Question about KitchenAid K45SS Classic Stand Mixer
I received a mixer without instructions. It came with two different beaters. Which does what?
Thanks, I had the wrong make. It is a Sunbeam mixmaster. I am still stuck.
Posted on Sep 26, 2008
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Dec 25, 2015 | KitchenAid K5SS Heavy Duty Commercial...
How do I keep beaters in mixer without them falling out?
Each beater may be shaped differently and only will click into its appointed port. There may be a picture on the mixer showing which side to put each beater.
May 12, 2014 | Black & Decker MX55 PowerPro Hand Mixer
How do you place beaters in mixer without them falling out?
I can't find a manual for the MX55 online, Suzanne, but looking at the picture of it I found on Amazon and based on the manuals for other B&D models, it looks like you should have two slightly different beaters: one with a collar and one without and it's very important that each beater go into the correct hole. The one with the collar should go into the left hole (looking at the bottom with the holes at the top) and the one without a collar into the right. The other manuals say "insert each beater and, if necessary, turn it slightly until it locks into place." I hope this helps. Good luck!
Kitchen aid khm3wh beaters will not stay in mixer
I fixed mine (my wife's). Kitchenaid 3-Speed Hand Mixer KHM3WH. Here's how I did it.
This is a pretty old mixer. My wife bought it at a thrift store for $1. She brought it home, we found the beaters and whisk beaters on eBay. Paid $34.00 for both sets of beaters, but when we received them we found they would not stay in the mixer. Oh we also bought the alternative/replacement beaters from Sears, parts online. I don't think those will work with my fix. However with some $0.92 rubber washers from Lowe's and a heavy duty paperclip I fixed the mixer, and it works flawlessly. Maybe some stainless steel wire would be a better, more permanent fix.
Apr 30, 2012 | KitchenAid KHM3 Classic Hand Mixer
Can you lengthen the beater by loosing a screw?
Hi, KLOEHR, your beater will not lengthen by losing a screw. However, if you lost your Beater to Bowl Clearance adjustment screw, then it might appear that your beater had ‘grown’ because now the beater may be touching the bottom of your mixing bowl, where previously it had not. Simply said, the beater didn’t grow the mixer head drooped.
You don’t say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM5PS)and select the last file listed that appear under Owners Manuals: KSM5PSWW0.pdf (2930.74 KB) and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now you’ll need
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 10, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Mixer component vibrates; seems to sit too low; beaters rub against bowl; alignment seems wrong
Hi, LAHR, by the symptoms you describe it appears that it’s time to adjust your mixer’s "Beater to Bowl Clearance" adjustment screw, which should be a pretty easy to do by yourself.
The instructions for adjusting your beater to bowl clearance are located in your Owners Manual. If you don’t have the original manual you can easily download a PDF version of it from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM150 and select the file listed for your model that appears under Owners Manuals (66) KSM150PSER1.pdf (732.33 KB) and save that file to your PC. Turn to Page 14 and you will find the instructions for adjusting the mixer head height.
But to save you some time, I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
I hope this helps! – Howard, Burke, VA
Dec 09, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Have a kitchenaid artesian mixer need to adjust beater depth-it is scraping the bottom of the bowl. Model #KSM150PSEr 325 watts
Hi KELLYSERMAN, this should be pretty easy to do by yourself the instructions for adjusting your beater to bowl clearance is in your Owners Manual. I you don’t have the original manual you can easily download a PDF version of your Owners Manual from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM150 and select the file listed for your model that appears under Owners Manuals (66): KSM150PSER1 (732.33KB) and save that file to your PC. Turn to Page 14 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
Dec 07, 2009 | KitchenAid KSM150PS Artisan Series Stand...
I need replacement beaters for an old GE hand mixer.
I bought an old GM mixer no. 30M47 with no beaters yesterday at the Salvation Army store. The beaters I have for a newish (ugly) GE hand held beater fit perfectly. I suggest taking your old beater to a store that sells new GE handheld beaters and seeing if the new beaters fit. If anyone reads this and wants me to look up the number of the new ugly beater for them, please say so before I take it to the Salvation Army.. : )
Oct 21, 2009 | Black & Decker MX55 PowerPro Hand Mixer
Instructions for Sunbeam 2350 Heritage Series Mixmaster
Go to sunbeam.com, select "kitchen", then select "customer service", then "instruction manual", then "stand mixers", scroll down to model #
Nov 23, 2008 | Sunbeam 2350 Heritage Series Mixer
KitchenAid K45SS Classic Stand Mixer Logo
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
