Question about Dell Latitude C640 Notebook
BIOS!!! I am using the dell system at XPS710 and i kept getting the bios error: No boot device available I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem. PLEASE HELP! No ignores!
    Scholar:
  • 124 Answers
No boot device available means that there is no Operating System available. F12 is the key that will get you into the Dell BIOS, not F2. Once there change your Boot Order to your HDD first. Good luck!!
Posted on Sep 25, 2008
  • Chris Brewer Sep 29, 2008
    My suggestion didn't help? Give me some more info and I'd be glad to revise it.
Laptop not used for some years. could enter bios OK to reset Replaced U/S CMOS battery with no problem. Restarted............ Message press F1 ibm bios setup press F11 to invoke IBM product recovery...
I received an IBM laptop with same issue a few months back. The error message due to the drained out CMOS RTC (coin-cell battery), which retains and other BIOS settings.
The system is OK and all you have to do is to get the CMOS/RTC battery replaced by the a professional.
Good Luck!
CreativeTECH
Dec 31, 2010 | IBM ThinkPad R30 2656 Notebook
Stop c00002la fatal system error, when I hit F8 and try to start with last known good configuration, still get error, can't fix it?
Run The Recovery Console
1.Boot from CD or DVD (change boot order from BIOS F1,F2, or Delete key/ save changes on BIOS ) then Reboot to BOOT fron CD
2.Choose R to Run Recovery Console
3.Enter 1
4. Enter your Admin Password
5.Type: chkdsk -r
6. Done
Nov 16, 2010 | Dell Dimension 2400 PC Desktop
OptiPlex GX110 PC Desktop: Hello.. I'm having Dell Optiplex machine.When I t...
Generally an indication that the Hard Drive isn't detected
Things to check, go to BIOS F2, reset defaults and reboot, see if the HDD is seen. If it is, the battery on the motherboard is likely dead and needs replacement (Watch battery at Walmart, 3 dollars)
If the HDD doesn't detect after resetting the BIOS, then most likely a Hard Drive failure
May 18, 2010 | Dell OptiPlex GX110 PC Desktop
Dell Dimension E520 has "NO BOOT DEVICE AVAILABLE" message. Pressing F1 F2 doesn't help. What should I do?
Shutdown the system and disconnect the power cable.Disconnect external peripherials.Hold the power button for 10 secs to drain static power.connect the power cable to the computer.turn on the computer and hit the F2 key to boot in bios.If you are in the bios turn on the caps lock,scroll lock, and numlock key.then Hold the Alt key + E, then Alt key + F, Alt key + B. Computer will restart check for hdd or boot device.If hdd is detected it should boot to desktop.If issue persist .Shut down the system.disconnect power cable.Hold power button for 10 secs.Open the tower and disconnect the hdd from the sata or ide cable.Connect hdd in a different sata or ide connector.Connect power cable and turn on the computer and follow steps 1.If still getting same error possible hdd gone bad.Good Luck.
Sep 03, 2009 | Dell Dimension 8400 PC Desktop
The service tag is 19sfy91. At first I could not get past BIOS error "Alert! System Halted. Incompatable processor" I flashed BIOS and the PC boots up but I still get the error message with option F1 to...
The new series of Intel G1 stepping Pentium 4 processors (Prescott) is not backwards compatible with all the latest BIOS versions for OptiPlex systems.
Jun 05, 2009 | Dell OptiPlex GX520 PC Desktop
Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
May 28, 2009 | Dell Dimension 8300 PC Desktop
Asus A8V Error Message
How many whats is your power supply? Sounds like not enough voltage.
Nov 27, 2008 | ASUS A8V Motherboard
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Apr 27, 2008 | Dell Latitude C640 Notebook
Dell Latitude C640 Notebook Logo
137 people viewed this question
Alun Cox
