb case is broken and would need to be replaced. Its a common problem with usb cases that the power source fails, and when the powersource fails the harddrive doesn't get enought power to work properly. so you just might need to get a new power adapter for it. thats happened a few times for me.
    If you have any questions or if you need anything else, let me know and I'l see what I can do.
    Thanks again,
    Ekse
  • Ekse Sep 25, 2008
    and as the case is 2 years old, I think the poweradapter is out of juice. So getting the power adapter tested or another power adapter might fix the issue easyly.
My mac laptop suddenly won't recognize it
you may need to swap the usb port it's plugged in
Jun 11, 2012 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My MAC G5 no longer recognizes my harddrive. Blue light flashes, light clicking noise.
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Nov 29, 2010 | LaCie (301146U) 320 GB FireWire 400...
I just bought my LaCie 301888KUA 1TB Starck Desktop USB2.0. I was following set up directions in the manual until I realized that my Mac OS X (version 10.5.8) is not recognizing the hard drive . It's not...
the problem is that your lacie drive operates using the NTFS (New Technology File System) under USB which is the standard file system of Windows. Apple mac is not interopable with native NTFS therefore you need to install a read-write NTFS file-system driver on your mac if you wish to use it via the USB connection.
an excellent free mac NTFS driver can be found here-
http://mac.softpedia.com/get/System-Utilities/NTFS-3G.shtml
download and install the software then restart your mac.
//javaftper
Jul 31, 2010 | LaCie 301888KUA 1TB Starck Desktop 1 TB...
My lacie hard disk 1tb all of a sudden isnt
Just contact www.lacie.com great support. their answer for my drive was to reboot the drive. For me it worked.
Follow the procedure below to reset the Network Space to factory defaults:
  1. Move the power switch to the OFF position. Wait for the drive to shut down.
  2. Turn ON the drive.
  3. Within about 3 seconds, flip the switch OFF and On several times.
  4. Immediately turn it ON
If the light flashes quickly, the unit is resetting itself. Attempt to connect to the drive again after about 1 minute using the default username and password (by default, they are both admin.)
Jan 27, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
My LaCie 500GB Quadra spins and clicks. Have tried (Mac) DiskWarrior and Disk Utility, but the drive ignores them and spins, clicks, and the blue light flashes
If you can hear clicking then I am afraid there is a serious problem with the hard drive.
The noise you can hear is usually known as "the click of death" when referring to hard drives.
Make sure you use ONLY the cable that came with it or a SHORTER one.
Dont connect via a USB hub
Make sure you only user the power supply that CAME WITH IT.
Most common causes are that the drive unit was dropped or mishandled or just plain old age
There is no known cure unless the data is mission critical
In which case you could sent it to a data recovery specialist but this is usually VERY expensive.
If you are advised to place it in a freezer or anything similar then that is up to you
but my advise would be to run from the person who may give this advise.
This is very old fashioned advice and meant for very old types of drives that used to get very hot.
If it a drive that was / is from an external enclosure then you could still use the enclosure and just place a new hard drive in there.
Another way to test it it to remove it from the enclosure and connect it directly to a PC with a suitable interface eg. SATA or IDE.
Sep 11, 2009 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
My lacie mounts on the g5 but when i click it, it doesn't open.
It would be a good idea to look at the Mac system log so from a v bad memory do...click Apple (top laft hand corner) then about this Mac then System Profiler then Logs and take a look and see what errors you are getting. If this doesnt give you any clues my advice with external disk problems is where possible to remove the disk from the enclosure and install it in the Mac. if you can, THis will eliminate the USB cable, interface, and box. See if it mounts then. If it does run disk utility to double check it but get your data off first onto the Mac. Hope this helps....Mark
Aug 21, 2009 | LaCie Big Disk External USB 2.0 1TB Hard...
My mac is not recognizing my Lacie 1 TB, it started a week ago. It used to work fine for 2 months or so. I got this Lacie less than 3 months ago. I have fully stored my all my music there, but now I can t...
I had the same issue -- turned out that power supply was going bad so the drive wouldn't spin up all the way; this could explain the strange noises you're hearing. I put in a support ticket with LaCie at their website and they sent me a new power supply at no charge (I was within the warranty period, I think).
Mar 08, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie 1TB External Drive flashing blue light, not being found
Hey
I know this arent a solution
Tho I have the same problem atm, this is just a networkstorage device, and this is a newly 1.
Feb 04, 2009 | LaCie d2 Extreme 250GB External with...
LaCie d2 Quadra 500 GB HD dropped, now makes strange chime/alarm
Modern hard drive motors can easily become seized after an impact. The only DIY solution I am aware of is the use of a heat gun over the back of the drive motor. The build up of heat within the motor is sometimes enough to free it.
If the drive was running the problem may be due to a phenomenon known as "sticktion" where the drive head is actually stuck to the disc surface. If this is true then you need a data recovery company.
Nov 19, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Computers & Internet Logo
115 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
