Convergence correction ic's
Can a skilled woodworker re-solder these or am i going to blow up my tv? Also how much should i pay to have a technician solve for me? Are the parts expensive? Does it matter what kind of parts (brand names) i use?
  • 790 Answers
If are no experience in electronics.. do not attemp to resolder the board or what else in the unit... Find a qualified technician in your are! or go to this site and find repair man near you! Click here
Thanks...
likha
Posted on Sep 26, 2008
I have a 60 inch rca rear projection tv and it looks like the screen is bowed can i fix this myself or will i have to pay someone to do it
Ur tv have a problems known as a convergence picture problems it is dead.The tv convergence board it is dead and must have to repair like replacing 2 STK convegence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.Yes,u can fix it and do the works by ur self.But u have to have all the requirement tools,have the skills and the know how to do the work on a circuit board and can do basic soldering work like take out ICS chips and replaces ICS chips on a soldering circuit board and also can take out some small dead components parts and replaces it with doing a soldering works.U can do that?Yes?Tries websites like Tvrpairworld.com,Tvrepairkits.com to buy a whole complete convergence kit that belong to ur DLP tv make and mode about $70-$75 also the kit will have a DVD tutoring disc.As i said u have all tools and the skills to work on a cucuit board and changes ICS and resistors u can do the job ur self.Or tvs shops will cost u like $300-350 for parts and labors.
Aug 30, 2011 | Sony KP-51WS500 51" Rear Projection...
My colors separate as you go from right to left across the view screen so that at the left side of the screen 3 overlapping images appear, each one is one of the RGB colors. Can this be fixed by me or do I...
U have tools like a soldering iron,a desoldering pump or a roll of desoldering braids and also can do and have pretty good soldering skills,because it involving replacing convergence ICS.The tv have dead convergence board must replace 2 STK convergence ICS and some or all it resistors too.To fix the convergence board,to solved the picture convergence problems.As i said u have all the tools have pretty good soldering skills,tries websites like Tvrepairworld.com,Tvrepairkit.com to buy a convergence kit belong ur tv model and make to fix it ur self.Or the shop,will cost like $300-350 for parts and labors.
Feb 05, 2011 | Sony KP-65WS500 65" Rear Projection...
I have a convergence problem- looking for wiring diag. and cheap parts or hh gregg here i come
The Sony type 1 convergence repair kit available from www.tvrepairworld.com is the correct kit for your model. The kit contains the Parts and the CD with instructions and the CD also has the service manual for your model also.
May 28, 2010 | Sony KP-51WS510 51" Rear Projection...
I am having a problem with the RED going out of sink with the other colors. Looks almost 3D. What causes this
Ur convergence is dead.Must replaced 2 convergence ICS,and some or all it resistors.U know to solders?Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 10, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Can't correct my red blue convergence manually or by using factory preset...the unit is 7 years old, is my picture tube bad?
You have bad convergence ICs. There are 2 ICs in the convergence circuit, one is for the Blue the other is for the Red. You can buy 2 ICs for under $40.00. Replacing these ICs require soldering and desoldering skills. Sometime, the resistors in the convergence circuit go bad also. Be very careful, there is a very high voltage in a CRT projection TV the voltage is over 30,000 volts.
Best of Luck
Sabre
Feb 23, 2010 | Philips 60PP9202 60" Rear Projection...
Red convergence out
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} The best advice I can tell you at this point is to go to tvrepairkits.com and order the complete convergence kit for your model of TV set, no need to search and order multiple parts from different sources and pay multiple shipping fees! The kit comes with original Sanyo STK IC’S , not those cheap aftermarket or china made IC’S full pictorial directions, the thermal paste, resistors, the correct Pico fuses, AND free live on-Line tech assistance in case you run into a problem with the repair. They ship out 2 to 3 day Priority mail, the next day in most cases GOOD LUCK!!!
Larry Dillon, senior tech/tvrepairkits.com
Jul 05, 2009 | Samsung HCL5515W 55" Rear Projection...
Mitsubishi 1080 hd ws-65809 wont power up
This issue is almost always caused by a faulty Convergence IC inside your TV. These chips heat up and can become damaged over time. The most common cause I have seen for the picture distortion is the heat of the Convergence IC weakening the solder connection to the TV circuit board. If you look on various messages board you will see people rigging wooden dowels and other items to apply pressure to the chips in order to correct their picture issue. This works because when the solder joint is weakened the chip becomes loose and vibrations or pressure will cause it to work or not work correctly. Aside from all that information the correct fix is to have the IC chips replaces on your TV.
The solutions for this issue are as follows:
1. located a tv repair shop that will replace the parts for you. I had the same issue with my 65" Tv and the quote was $350 for the labor and parts.
2. You can ordered the IC replacements yourself online by going to google and looking up a reseller of the STK392-110 Convergence IC that is inside your model TV. You will need 2 of them and they cost around $6 each. If you have the soldering skills to remove the old chips and install the new ones this is by far the most cost effective route. It is a fairly simple process and guides can be found online.
Mar 17, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Toshiba big screen The tv is like double exposed . I have a toshiba big screen tv and I have double images in red and green. How do I fix this problem?
This is likely your convergence ICs(chips). If you can bump it then the ICs (chips) are still ok, it just needs resoldering.
my company charges $300-400 for the full repair (replacing ICs, full realignment plus cleaning)
if you can find a company that will resolder for you, it could cost $100-200 maybe. if you are a handy person with soldering skills, you could repair yourself. i can instruct if needed, but convergence IC soldering requires decent soldering skills. you will find the ICs on the largest heatsink in the tv. the part number starts with STK. if you replace them, check the resistors in front of them and replace accordingly. most toshiba will blow up to 3 fuses (f850, f851, f852)
Dec 08, 2008 | Televison & Video
Mitsubishi Rear Projection 65" tv picture becomes blurred bouncing right to left and color is red & green. TV is 8 years old approx. Any suggestions. Have not had any problems prevoiusly. First it woudl...
Sounds like possible solder connections on the convergence ICs. If so, you will see the red, green, and blue not lining up on ever input and even the mits menu. If you can bump it to correct, its just a solder connection, but if its out all the time then the ICs need replaced. This is a difficult repair only recommended for skilled technicians (40 solder connections + possible re-alignment needed)
Dec 03, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
