Question about AEG 18 in. Favorit F54850 Slim-Line Free-Standing Dishwasher
AEG DISHWASHER, DOES NOT HEAT WATER.
AEG SLIMLINE DISHWASHER, THE WATER STAYS COLD THROUGHOUT THE WASH CYLCE. IT IS NOT THE HEATER ELEMENT HAD IT CHECKED.
COULD IT BE THE SENSOR, THAT IS LOCATED IN THE BASE OF THE MACHINE.
  • angelote Sep 25, 2008
    I have a AEG favorit 40830 sensorlogic from two years an two months and I have the same problemI have looked that some people have the same problem but I haven't found a solution.
  • EMEABURN Sep 25, 2008
    Agelote, i was told it may be the SENSOR located uder the machine it may regulate the heater to switch on and off according to thewater temp. it is easy to locate and remove.
I had this same problem on our AEG dishwasher. The reason was on the controller board. There is one relay switch which drives the heater element.One of the legs of that relay box was disconnecteds from the circuitboard. Check this out.
Posted on Dec 09, 2008
  • 4 Answers
At the front door on top of it are the electronics,turn the electronic box loose and open it,get out the prints and on one of them is the heating command,this is probably burnd trough if you have opened the machine while it was heatening,you have to solder it with an electronic solder iron.
Posted on Sep 20, 2011
What is cold resistance of heater element? Bosch SGS56E02GB
If the heater element had infinite resistance, it would be defective. Possibly a defective thermostat.
Jul 01, 2015 | Bosch Dishwashers
AEG F60873 temperature problems.
The problem when the dishwasher does not heat is failure which requires to remove the qualified personnel and therefore error code is not shown on the display but it is visible in the service mode.
Possible error causes:
faulty heating element
wiring between heating element and PCB
PCB (printed circuit board)
Dado
Aug 24, 2014 | AEG Dishwashers
I have just been given a beko slimline dishasher DE2431F, my friend told me it was only washing on cold wash,and it needed a heater element,i bought one installed it but it is still running cold the water...
Use a mulimeter to check the voltage to the heaters when the dishwasher is started on. If there is no supply to the heaters then the fault lies with the program controller drive. It can be failure of the relay or the contacts. Or it can be problems in the main program controller not outtputing to switch on the heaters..
Jul 14, 2011 | Beko DFN1000X Dishwasher
AEG Favorit Integrated Dishwasher failing to heat the water. has the element gone? and how do you get at it?
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Mar 23, 2011 | AEG 23 in. Favorit 50750Vi Built-in...
The dishwasher will not heat up what could be the problem
heatman101
Nov 23, 2010 | AEG 24 in. Favorit 40850 Free-standing...
My dishwasher has stopped heating the water and is washing cold with obvious poor results. Is it a heater matrix problem or something like that? It is a Tricity BendixDH200
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
A bad heating element causes many problems in dishwashers…
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 07, 2010 | AEG 24 in. Favorit 40850 Free-standing...
Do all Hobart dishwashers have a element in them for wash water and rinse water
All Hobart dishwashers will have a wash tank heating element, but the rinse water is not heated by the dishwasher, unless it has a built-in booster heater. Usually a separate booster heater is used to heat rinse water to 180-190 deg. F for hot water sanitation.
Aug 07, 2010 | Hobart AM14C-155 Dishwasher
Dishwasher runs full cycles but the water is cold each time.
It's probably the heater element that has gone, but it could be a simpler fault like the pressure switch not activating. See this video it should give you the general idea
Jan 09, 2009 | AEG 18 in. Favorit F54850 Slim-Line...
Open Questions:
Hi, I have read all posts for fixing AEG Dishwasher not heating water problem. Most answers were about PCB heater relay. I have a Favorit 80860iW sensorlogic turbo, (turbo is car?) [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800026-1.jpg[/IMG] and i treat it as a lady. Always best materials in, and dishes cleaned before input. Now, I removed door panel, also 2 PCBs inside, but couldn't find any relay to re-solder it. I am posting some photos here, if anyone please see any problem in my PCBs, or the famous relay, just send me an answer where to solder. 1. when removed fascia. [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800038.jpg[/IMG] 2. back side of fascia [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800047.jpg[/IMG] 3. PCBs removed [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800039.jpg[/IMG] 4. PCB with red display panel [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800043.jpg[/IMG][IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800040.jpg[/IMG] 5. PCB with power button [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800042.jpg[/IMG] [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800041.jpg[/IMG] 6. PCB on the bottom of dishwasher [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800051.jpg[/IMG] [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800055.jpg[/IMG] I am disappointed, its a 2000 expensive buy, told me it would last, and i fixed it 5 times already. The dishwasher program is working normal, it just won't heat no more. I replaced today the bottom sensor, which fixed this problem 2 times in the past, but now, no luck with new part, it don't heat. 7. sensor replaced [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800049.jpg[/IMG] 8. where sensor goes in [IMG]http://i68.photobucket.com/albums/i29/savvaske35/AEG%20oko-favorit%2080860/JD800052.jpg[/IMG] thanks for your time.
Feb 05, 2011 | AEG 18 in. Favorit F54850 Slim-Line...
AEG 18 in. Favorit F54850 Slim-Line Free-Standing Dishwasher Logo
1,911 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
