Question about Siemens Microwave Ovens
I have a Siemens microwave (inno-wave) that we have had for 3 years. It is a HF 17055GB/02. When I try to cook something, say I set it to cook for 2 minutes, after 23 seconds it stops and reverts back to the digital display clock. It seems clear during that 23 seconds the microwave isn't heating anything. Any idea what might be wrong and whether it is fixable and at what cost. Any help would be appreciated.
  • Siemens Master
  • 9,086 Answers
I wonder if this is an inverter-based model... I ask because on Panasonic/Quasar units, a problem with the magnetron or inverter will cause this very symptom.
If so, because of the voltages and currents involved, I do not recommend that someone without experience attempt repairs on an inverter circuit.
I would contact the manufacturer at the number in your owner's manual to find the nearest authorized servicer.
Posted on Sep 27, 2008
  • onnohennis Nov 21, 2010
    Hello HammerJ,
    I am having the same problem. What is the solution?
    Thnx in advance...
    Onno
Hi I am using kenwood microwave since last6 years.but now from last one year it suddenly started make sound while not in working and now it is not heating. Plz guide what to do
Time to throw it away. Microwave ovens can be dangerous if not working correctly. Micro-waves, (The actual waves themselves) can be lethal. Unless you really know what you are doing, do not under any circumstances dismantle the machine and switch it on. The cabinet of the machine is designed as a protective box and should stop random waves escaping and cooking anything else including you own insides. Generally Microwave ovens are uneconomical to repair, for the parts and labour you can buy a new one. Buy the most powerful you can. If you buy anything that is below 1000 Watts make sure it has a turn table. Remember that the more you place in a microwave oven, the longer it takes to cook. If you have a big family and you can afford it, you might like to think about a commercial oven 1600 - 1800 watts, that can cope well with large quantities well and will cook a tin of baked beans in less than a minute.
Rgs. Bob
Feb 21, 2016 | Kenwood Microwave Ovens
Hi I have a siemens inno-wave HF17055GB Microwave and the plate turner is not turning, otherwise it seems to be working? help please
Replace the motor. The teeth in its gearbox have probably been damaged when trying to turn the plate by hand.
Aug 25, 2014 | Siemens HF17055GB Microwave Oven
Kenmore Ultra Wave microwave Model # 665.61652 Quit Working
There are fuses in the unit but why did they go bad? something else has to go bad to cause the fuse to blow, unless the fuse got old or had bad connections at the fuse holder. Can try a new fuse then run and see if it works. Just don't run it empty, just put a container of water in it to test. If it works check all connections and see if any are loose or browned like it has been hot. That's where your problem will be.
Aug 12, 2017 | Microwave Ovens
I have a Siemens microwave (inno-wave). When I try to cook something, say I set it to cook for 2 minutes, after 23 seconds it stops and reverts back to the digital display clock. It seems clear during that...
The controller is probably sensing that the magnetron is not drawing current and shutting down the timer.
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Nov 21, 2010 | Siemens Microwave Ovens
When you push cook time and a time, or just hit the auto 1,2,3,or 4 minutes, it lights up on the display like it is cooking, with the timer till finished going and everything, but it does not actually...
Highly likely your microwave has "failed".
Down inside the microwave is a part called the Magnetron. This is the part, (about the size of your fist), that makes the sound waves to cook the food.
On some models, it can fail, whilst all the other stuff works.
3 possibilities:
1) You need a fuse replaced.
2) You need a capacitor replaced (That part "starts" the magnetron) or
3) you need a new magentron.
In any regard, very often people will not opt to have it repaired, because the labor & parts can cost more than a new Microwave.
God bless your efforts.
Sep 08, 2017 | Jenn-Air JMC8127DD Microwave Oven
Moved the mirco wave, then the only buttons that work now are the time set, but it only shows 12hr and 24 hr, and will not set the time. none of the buttons will work now for the cook time. if the power...
i cant work out if its broken or not over the years i do remember seeing a sanyo microwave that would not cook untill the time was set though have not seen another since (cause its a silly idea) but try setting the time and it might work
Oct 14, 2010 | Daewoo KOR-860A Microwave Oven
Glass door for a Siemens microwave hf 879
I've the same problem. Inside glass broke while heating.
May 20, 2010 | Siemens HF87950GB Convection Microwave...
Micro wave does not work EM-Z2100GS
First you check the fuse at the out put of highvoltage of the transformer. If the fuse is ok, replace the magnetron.
Feb 28, 2008 | Sanyo EM-Z2100GS Microwave Oven
Siemens HF 87960 GB Microwave/Combo Oven
Please, Can somebody tell me where can I get one of this oven??? Thanks Andy
Dec 08, 2007 | Siemens HF87950GB Convection Microwave...
Microwave Ovens Logo
793 people viewed this question
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Steve
Gerry Harvey
Gerry Harvey
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
