Alternator may be bad, causing battery to lose voltage. I think you should have the starting/charging system checked, and replace the battery and alternator as required by the testing. I wouldn't drive it until this problem is fixed, as the car can shut down when the voltage gets too low, working off of the battery. Check whether the charge light is lit when the car is running. If it is, there is a self detected problem with the alternator. If not, there could still be a voltage charge problem, that hasn't been self detected, perhaps a diode is bad or voltage regulator is faulty, causing the alternator to barely put out enough power to keep the car running.
No my friend. It happens even when the car is not started. I mean when you turn the ignition switch to accessory position. Plus when I start the car I measure my battery it reads 14.7 which is perfect ( Alternator ).
Any thing else ? or any body else?
I see. Usually when a customer complains of lack of voltage to accessories the charging system is defective. But, you say your voltage is 14.7 which should be plenty to power everything.
