Question about Panasonic TOUGHBOOK CF-18 Tablet PC
Keyboard key not active on front of computer
Does anyone know about the keys on front of the computer. There are five of these..LCD brightness, one with a keyboard, two that I dont reconize and one with a key on it. It is my interpretation that the one with the keyboard is supposed to activate a keyboard on the monitor that you can use with the stylus. Is is possible that it could be just deactivated or never activated? Is there anyway within the computer or the operating system...Microsoft XP that I can check the status or get this going?
    Top Expert:
  • Panasonic Master
  • 48,245 Answers
Keyboatd controls are found by going to control panel--keyboard --and clickong or the tabs
Posted on May 22, 2017
Some key on the keyboard are typing numbers instead of letters what should i do please?
You might have accidentally activated the "Numlock" key on your keyboard. Just press the Numlock and it should type in letters instead of numbers.
If press just the Numlock key will not work, try the combination which is CTRL and Numlock simultaneously.
Hope this helps.
Jun 17, 2011 | Tablets & eReaders
Need to disassemble
to remove the keyboard on the cf-18 keyboard you must remove the 4 screwsby the ESC, F4, F10, and PAUSE key. once removed lift the 2 covers and holding the keyboard from Function key sides lift up slowly. There are 4 sticky tapes holding the keyboard, once some of the tapes are off you can slide the keyboard up towards the LCD to remove. The connector to the keyboard can be removed by removing 3 screws from the aluminum center cover found under the keyboard
Jul 17, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Keys enter wrong characters
You have Num Lock on. Turn it off.Generally Function and End or one of those keys.
Feb 16, 2009 | Fujitsu LifeBook T4220 Tablet PC
You need to clean the keyboard. Blow it with air blower so that the paricles inside keyboard will be eliminated. If not work, then you disassemble the keyboard and clean the key one by one. afraid to do , then let the repairman do it for you or you can attach USB keyboard for the laptop.
Jan 16, 2008 | Toshiba Portege M400-S5032X Tablet PC
Display problem in Toshiba Satellite pro L20
did you try the FN and F8 key and try that see if that turns the lcd on. If not write back here and we can figure it out.
Dec 18, 2007 | Toshiba Satellite R10-S802TD Tablet PC
Key board problem
check you keyboard in Regional settings and see that it is set to a 101 type (US or Aust) otherwise key location can change,also are you talking about Shift Keys or the Up/Down, Left/Right scroll arrows, let me know, otherwise something has gone arye on the keyboard itself.
Dec 12, 2007 | Compaq tc1100 Tablet PC
Space Bar
Sounds like something's not making contact properly. I don't think you're going to have much success getting that key to work, at least on a permanent basis.
If your computer is under warranty, this merits a replacement keyboard. If it's not under warranty, replacement keyboards can be found online from parts providers or on eBay. Just make sure to get the right one for your model. You can usually install them yourself quite easily (typically three or four screws, five minutes or less). If you don't feel comfortable doing it yourself, it's a very basic repair and if a service provider sounds like he wants to charge you too much, he probably is. Keyboards run in the $30-70 range depending on your model, and I wouldn't pay too much more than $30 to have it installed. Forget places like the Geek Squad; a local shop can probably do it cheaper. I'd say altogether you're looking at $50-100 installed.
And as for your other question... I work servicing computers, and Toshiba machines are by far the worst products I've encountered. I don't recommend them to anyone. I haven't had much luck with other Toshiba electronics, but then again I haven't used them extensively either.
Hope this helps.
Nov 18, 2007 | Toshiba Portege M205-S810 Tablet PC
Volume quick key
There should be some software on your laptop to setup hot keys. You need to find it and setup the correct hot key for the volume knob again. If thats not the problem, some computers have memory resident keyboard hot key software that loads at boot-up. Check if this has been disabled if you laptop uses such software.
Aug 07, 2007 | Toshiba Tecra M7 Tablet PC
Weird keyboard problem
The problem posted by "Guest" is indicating that the "Windows" key is stuck on his system.
Dec 06, 2006 | Toshiba Satellite R15-S822 Tablet PC
Panasonic TOUGHBOOK CF-18 Tablet PC Logo
Top Panasonic Tablets & eReaders Experts
Paul Wang
Are you a Panasonic Tablet and eReader Expert? Answer questions, earn points and help others
