Question about ViewSonic VE710b 17" Flat Panel LCD Monitor
Auto image adjust
Constantly reading "auto image adjust" across the screen. What should the resolution be set at?
SparkGap
  • 363 Answers
SOURCE: Always says: Auto Image Adjust
These are the allowable resolutions and refresh frequencies for your monitor. 1280 x 1024 @ 60, 75 Hz 1024 x 768 @ 60, 70, 72, 75 Hz 800 x 600 @ 56, 60, 72, 75 Hz 640 x 480 @ 60, 75 Hz 720 x 400 @ 70 Hz 1280x720 is invalid but I see that you were having problems at 1024x768 which might mean the refresh timing was wrong. Make sure the monitor tab in the display properties (advanced) is correctly set with 'hide modes that this monitor cannot display' so that the display is locked to the valid frequencies and resolutions. If all else fails look at the game .ini configuration settings. You might be able to set a compatible mode there. Or run the game in a window.
Posted on Sep 24, 2007
proton77
  • 1183 Answers
SOURCE: auto adjust
In case you have connected both the DVI and VGA cables to the back monitor can cause this problem. Try unplugging one of the cables and check if the problem gets resolved
Posted on Mar 23, 2008
  • 13 Answers
SOURCE: Planar 2010M auto adjust
This may be related to a power supply problem that these monitor have. I think you need to fix the power supply board inside the display itself. It's giving the logic board and backlights fluctuating power and they have weird / intermittant problems.
There is a supplier of power boards online, you can google them with numbers from the board but I don't suggest using them. Look for information on the company before you buy from them. I've seen a lot of complaints for this "international" company.
First check that you are getting a strong 12V from the external power adapter. If so, the problems may be as simple as changing out a few capacitors. (about $8 in new capacitors, plus shipping)
On the PL2010M monitors you need the following parts. I've added digikey part numbers to make life easier:
P10271-ND 220UF 25V Capacitor (3 or 4 depending on PS)
P10275-ND 470UF 25V Capacitor (1)
P10221-ND 470UF 10V Capacitor (4)
If you're not comfortable with soldering and de-soldering electronics, take it to a local technician for the work and give them the parts list above. That should work to fix your issues. I've fixed several of these monitors so far. All the problems were related to the power supplies having bad capacitors. Same with the Planar PL1700 LCD monitors.
There is also a single capacitor on the display logic board, but I haven't seen this one go bad yet.
-Chip
Posted on Dec 06, 2008
SOURCE: computer monitor keeps auto adjusting screen
I don't know if this solution is credible to all monitors with this problem.... but have a gateway monitor and it kept doing that annoying "auto processing" flash while i worked...but i figured it out...for some wild reason i held down both the "auto" button and "contrast down" button and it fixed it. it will take a couple of tries but on a lucky push I did it and it went away and i havent had a problem since...I hope i have been a little help :)
Posted on Feb 03, 2009
acdr
  • 1913 Answers
SOURCE: Monitor resolution problem
set your dispaly resoluiton to 1024*768
Posted on Mar 24, 2009
Image auto adjust
it seems the LCD panels is defective.
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 05, 2014 | NEC Office Equipment & Supplies
Colour setting keeps reverting from 32 bits to 8 bits
Turn the laptop on and hold down the "Fn" key on the laptop's keyboard.
Tap the arrow key that has a picture of an open sun to make the laptop screen brighter.
The laptop will automatically save the adjustments after you release the "Fn" key.
Tap the arrow key that has a picture of a filled-in sun to make the laptop screen darker.
Screen Resolution
Click the "Start" menu. Click "Settings" and "Control Panel."
Choose "Display" and "Settings" in Windows 98, ME or XP. In Windows Vista, click "Appearance" and "Adjust Screen Resolution."
Click on the resolution bar and slide it to the right to lower the screen's resolution and to the left to raise the screen's resolution.
The optimum screen resolution usually depends on the size of the laptop screen.
The recommended resolution for a 15-inch screen is 1024 x 768, 17- to 19-inch screen is 1280 x 1024, and 20-inch screens is 1600 x 1200.
However, you can adjust the resolution to your personal preference.
Click ""Apply to see how the resolution looks on the laptop's monitor.
Click "OK" to save the resolution settings.
Color Setting
Click "Colors." Choose 32-bit for a high color-pixel ratio that will make the colors brighter and bring out image details.
Choose 24-bit for a medium color-pixel ratio if the screen is too bright or if images are somewhat distorted.
Some older laptops have a 16-bit color setting, but this setting is no longer recommended as it will distort images and text.
Always Click "Apply" to see how the color setting looks on the laptop's monitor.
Click "OK" to save the color settings
hope this helps
Oct 14, 2012 | Computers & Internet
What do I need to connect my laptop/wii/dvd player to my Sharp Quattron Aquos Led TV? Please need an urgent answer please?
Hello
1 Press MENU to display the MENU screen, and then
press [=> or <=] to select "System Options".
2 Press [Up or Down] to select "Input Terminal Setting", and
then press ENTER.
3 Press [Up or Down] to select "PC input", and then press
ENTER.
4 Press [Up or Down] to select a specifi c adjustment item,
and then press ENTER to set each item.
5 Press [Up or Down] or [=> or <=] to select or adjust the desired
setting, and then press ENTER.
Adjusting the PC Image
Auto Sync. (for Analog PC Input Mode Only)
For automatically adjusting the PC image.
Yes: Auto Sync. starts and "Now adjusting the image."
displays.
No: This function does not work.
When "Auto Sync." is successful, "Completed" displays. If
not, "Auto Sync." failed.
"Auto Sync." may fail even if "Completed" displays.
"Auto Sync." may fail if the computer image has low
resolution, has unclear (black) edges, or is moved while
executing "Auto Sync.".
Be sure to connect the PC to the TV and switch it on before
starting "Auto Sync.".
OK.
Mar 14, 2011 | Sharp Televison & Video
The HANNSPREE monitor that I just bought is great except for one thing. As a photographer, the HANNSPREE screen is too wide in relation to the normal photograph sizes. The horizontal linear distortion...
The best way to adjust the screen is to adjust the screen resolution until you get a correctly proportioned image.
First display an image such as a square or a circle on the screen.
Go to Control panel - Display - Settings tab and start with 1024 X 768 screen resolution adjustment
click Apply and the check your image.
Repeat the adjust screen resolution select the next highest screen resolution setting, repeat thia process until you get the best image.
Jan 24, 2011 | Computers & Internet
How do I get my gateway fpd1975w tft lcd monitor to not stretch images images across the screen?
You need to make sure your computer's display resolution is set to 1440x900, which is the monitor's native resolution. Other resolutions will result in fuzzy displays or, as you're seeing, distorted images.
Right-click on an open area of the Windows desktop (that is, not over any icons), then select "Properties" from the pop-up menu. Click the "Settings" tab and you'll find a slider adjustment to set the resolution. If 1440x900 is not offered as a resolution, you'll need to upgrade your video card (or add a video card if you have a motherboard with integrated video). Most newer computers support that resolution, but some older systems may only go to 1024x768.
Thanks for using Fixya!
Oct 20, 2010 | Gateway FPD1975W 19" LCD Monitor
Screen monitor images on the righ side is not showig.
Hi afcarrillo,
This could be a simple resolution problem. By that I mean that the resolution is set too low, therefore putting things off screen. Here's how you change the resolution:
Windows XP
Right click the Desktop and select Properties. Click the tab all the way on the right that says settings, and drag the slider to your native resolution of 1600x900
Windows Vista
Click Start, Control Panel, Appearance and Personalization, Personalization, Display Settings and drag the slider to 1600x900
Windows 7
Simply right click the desktop, select Screen resolution and pick 1600x900
If you do not have a resolution problem, then it's most likely the monitor itself. Most often times you can fix it one of two ways:
1. Some monitors have a button that says "Auto" which will auto adjust your monitor. If you have one, try it.
2. If that didn't work or you don't have one, go through the monitor's OSD (on screen display) and work through the settings so that you can manually adjust it and set it to your taste.
Hope this helps :)
Nov 29, 2009 | Acer Computers & Internet
Computer monitor
If one of those 5 computers has a working monitor,
set the device-resolution to 800-by-600 and the refresh-rate to 60 Hz.
Then, disconnect the "working" monitor, and connect the "problem" monitor.
It should say "auto-adjust", and then it should continue to display that 800-by-600 image.
Try upping the device-resolution to 1024-by-768,
and see if the "problem" monitor will support that resolution.
Try upping the device-resolution to 1280-by-1024,
Nov 06, 2009 | Computers & Internet
My desktop is not centered and the fonts are too big. Also my Start button and bottom toolbar have disappeared.
Sounds like your resolution has been set too low.
Firstly, i'm going to assume you have a 17" LCD monitor, and that you are running Windows XP. (what a guess!) =-]
Generally, you'd want to right-click the desktop in a blank area, select properties. This gives you the display properties. Go to the last tab across called "settings", then under "screen resolution", drag the slider up a notch and hit apply. If it looks right, leave it at that. If it's not quite right, go another notch and apply. Keep going until you have it right.
But on your 17" LCD monitor, running the DVI cable to the PC... the computer should already have detected it's maximum resolution. In this case, you can drag the slider all the way to the right and hit apply, knowing that this is the optimal resolution. Also on your Dell LCD, you should have several buttons for adjusting the screen. One of those buttons is usually a "self-adjust" or "auto detect" or "some other obvious thing" for self-adjusting the screen viewable area. It *should* do this automatically when you change resolutions, which your Dell 173FPb should do anyway. =-]
Aug 23, 2008 | Computers & Internet
My monitor is showing constant 'auto adjustment in progress' in every 3 sec, i cannot get rid of it.i cannot watch any movie or read my email.constant getting black out and showing me that same msg
it happens because you have selected( accidentally or otherwise) the resolution that the monitor cannot handle easily. So each time turn on the computer the screen tries to adjust itself to work with the resolution that you have selected. Select a screen resolution that the monitor can handle and work with.
May 17, 2008 | HP Computers & Internet
Sep 24, 2007 | ViewSonic VA703B LCD Monitor
ViewSonic VE710b 17" Flat Panel LCD Monitor Logo
134 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
