SOURCE: Unlockint the rca truflat
just had the same problem... found the old RCA remote in my house... put new batteries in it...used RCA remote.... hit menu... arrow down to preferences and hit "ok" on remote.....use arrow again to go down to FPA lock and hit ok to turn it off, hope this helps, hit menu again to remove menu from your screen
Brenda
SOURCE: rca 14" truflat
really depends on the model. I've got a 2005 26" RCA truflat that has both digital and analog ota tuners--I can pick up off of rabbit ears OTA broadcasts, as well as via coax cable (cox cable) any of the unencrypted clear digital channels (QAM). Just can't handle the encrypted channels. If there are multiple coax inputs, check their labels--if labeled digital, likely that you've got a QAM digital tuner. Also, in the menuing system, channel scan--does it identify signal type as selectable digital/analog?
The surefire, get the model number, goto RCA.com website, download the user manual.
SOURCE: My DVD player is hooked up to my RCA truflat but i
There should be a button on the front of the TV that says TV/VIDEO or INPUT. Turn on the DVD player and put a DVD in it and press play. Press the TV/VIDEO button until the picture is present.
Good Luck....
SOURCE: I accidentaly turned the FPA
Hello
It will be very difficult to unlock RCA TVs without its orginal remote control handset. Anyway just try this, This is the actual proceedings to unlock the RCA TV with its original remote. If you fail to do this with your present universal remote control, just buy an new original one from RCA Authorised Service Center at tyour town, or just borrow it from any of your friends or relatives; just to unlock your set. After unlock, you can use the universal remote control. Just follow the proceedings given below. One amoung them must unlock your RCA TV.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
