Question about Whirlpool RF369LXPQ Electric Kitchen Range
Whirlpool electric range model # RF261PXSQ oven not heating
My electric range is a little over a yr. old and the bake, broil and self cleaning function do not work. The stove top works fine the digital display says the oven is preheating and beeps saying it is up to temp. but there is not heat. The elements were not the problem what else could it be? Anyone have any ideas? Please help!!
  • 1 more comment
  • gametime2525 Sep 25, 2008
    The elements never attempt to come on.
  • Anonymous Jan 30, 2009
    Burners work; oven control panel works, but the elements in the oven do not heat up on bake or broil.
    My model is: RF261PXST
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Do the elements actually come on? Or do they stay off and never attempt to heat?
  • 5,911 Answers
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. The surface elements are controlled by individual infinite switches behind each control knob.. That's why the surface elements all work, but the oven does not. A replacement EOC can be purchased on line at searspartsdirect.com. Just type in your COMPLETE model number and you will find it under the "Control Panel Parts" heading as item number 12. There are several listed, based upon the color you need (White, Biscuit, and Black). This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
I hope you find this information helpful. Let me know if you have questions and/or require additional assistance.
Posted on Sep 25, 2008
Both Oven elements do never come on Together, Top Works When turn on Broil and Bottom when On Bake & Auto. Pls help.
that's normal. The top element is meant for broiling only while the bottom one is meant for baking.
Mar 11, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
My oven will self clean and the top will come on when in Broil but oven will not preheat in bake mode.
self clean and broil will make same heat for self clean
if this is a gas range then change bake glow ignition
more info can be yours send us full model # of range for more exact info of your range.
electric range will be element bake or broken burned wire
Dec 06, 2014 | Hotpoint Kitchen Ranges
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Self Cleaning Oven - Model RF360BXXW Serial # FA4005915 Turned oven on bake - bottom element is not heating however top element is. Tried to change setting to 'timed bake', 'broil' and 'clean'...
Your lower element may be burned out. Generally you can firmly grasp and pull it out. Take it to a repair shop and get a replacement unit. Then simply snap it back into the same outlet where you remove the first one. It sound as if you've tried everything else so it must be the unit that is bad.
Nov 04, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My oven does not bake any more
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jun 01, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
My whirlpool oven will not heat up or bake or
Should still be under warranty! Call the dealer. Make sure you have the model # and serial # from the tag on the oven first. It is the ONLY way they can check warranty status. If not covered, it is probably the selector switch
Mar 31, 2010 | Whirlpool GS445LELS Gas Kitchen Range
Self cleaning gas range: Bake and broil will not light up.
the thermal fuse in back is out. sometimes they are resetable
Feb 09, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
How do i turn on the bake option on the self cleaning oven?
to just turn on the bake option there should be a bake button to press as well as a self clean option and broil cycle.
Jun 21, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Oven not heating properly
you sure you have 240volts at the unit??? chk for 120+120 volts to get 240volts,one leg out and you'll have little to no heat condition
Jun 19, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool RF369LXPQ Electric Kitchen Range Logo
1,278 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
