Question about Singer 7462 Mechanical Sewing Machine
PFAFF 362 Sewing Machine: The shift lever to move from straight stitch to zigzag stitch is stuck in zigzag mode and will not release to go back into the straight stitch. The machine sat unused for a few years and the lubricant has dried up so that the internal part does not release or change positions.
    Problem Solver:
  • 10 Answers
Remove the top cover (grasp and lift straight up), spray with "Tri-Flow, liberally inside. Pay attention to the right 1/2 and behind the front dials.
In Front, each dial has a small square opening on the side, use the tube included with the "Tri-flow" to squirt lube inside them. DO NOT use WD-40.
Run the machine daily for 5-10 minutes (set the dial "C" [top front that goes up to 8] to 0 also set the dial on top of the case to 0. Move the Zig-Zag lever (upper right) from 0 to 4 and back again. Respray with Tri-flow. After a couple of days, if it is still stuck place a hair-dryer or light nearby to warm it up to skin temp.
Between the temp and the oil, it should begin working.
Break a Leg!
Posted on Jan 08, 2010
I just fixed this on my pfaff 230-the problem is the needle position dial-the middle dial with the chrome lever on the right-has froze up .
remove the dial-it doesn't come off by the screwhead in the middle of the dial ,the screw you need to loosen is the one under the wider end of the part of the dial you hold-you will need a glasses screwdriver.
once it is off ,heat the exposed shaft with a heat gun while turning the shaft back and forth with pauses for dripping 3 in 1 oil on the shaft so the heat melts the hardened grease and draws the 3 in1 in to flush out the old grease and lube the shaft.
eventually you will be able to turn the shaft easily-then when it cools off replace the plastic dial.make sure your upper dial is on "0" there is a cam on it that will push down the other end of the chrome lever.
This will work-there is no plastic in the shaft and arm assembly to melt and you don't have to dissasemble from the top-that sucks.
Posted on Feb 04, 2010
My machine is stuck on zig zag stitch and I need straight stitch
THE TOP OF YOUR MACHINE NEEDS TO BE REMOVED. A ROUND THING WITH BUMPS ON EACH SIDE IS USED FOR ZIGZAG STITCHES. A LITTLE PIECE OF METAL RUBS AGAINST IT AND CAUSES THE NEEDLE ARM TO MOVE BACK AND FORTH IN THE SAME METHOD THE BUMPS ARE LAID OUT. AS YOU MOVE YOUR ADJUSTMENT KNOB THE LITTLE PIECE OF METAL HAS TO BE MOVED TO A POINT THAT IS SMOOTH SO THE NEEDLE WON'T MOVE IN ZIGZAG FIGURES. THIS AREA OF THE MACHINE CAN BE CLEANED WITH A CUE TIP VERY WELL. AFTERWARDS LIGHTLY OIL ALL METAL TO METAL PARTS. SOMETIMES THE PART THAT MOVES AGAINST THIS WHEEL HAS TO BE ADJUSTED. THERE ARE SCREWS ON IT THAT WILL ADJUST IT SO THE SEWING STITCH TYPES WILL MATCH THE STITCH TYPES CHOSEN.
Oct 05, 2014 | Husqvarna Husky 145
Can I go from straight stitches to zigzag stiches and back in the same seam?
Hi Susie,
I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
Hope this helps.
May 14, 2014 | Singer 3116 Simple
Singer sewing machine needle moving to the side after it's in the fabric for a zigzag stitch
If you can grab the hand wheel and move it right and left, then it probably needs a plastic collar that goes next to the left upper shaft bushing.
If not then the cam timing needs to be adjusted.
Mar 13, 2014 | Kenmore 15516 Mechanical Sewing Machine
Pfaff 360 I can't seem to get a true straight stitch when dialed to that mode, about every 3rd st. looks as if it is zigzag-then straight again.
On a mechanical machine the top camstack may be slightly out of line with the selector finger a simple shop adjustment will cure it
Oct 27, 2013 | Sewing Machines
Can this machine do zigzags?
The Sew Dlite 11401 shown on Amazon here, http://www.amazon.com/DLite-Supreme-Portable-Sewing-Machine/dp/B0006BDG8Q , does not do zigzags. It only does straight stitches. There are similar models that have a stitch width lever. Those do zigzag stitches and straight stitch when in the zero width mode.
I hope this helps.
Aug 25, 2013 | Sew D'Lite 11401 Mechanical Sewing Machine
Pfaff 362 won't zig zag
yes, it's very possible that the control/knob needs to be replaced
or the cam or gear that works the zigzag
Jun 03, 2012 | PfaFF Sewing Machines
Won't stop zigzagging
At some time your machine was probably stored in the zigzag position. When left set this way they will lock themselves in. To fix open the top of the machine & using sewing machine oil (not 3 in 1 as that will lock up the machine) oil every part that moves or looks like it should move. After letting it set a while you should be able to work it back to straight stitch setting. I have had some stuck so bad this way I've had to use T-fal to break them loose, but if you do be sure to clean it out good and oil with machine oil afterwards.
May 29, 2010 | Singer Featherweight 132Q Mechanical...
I can't get my Pfaff 230a to straight stitch!
The stitch selector switch is most likely the culprit. Have you tried operating the machine upside down?
Jan 17, 2010 | PfaFF Sewing Machines
Needle stuck in the material while sewing a straight stitch.
See if you can release the bobbin from the case.
Dec 30, 2009 | PfaFF Sewing Machines
Singer 7462 Mechanical Sewing Machine Logo
1,407 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
