Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD 52525
TV turns on, no picture, stays on for only a couple of minutes then shuts off. Timer light is blinking when tv is on for those few minutes. What can this be?
  • 927 Answers
GOOD DAY;
THIS COULD BE YOUR PROBLEM:
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). Good Luck, big IRISH.
Posted on Sep 28, 2008
WD-62526 shuts off
The power supply is failing. Your TV is able to start but the power supply can't continue operating and shuts down.
Dec 12, 2013 | Mitsubishi Televison & Video
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Timer light keeps blinkin!! i unpluged it and plugged back on and it does the same wat do i do
This would be a result a of your lamp going out. You will need to replace your lamp and reset the timer.
The Following are a couple of sites that have lamps for your model of TV.
http://www.bluestar-online.com/Mitsubishi_Model_WD_52525_Replacement_DLP_Lamp_p/wd-52525.htm?gclid=COS58_Xr05sCFSENDQoduFtFDA
http://www.purelandsupply.com/GeneralSearch.aspx?search=mitsubishi%20wd-52525
Make sure you reset the timer on your TV or it will continue to blink.
Jul 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Turn on the TV and only Timer light is on , no sound & picture
after holding down the menu and device the led will blink a two digit error code such as 3 blinks pause then 4 blinks then repeat that sequence a couple of times. Need that blink code to help let you know whats going on. The 34 code means lamp abnormality which translates to the power Pwb capacitors have most likely failed.
Jan 23, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The blinking status & Time LED lights
DM board n/l/a ....
the only and best way to fix this TV ! ! !
you need to replaced the chassis !!!!!!!!!!!!!!!!!
Nov 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62628 power shuts off!
hold the MENU and DEVICE buttons when turning on the TV and get error code
Dec 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
42" Mitsubishi 52525
You may have bad capacitors in the DM board.
Mar 05, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
147 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
