Question about Epson RX620 All-In-One InkJet Photo Printer
Epsom Rx620 states use originals for ink cartridges
Have tried 'compatable' ink replacement cartridges for my Epsom RX620 but after about 50 uses it nows states doesnt recognise my black replace, replace with original - can I do anything to override the epsom request, I asume its something to do with the chip in it.
  • 3 Answers
Try to hold down both 'stop' and 'B&W' button when you press the 'on' button to start the printer machine. This should erase the error message and let you print.
Regards.
Gordon
Posted on Oct 29, 2008
I have an Epsom TX100, it has run out of black ink. I have replaced it with a 91N cartridge, but it is saying it is not compatible.
Hi leona_sha321,
TX100 doesn't use 91N ink cartridges that was why it is saying that it is not compatible. below are the list of inks for your TX100
T0731 73N - black
T0732 73N - cyan
T0733 73N - magenta
T0734 73N - yellow
Thank you. hope this helps
Janc30
Feb 08, 2011 | Epson Stylus C46 InkJet Printer
Replaced all ink cartridges with epsom cartridges. Printer shows ink incompativble- replaced with identical cartidges and printer wont print
the inks u had replaced might not be the compatible with ur printer you need to change another inks which are compatible only
Jan 26, 2011 | Office Equipment & Supplies
Our daughter has an Epsom PaperMate 240 printer. Until now we have used only Epson cartridges but last time we bought a compatible cartridge. It ran 4 prints then the "out of ink" message was...
Hi
First it is not advisable to use other catridge other than epson because it will damage your printer. Because the printer have specialized chip that detect epson cartridge only. It will be okay for 2-3 times but later on it will say out of ink even you put new cartridge. I suggest if your printer had reset ink cartridge, just reset it and turn off your printer and computer for 5 mins. Then to restart on fresh mode and then try to print again. Next time use epson only because later it will not detect ink cartridge any more.
I hope it helps you.
Jan 11, 2011 | Office Equipment & Supplies
I have replaced all the ink cartridges, but it still says they are empty. It won't print anything. what do i do?
are these original ink cartridges? sometimes when you use compatible inks these happens. get some original inks in and check if it still does it. if you do have original inks and still get this problem the head may have a problem. you will need to have it checked at epson. if the original ink works, try to put the compatibles in, this solves the problem most of the time for compatibles.
Jun 19, 2010 | Epson Stylus CX5000 InkJet Photo Printer
ALL cartridges(compatible not original)suddenly not recognised
This may help http://www.ghacks.net/2008/03/18/epson-software-resetter/
May 01, 2009 | Epson RX620 All-In-One InkJet Photo...
Epsom RX620 Poor quality photo prints
I have got round this problem by routing my pictures via Picasa 2. Printing direct is still a problem, but I think I can live with that for now.
Richard
Nov 18, 2008 | Epson RX620 All-In-One InkJet Photo...
Epsom stylus CX4700 won't print - new ink cartridges installed
They cut costs on Epson compatible cartridges by using low quality ink and chips or not resetting the chips at all. Sounds like you got cartridges that the chips were not reset on so your printer thinks all the cartridges are empty. I own a Cartridge World ink refilling store and I would never recommend purchasing compatible Epson cartridges from anyone. I would buy refills of Epson brand cartridges and make sure the seller reset the chips.
Oct 18, 2008 | Epson Premium Compatible** Inkjet...
Epson Photo RX620
I use a bulk ink system which is not Epson so printer did not recognise the ink supply.
I 1) Turned printer off
2) Removerd bulk ink suppy tanks
3) Fitted Epson ink tanks [ dont matter empty or full ]
4) Turn on printer and let it go through it's start up prcedure
5) Do not turn printer off but do ink change procedure and refit bulk ink tanks
6) Do Nozle Check/Clean/Realignment
Bingo sorted
Jul 20, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
Wrong colours!
Hi Dannydoda,
I understand that, you are using different compatible ink cartridges and having problem with colors.
HP printers has a small built in firmware, which can detect the original ink cartridges and the ink level.
Using other compatible ink cartridges may damage the print heads of the printer.
I suggest you to replace the ink cartridges with original or Genuine HP cartridges.
You can also try some of the steps to fix the issue as given in the web link.
please click on the web link given below and perform the steps carefully.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042885&cc=us&lc=en&dlc=en&product=79499
This should fix the issue.
Have a great day!
Mar 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
Epsom R200 COPY INK DOESNT WORK
There is no solution, I have tried this myself, there are compatible inks for this product, you just got the wrong ones, However it may only be down to one of the inks, check the ink levels before removing, if all empty, then they are not compatible.
swampduck
Jan 07, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson RX620 All-In-One InkJet Photo Printer Logo
314 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
