Question about Xerox Phaser 6110MFP All-In-One Laser Printer
Xerox phaser 6110 mfp
Print quality very poor. Have already replaced main fuser unit which takes all colour cartridges. colour is very light.
help!
  • 2 more comments
  • Anonymous Dec 12, 2008
    Print is so faded that is is barley legible, ink has been changed with no results. This is worse on on one side of the page
  • Anonymous Dec 16, 2008
    I am having the very same problem. Color printing is fine but with the black, color is faded esp on left side of paper
  • nicky_mcgrat Jan 27, 2009
    how and where do i find the lsu???
  • Anonymous Mar 12, 2009
    where is the lsu
  • 24 Answers
Sir,
clean the LSU(Laser Sensing Unit) with a dry cloth.
Posted on Sep 29, 2008
Qu'est peut on faire si la machine ca,o, IR2318 donne erreur 0000007-0000
hello sorry but another time try to use the language which can easily be read and thats English back to the point the cause of that error is the rotation of the fixing film is detected.
The reading of the main thermistor is 100C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more while the fixing motor is driven try to check on that fuser film if the error persist change the fuser unit
Jan 13, 2017 | Office Equipment & Supplies
My MX922 printer worked well this morning. All cartridges have ink but ALL lights under the cartridges are on and print comes out blank. There are no error codes or anything abnormal displayed
This problem is mainly happens to all inkjet printers. If your printer print blank pages then please at least once go to official site of Canon and check whether there is any printer/scanner drivers update is available or not. If yes then download it. Also check your ink cartridges. Because if there is no print on paper that means your ink might be dry.Sometimes it clog the print head. If your ink cartridges get dry change it. Or you should clean your printer's print nozzle by using printer's control panel. I hope all these suggestions helps you. If doesn't then watch Canon MX922 Manual English
Jan 12, 2017 | Canon Pixma MX922
I replaced the K cartridge and i get this caution. I-Unit End Replace K
If "[Color name] Toner Empty. Replace with a new toner cartridge." is displayed and printing stops, replace with a new toner cartridge.
([Color name] indicates one of the following: C or Cyan, M or Magenta, Y or Yellow, K or Black.)
Jan 10, 2017 | The Office Equipment & Supplies
How do i solve an error e000-0000 canon ir 2202 please
Dear
Its related to the fixing temp. do the error clear on service mode. then check the fixing film assy. heater circuit contact points for corrosion. Replace it.
Thanks.
Dec 12, 2014 | Canon Office Equipment & Supplies
My Epson WF-3640 is printing with gaps in the text. How do I fix this issue?
Make sure you should remove shipping tape from the ink cartridge. These taps are used to protect printer during shipping but you have to remove it before starting printing. Beacuse these taps prevent the ink to entering in print head. If you will not found shipping tape in your printer then there is terr off strip, remove it. The tear off strip seals the the vent holes on the top of the cartridge to prevent it from drying out on the shelf or during shipping.
After ensuring that the shipping tape has been removed, run the printer's "Head Cleaning" utility to prime the cartridge, then print a test page.
See full detail at- http://guideusermanual.com/product-name-workforce-wf-3640-manual&po=152836&lang=English
Sep 18, 2014 | Epson WorkForce WF-3640 Wireless Color...
How can i calibrate print head of pagewriter trim 1
It would help if you stated the manif. example. Phillips, HP, hewlett Packard. ect.
You should be able to find service information on the bottom of unit.
May 08, 2014 | Office Equipment & Supplies
Why is print quality poor after inserting new ink. Copies are faint and have lines
the cartridge is clogged with ink that has dried and reduced the slit. you need to replace the cartridge with a new one. it happens usually if you recharge the cartridge 3 or 4 times with compatible ink.
May 07, 2014 | Office Equipment & Supplies
Laser printer makes light clicking noise when idle
When idle is potentially the fuser unit, after heating and cooling. However the print quality issue associated with the clicking sound could indicate an electrical issue. The HVPS maybe faulty causing the print quality issue (due to dependant parts) and the electrical click. In any case I would recommend calling Brother and finding the nearest authorised service agent.
Oct 20, 2012 | Brother Mfc-9840cdw All-in-one Laser...
Printer won't recognize cartridge
I had the same problem. I'm not sure but I think I replaced the cartridges when the printer was on because I turned the printer off and removed one of the cartridges. When I turned the printer back on it recognized that cartridge but not the others. I turned the printer off again, rmoved all cartiridges and put them back in when the printer was still off. When I turned the printer on again I had no problems. So...try turning off the printer, rmove all cartridges, then put them back in and restart printer. Hope this works for you .
Nov 28, 2007 | Epson Stylus 2200 InkJet Photo Printer
Xerox Phaser 6110MFP All-In-One Laser Printer Logo
761 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Whit
Whit
Level 1 Expert
iteminconline
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
