Question about Kenmore 73662 Top Freezer Refrigerator
Kenmore 253.717941OC Top Freezer - freezer okday, frigerator inop
My freezer is operating as it should but the refrigerator is inop. There is no fan noise, not cold at all. Cant get Sears out here until next month. Have to keep ice chest filled with ice beside frig. for frig supplies.
  • Brakofday
    Brakofday Sep 25, 2008
    Thank you for taking the time to direct me. D
Try defrosting the fridge, sometimes water gets frozen arond the fan and won't allow the blades to turn.
Posted on Sep 26, 2008
  • Kenmore Master
  • 5,568 Answers
The missing fan noise is the clue; the fan that is responsible for circulating air between the two chambers has failed. Both may have cooling coils but a fan is responsible for balancing the temperature between the two and is even more important if the coils are exclusively located in the freezer chamber.
Unless it is still under warranty, it isn't necessary to wait on Sears service since they are independent contractors anyhow.
If you are in the US, check your local Better Business Bureau website to find a reliable service company. I'd bet you can find one much earlier than next month.
Posted on Sep 25, 2008
My kenmore side by side has a problem the freezer part work but the frigerator part doesn't what can I do help
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 14, 2011 | Kenmore Refrigerators
Frigerator and freezer are not cold
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Jan 26, 2011 | Kenmore 64802 Top Freezer Refrigerator
Freezeor r works fine but frigerator not working
check that your fan is working inside your freezer also check that u do not have an ice blockage problem if your fan is working and also check your t-stat and heater start with the fan if its not blowing the air into the fridge side then thats your problem you can order a new fan from marcone or allbrandsappliance hope this helps
May 16, 2010 | Maytag MSD2756G Side by Side Refrigerator
Kenmore Top Freezer not getting cold (freezer or refrigerator), fan works. Occasional click down by compressor? Any advice appreciated. Trying to fix cheap as this is an 8 year old 2nd frigerator we keep...
Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Sep 12, 2009 | Frigidaire FRS26R4A Side by Side...
Frigerator will not cool , freezer operates, coils cleaned, fan operating
On line diagram of frig and concluded that it was the upper fan (motor) in the freezer. Air was not being transferred to the bottom portion of the frig.
Sep 05, 2009 | Kenmore Refrigerators
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator
The divider between the side by side frigerator/freezer where the door closes and seals is extremely hot- too hot to touch. Is something wrong with my refrigerator, should i unplug it?
Aug 25, 2009 | Kenmore 53642 / 53644 Side by Side...
Water in bottom of frigerator
Hi, The drain is plugged coming from the freezer section. Please get me a model# and I can assist you with this problem. Thanks Vic
Jun 14, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Frigerator is working but, refrigerator is not working at some points
Your freezer coil may be frozen over causing air circulation to stop. Check for frost build-up in freezer compartment. this is an indication of a fault in the defrost system timer or heaters.
May 18, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
FAN MOTOR NOT OPERATIG
1. remove everything from freezer. 2. unplug freezer. 3. remove screws from back of freezer wall. 4.remove evaporator fan. (you will see it at the top of the freezer wall) 5.install new one.
Mar 12, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73662 Top Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
