Question about Video Game Consoles & Games
Throttle not working correctly
After 7 months of good operation the throttle showed some problems.When you want idle and place the throttle to idle position (first "click" on the trottle path) it gives me full A/B for that spot.In addition, the throttle path is not the same with the engine's rpm.In full forward throttle position (looking at CCP Viewer) it's not at 110%rpm (full A/B) but at about 100%rpm.The funny is that when i pull the throttle all the way back(behind the first "click") instead of min rpm it gives full A/B(max rpm).I've tried to flash it but the result was the same.Any ideas? Thank you in advance.
    Problem Solver:
  • 17 Answers
Hey voyiager i understand your issue so my advice to just take back to where you got and explain to them more what is happend better then us telling you what to do because we dont want to give bad advice ok thanks
Posted on Nov 03, 2008
I have a Jialing off road bike with a high rev problem when starting, I noticed this problem when trying to start it after 4 months of not using it how can I fix this problem?
Hi, Sheren and the usual suspects are:
1. Throttle cables improperly adjusted, pinched or need lubrication.
2. Idle adjusting screw needs to be backed off.
4. Air fuel mixture adjusted too lean start with 2 full turns.
5. Intake system air leak.
6. Fast idle choke ramp is not releasing.
7. Broken throttle return spring.
8. Damaged diaphragm or slide.
9. Faulty MAP, TPS, ATS, O2, sensors or wiring/connector.
10. Multiple carburetors not in sync.
Good luck and have a wonderful day.
Jun 15, 2017 | Jialing Motorcycles
Why does my engine stall when idling bf falcon only does it some times ?
Fuel Injectors
Use an ohm meter to check your fuel injectors (with the engine running), by removing the wire from the injector. Two metal prongs sit inside the connector. Set the meter for the ohm setting. Touch the red meter lead to one contact and the black lead to the other prong. The ohm resistance number should be the about the same for all the injectors. If any injector reading shows a higher or lower than average number, the cause will be a defective injector, which will cause a rough idle. A zero reading will indicate a shorted injector, and must be replaced. You can also use a stethoscope or a long handled screwdriver to place on the injector head. You should be able to hear a clicking sound, telling you that the injector is "pulsing." No clicking sound indicates a dead injector.
Carburetor-Equipped Vehicles
Examine the choke setting on a vehicle equipped with a choke adjusting knob or mechanism. Make sure the choke operates by opening slowly during normal engine warm-up. A choke that fails to open or sticks shut during warm engine running will cause a constant misfire and rough idle. A choke stuck in the open position will not allow an engine to warm up properly.
Trouble Codes
Hook up a portable trouble code tool for your specific Ford make and model. Look for any trouble codes that appear while the engine runs at idle. Write down any code number and look it up in a trouble-code manual. Most times, code numbers can pinpoint the exact system failure or miss in the engine.
Powerful Autel MaxiDAS DS708 Multi language Diagnostic tool
Sep 17, 2014 | Cars & Trucks
2008 yardman lawn mower 13.5 hp. has a high idle speed and does not slow down, need diagram for throttle control
Throttle cable should pull a SPRING, which pulls the governor, which pushes/pulls the carburetor butterfly valve.
Aug 12, 2014 | Yard Machines Garden
Wont hold an idle revs up and down
Hi, Anonymous and the usual suspects are:
1. Extremely lean fuel mixture.
2. Dirt, rust, water, or ethanol sludge in the fuel system.
3. Sticky throttle cables.
4. Multiple carburetors not in synchronization.
5. TPS sensor out of adjustment or faulty.
6. Wrong spark plugs for the type of service.
7. Throttle bodies not in synchronization (FI)
8. Faulty O2 sensor.
9. Clogged, stuck, or faulty IAC valve.
10. Aftermarket components not compatible with ECM.
For more information about your issue please click on the blue links below. Good luck and have a wonderful day.
How To Fix 5 Common Bike Issues RideApart
http://www.thegsresources.com/_forum/showthread.php?181491-Bike-in-idle-and-rpm-s-go-up-and-down-then-stall
Total Motorcycle Forums
You wont get this engine revs by itself
Symptoms of Lean or Rich carb settings on motorcycle
Apr 10, 2017 | Motorcycles
IDLE CONTROL SYSTEM!! HELP
Poss clogged injector, vacuum leak Throttle body gasket Good luck
Mar 29, 2017 | 2003 Saab 9-3
Have a EB5000X generator which has staring problems, aprx 8 yrs old and not used a great deal until hurricane Ike came thru here and it ran for several days with minimal down time. Afterwards I changed the...
If I understand the problem correctly, it runs fine after you cleaned the carb, but the auto idle will not engage when you put a load on it. First if it has a switch to turn the auto idle off try that. if it does not rev up, then the magnetic controller is stuck. There is a magnetic coil which is connected to the throttle and this either pulls or releases the throttle when load is applied. My guess is that this is hung up a bit. Look for a small round coil with wires coming off it that is connected to the throttle assembly. You could also try tracing the wire from the auto idle switch backwards. This may just be stuck in the idle position by corrosion. especially if you live in a humid area or one near the ocean. gently try to work it a bit by hand (when the generator is not running) and try a bit of wd40 or the like.
Jan 02, 2011 | Honda Mmd 5000 Watt Electric Start...
I just got a 2000 zr 7 and it has good compression but smokes after a few minutes of running. The far left cylinder fouls the plug, as I said it has good compression, but has been sitting for 3 years, how...
What color is the smoke? A blue-ish smoke is burning oil, a blackish smoke is unburnt gas. If the plug fouled with gas or oil? Does the plug foul at idle, or while riding it? Full throttle? or partial throttle? Answer those questions and you will know if you have a an oil leak in the head or overly rich mixture at idle, or during an open throttle position.
It sounds like too much gas (since you say it has good compression -- did you do a real compression check?). I'd get the carbs synch'ed and make sure they all have their idle mixture screws set correctly.
Dec 16, 2010 | 2000 kawasaki ZR-7
1997 chevy truck 5.0 the truck sat for 7 months now it idles at over 2000 rpm only code showing for idle air control replaced it no difference
Try getting some throttle body cleaner, open the throttle body butterfly valve and clean it with an old toothbrush. It should be better.
Dec 12, 2010 | 1997 Chevrolet C1500
Jaguar xj6 4.0 1990. showing fault code fuel 14, fail 14. what does this code mean ?
2 airflow sensor out of operating range 3 coolant temp sensor out of operating range 4 oxy sensor indicates full rich 5 throttle potentiometer/airflow sensor... (low throttle pot signal with high airflow sensor signal) 6 throttle pot/airflow sensor...... (high throttle pot signal with low airflow sensor signal) 7 throttle pot...idle fuel adjustment failure(idle speed??) 8 intake air temp sensor...open or shorted circuit to sensor 11 Throttle pot at idle: Throttle pot idle trim out of normal range 12 Airflow meter: MAF signal out of range 14 Coolant thermistor: Resistance out of range or static during engine warm up 16 Air thermistor: Resistance out of range 17 Throttle pot: Out of range 18 Throttle pot/Airflow: Low throttle pot signal at high airflow 19 Throttle pot/Airflow: High throttle pot signal at low airflow 22 Fuel pump drive: ECU output to fuel pump relay 23 Fuel supply: Engine running too rich 24 Ignition Drive: ECU output to ignition Amp 26 Air leak: Engine running too lean 29 ECU self check 33 Injector Drive: ECU output to injectors 34 Injector: Looks for Injector dribble 37 EGR Drive: ECU output to EGR switching valve 39 EGR check sensor: EGR not working (normally pipe blocked) 44 Lambda (O2) sensor: Poor mixture control rich or weak (or misfire) 46 Idle speed Control valve: ECU output to Coil AB 47 Idle speed Control valve: ECU output to Coil CD 48 Idle Speed Control Valve: Stepper motor grossly out of position 66 Air pump: ECU output to air pump relay 68 Road speed sensor: Seen speed < 5km/h at high engine airflow 69 Drive/Neutral switch: Seen cranking in "D" or high airflow in "N" 89 Purge Valve drive: ECU output to purge valve
this is all I could find
Nov 09, 2009 | 1990 Jaguar XJ6
Engine miss at 45-55mph, no accleration with throttle response,
Anytime a bike sits for that long you stand a chance of fuel system problems. It sounds like you may need to "boil out" the carburetors and of course resynchronize them with vacuum gauges when you put it back together. You can also use a mercury manometer for synching the carbs. My guess is you have varnish still in the float bowls that is causing erratic running and perhaps the vacuum operated slides are not working correctly.
Nov 29, 2008 | 1986 Honda GL 1200 Aspencade Gold Wing
Video Game Consoles & Games Logo
134 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
