Question about Samsung DVD-HR720 DVD Recorder
Faulty power supply board
Hi, I have just had my recorder checked out as all displays failed while in stand-by. I was told the power supply board had a fault, and was no longer available. Can you suggest any sites for a replacement?
  • david182 Oct 03, 2008
    Hi, can you tell me what component it was you found to be faulty on the power supply board, it might be worth trying a replacement component rather than scrapping the whole machine.
I have exactly the same problem. Indeed the power supply was defect. I have repaired it. Now the display is working but it is still not working : It displays LOADING... and that's all. Probably the controller card (the one with the LSI LOGIC chip) is also defect. It is impossible to repair, it has to be replaced.
I think this recorder is not 'CE'.
Posted on Oct 01, 2008
After turn on, why is screen filled with horizontal lines for approximately 30 minutes before clearing?
This sounds like Power Supply Board Capacitors failing and allowing an AC ripple on the T-con board LT supply which is clearing as the components reach optimum operating temperature, but it could be the early signs of t-con board failure. You could try to narrow the fault to one board or the other with the use of a good freezer spray, and then go for replacing that board. Have a look at the many board retailers prices to see if this approach is best for you.
http://www.shopjimmy.com TV Parts Universal TV Stands DLP Chips ShopJimmy
Dec 24, 2015 | Televison & Video
What makes the HISENSE LCD (Model LCD 42W58P1) power supply failed to produce output voltage goes to the main pc board?
First of all the power supply makes 'Stand By 5 or 3.5V which goes to main board. When we give power on command to the TV the main board sends 'stand by or Power ON' command to the power board which then makes other necessary voltage for the main board as well as other sections. If the power board does not receive 'Power On' command from main board, it will not produce the necessary voltages to operate the TV set.
May 20, 2015 | Hisense Televison & Video
Power 48v check
Hi
Either the power supply is
not generating a proper 48
Volts or the controller board
is not detecting a 48 Volt
output from the power
supply board.
1. Make sure the power supply
board is correctly connected to
the controller board.
2. Power on the printer. If the
message appears, do the power
supply operational check (page
195). If the power supply fails the
check, replace it. If it passes the
check, go to the next step.
3. Power on the printer. If the
message appears, replace the
controller board. Record the
message and return it with the
defective board.
Aug 11, 2014 | Printronix Matrix Office Equipment &...
Display no longer works. Receiver still works, however. What's up?
This is purely a fault in the display unit. you need to check the power supply to the display unit. Check the filament voltage and the grid voltage to the display from the display driver processor.
If absent the power supply should be checked , it can be a open fusible resistor if voltage is absent. If not the IC is defective. Check for dry joints of the display unit, the IC or the connector to the display board.
Oct 03, 2010 | Sony STR-DE197 Receiver
Power supplierd but does not start recorder no
Hello:
If the unit is competely dead, then you may of blown a fuse or the power supply has failed in the unit. If you take off the top of the unit while unpluged check the fuses near where the power cord attaches to the inside of the unit this is the power supply area, If you have indicators lit or the display is coming on then the unit may have a bad power supply or the System control board has failed. It which case its cheaper to just purchase a new unit.
Jul 14, 2010 | Panasonic DMR-E85H DVD Recorder
Failed power supply section,what is the problem?
it unfortunately could be literally one of 25 things, the Power Supply is a symptom of the actual CAUSE. You must get a service manual to perform the troubleshooting and fault isolation procedure, and even than it is still extremely hard to isolate, usually one just replaces the Mother Board, and or power supply.But it also may be the laser head, too.
Mar 19, 2010 | LG RH177 DVD Recorder/HDD Recorder
I Have a Philips LCD TV model#30PF9946D/37. Recently the picture disappeared and only sound and can change chanels too. I was told I need to repair the power supply! Can I change It my self ??? I read it's...
Oh yeah, you can most certainly change the power supply by yourself.
It's easy to locate - just follow the power cable - and easy to replace.
Only make sure to let it discharge before you operate it. 10-15 minutes disconnected from power should do.
However, there's no guarantee that the problem is in the power board.
There is a very good chance it is, in fact, not there.
There's another board which commonly fails on many plasma TVs and the effect is exactly as you describe. It's called Y-Sustain board and you can tell which one it is by looking at the side of your TV and seeing which large board has manny plastic connections that enter the display on the side.
That board often has one or two fuses on it - I'd check those first.
Nov 03, 2009 | Philips 30PF9946 30 in. HD-Ready Plasma...
DVD on light comes on for a few seconds and then shuts off
HI, this will occur when there is a power supply circuit fault that is located on the power supply board. this could be a failed capacitor or resistor of some sort.you will need to replace this damaged power board if possible to restore normal function.
It is unable to hold a proper AC current at this time.
May 31, 2009 | Cyberhome Progressive Scan DVD Recorder...
Tevion dvd recorder will not power up fuse ok.
Hi-
Have you tried changing the cables (power), try pressing on the power button longer, if all fails there might be a problem with the board or power supply.
Hope this helps
Oct 30, 2008 | Televison & Video
SONY - PFM-500A2WE 16:9 42-inch Plasma fault 22-12
According to the Sony Service Manual for the PFM-500A3WU, 12 22 means either the Plasma Panel has failed or the Power Supply has failed. 12 means "warning decrease of panel high voltage" and 22 means "warning of decrease of middle panel voltage".ve had a look on other forums and someone as narrowed the 12/22 code down to the (ic102) its only outputing 5volts its something to do with the (b+ power supply)
Feb 01, 2008 | Televison & Video
Samsung DVD-HR720 DVD Recorder Logo
223 people viewed this question
Jerry Greenberg
Jerry Greenberg
