Question about Canon FAXPHONE B640 Plain Paper Bubblejet
Will not print anything. Full cartridge.
Printed one page of six on incoming fax. Told me to replace cartridge. Cartridge full of ink. I took it out of machine reinstalled and it still won't work. HELP
    Problem Solver:
  • 16 Answers
Remove the cartridge and clean your contacts with isoprophyl alcohol. A cue tip may work best for this. Allow to dry. Make certain the cartridge is secured properly and the locking latch is down.
Posted on Nov 15, 2008
My printer won't print? it has full ink cartridges.How do i fix it?
Maybe your cartridges are not out of ink. Try it with another game cartridge kit...
Apr 30, 2012 | Canon PIXMA MP780 All-In-One InkJet...
My fax won't print copy's or incoming faxes.If I do a self test there are lines that are printed. The ink level says 4 / 8. I took the cartridge out and cleaned the copper area as said in manual...
Based ENTIRELY of the total LACK of make and model information about your fax unit, my guess is that the software DRIVER is corrupted! But of course, that is a total GUESS! Let me show you why that is SO IMPORTANT!
My favorite ant broke her leg ... leaving her only FIVE good legs to run around on! Most people know that ants (INSECTS) have six legs. But you MIGHT have assumed that my ant was my mom's sister, or my dad's sister, and that I simply misspelled AUNT!
May 11, 2017 | HP 1040 Plain Paper Inkjet Fax
My hp deskjet 6940 inkjet printer doesn't show me level of ink in cartridge
Print a diagnostic page If the steps above have not helped, print and evaluate a diagnostic page to see if the cartridges or the printer is causing the problem.
  1. Make sure the printer is on and loaded with unused, plain, white paper.
  2. Press and hold the Power button and then press the Cancel button. Release both buttons. The diagnostic page prints. Figure 1: Power and Cancel buttonsc00584735.gif 1 - Cancel button 2 - Power button
Step 4: Note which cartridges printed which areas of the diagnostic page You must identify which cartridge printed which part of the diagnostic page, so that if you find defects on the page, you will know which cartridge is the problem. However, you can install different combinations of print cartridges in your printer, and different cartridge combinations print different diagnostic page patterns. Your diagnostic page may not look exactly like the picture below, but the right and left cartridges will print in the same areas of the page no matter which cartridges are installed. Figure 2: Diagnostic page layout (the patterns in each area may look slightly different on your page)c00584715.gif 1 - Printed by the right cartridge 2 - Printed by the left cartridge NOTE: If you are printing in reserve mode (one cartridge is missing), the missing cartridge's area of the diagnostic page will be blank. Step 5: Check ink levels NOTE: If you have installed a refilled or remanufactured ink cartridge, or a cartridge that has been used in another product, the ink level indicator is inaccurate or unavailable. Look in the middle of the diagnostic page. The bars with "E" (for "empty") and "F" (for "full") at each end show the ink levels in the cartridges. As ink is used, the solid color changes to a faded color. Figure 3: Left (tri-color) cartridge almost full - right cartridge emptyc00235259.gif Figure 4: Both left and right cartridges almost fullc00235260.gif
Feb 22, 2011 | HP Deskjet 6940 InkJet Printer
How to refill hp deskjet 1560 black cartidge
Hi
check here
Pls vote us to keep us alive
Nov 09, 2010 | Office Equipment & Supplies
Cartridge error:remove cartridge and reinsert cartridge on left, already cleaned, still happening, when put in new black ink, printed the alignment page out and then error showed, cannot print, fax, etc,...
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Dec 12, 2009 | HP Officejet J5780 All-In-One InkJet...
I have a Kodak Easy Share 5500 AiO Printer. I was
Bad new catridge not impossible, I would return the catridge to the store.
Sep 03, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Page blank when printed
remove the ink cartridges and use a qtip dipped in rubbing alcohol and GENTLY clean the printhead on the cartridge. Reinsert and try printing again. If it prints anything at all, keep going till it becomes normal. If still nothing, replace the ink cartridges.
Jun 23, 2009 | Dell Inkjet 720 Printer
My fax machine 'prints' out a blank page when I receive a fax. No hint of any ink, yet when I test my ink cartridge it tests as full.
The ink may be dried out inside the cartridge. Try cleaning the brass parts of the cartridge with SOAPY WATER or replace the cartdridge.
Nov 19, 2008 | HP Office Equipment & Supplies
Ink cartridge problems
exchanged the black cartridge (57): the printer told me there was a problem with it, that I should remove it and re-insert it. I did, the ink button still blicks. After several efforts the printer started to work again, printed one document and then told me there was a problem with the colour cartridge. I removed it, re-inserted it several times. Finally a test page was printed - everything was okay.
Then the printer refused to print anything - the yellow LED lamp blicks continuously. Have turned the printer on and off, have also shut down the computer and re-started.
The only thing that will work now is the black cartridge, if I remove the colour one.
May 08, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Nothing there
Did you try cleaning the print cartridge nozzles.
Press Function once and up arrow 2 times
Press the right arrow once and the up arrow once
Press Start/Memory button
It will print a test parttern page
Once you insert the new cartridge did the machine recognize the new cartridge? You had to press 1 for new
When 1 is selected you will get a prompt New Cart: OK?
OK press start.
If you selected NEW the display will show the alternating messages at right. Align Cartridge----1 Print 2 Set
Press 1 to print an alignment page
Hopefully, it will printed. Let me know one way or the other.
Mar 27, 2008 | Sharp INKJET FAX UX-A1000
Canon FAXPHONE B640 Plain Paper Bubblejet Logo
59 people viewed this question
old marine
old marine
