Question about Zanussi TC7114W Electric Dryer
I have a problem with my dryer. Where the water bottle locates at the back of the dryer there is a spring and a valve with an o ring on it this has fallen out and I cannot figure out how this is located. Help if you can please.
  • tomlen Dec 31, 2008
    Can anyone tell me where the spring goes and how the valve is fitted please?
    President:
  • 1,462 Answers
O ring fits on a slot round the spigot of the valve
Posted on Sep 25, 2008
You need to get underneath the dryer by tiltiing backwards. Then you unscrew the part connected to the back left underneath, which is where the water reservoir clicks into. Once this part is taken out, you need to locate the small cylindrical sprogit and spring. Push the sprogit through the spring and through to the other side of the fitting. Then to hold the spring in place, you place a small o ring over the lip of the sprogit. Now the whole fitting should spring in and out just like the one attached to the water reservoir. Re-attach this back into place under the maching and it should now work!
Posted on Feb 05, 2012
I have a Zanussi condenser dryer TC 7114 w. It stops half way through the cycle indicating the water tank is full, but it is vertually empty and the water is collected in back of dryer and then leaks all...
I have just fixed this as below - your leak may be easier to see if you turn the machine on its front - there is a rear valve with a rubber bung and underneath a rubber pipe with a metal clip - check both for leaks - http://www.fixya.com/support/t4079509-full_water_indicator_lit_continuously
Oct 04, 2010 | Zanussi TC7114W Electric Dryer
Where is the thermostart in the dryer of zanussi tc7114w
Open up the back of dryer and the thermostat is located on the exhaust duct down by the lower part of dryer.
Nov 05, 2009 | Zanussi TC7114W Electric Dryer
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Water leaking from back of m/c
You may have accidentally disconnected the pipe which takes water from pump to bottle.
Please post back if any assistance needed to access pump.
Thankyou for using Fixya.
Jan 23, 2009 | Zanussi TC7114W Electric Dryer
Zanussi tumble dryer. no.TC7114W
loop the belt around the drum.
slide the belt down the drum directly over the motor pulley
loop the belt around the motor pulley
pull the tensioner pulley hard to the end of its travel against its spring
wrap the belt around the tensioner pulley
release the tensioner so the spring pulls it against the belt
rotate the drum by hand to ensure the belt is aligned and does not pull offf the pulleys
reassemble case
dry clothes
its easier than it looks seeing a broken belt in the bottom of the case.
Aug 07, 2008 | Zanussi TC7114W Electric Dryer
Zanussi TC7114W condenser Drier
belts do not figure 8
they look something like this
f6516ed.jpg the front panel comes off, to access the drum without removing bearings etc, and the belt can be placed easily, around the drum and motor pulley.
then pull the tensioner hard against its spring, loop the belt around the tensioner and allow the spring to tension the belt.
Feb 14, 2008 | Zanussi TC7114W Electric Dryer
TC7103W - electric dryer
there is a lint blockage between the water collection box and the pump
Jun 02, 2007 | Zanussi TC7114W Electric Dryer
Zanussi TC7114W Electric Dryer Logo
218 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
