Errors in hard disks
I have problem in hard disk
pls tell me how can i solve it /
help me pls
  • nep_garcia Mar 02, 2009
    I'm having error loading OS on my old notebook.
    Diagnostics told me that it's with the hard drive.
    Since the omni book 4100 is old, do you have anysuggested replacement. pls send the specs.. tnx
  • 189 Answers
Need more information.
Posted on Oct 19, 2008
How to format the canon ir3300 hard disk
If the error 602-003 arise in IR - 3300, Than what to do, is it necessary to format the hard disk ? If, so , pls. let me see , how to format the hard disk ?
Thanking you
Nov 18, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Pri master hard disk: S.M.A.R.T. command failed
there is problem with hard drive kindly replace it.
have a nice day dont forget to rate pls.
May 11, 2010 | Samsung (SP0411N) 40 GB Hard Drive
Cannot Read disk. Operating system not found Error
best way to solve it and recover your data is to take it to the vendor else you can use dos to copy it to your pen drive...lets understand 1st why a vendor can only work with it because its a laptop and the hard disk can not be accessed externally like with a desktop...so dont play with your critical data hope this will help u a lot...
cheers...pls rate...
Jan 04, 2010 | Lenovo 3000 Y410 Laptop
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
How can i solve this problem..? my 500gb hard disk damage... the bios says that the 3rd master hard disk error.. pls.. help me..
I myself would purchase the external USB empty SATA Hardrive interface box and then connect it to your PC to see if it at least recognize the drive.
If you really need the files from the drive if this tactic doesn't work then I would find a Data Recovery company that can pull your information off the disk and send it to you. 'You will loose the drive but recover the information'.
Not cheep at all. Usually 3 to $400 charge.
Blessings,
A/V Media Guy
Nov 22, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Need a hard disk recovery software for canon ir3300
hi i am form India i have canon ir 3300 i am getting error for E602-003 pls no technician
Jul 08, 2009 | Canon Office Equipment & Supplies
PXE-E61: Media test failure, check cable Pxe-M0f: Exiting Broadco
PXE-E61: Media test failure, check cable (of the HARD DISK pls)
pls first check the hard disk seated in the bottom left side of ur notebook u have to take out the 7 or 8 screws first and then take take it out by pulling the connector gently and try to re seat or re fit the hard disk so connector can seat firmly in hard disk and then power up ur notebook if Error persists
then sorry to tell u my friend that ur Hard disk has CRASHED and not giving up files for OS loading kindly replace ur HARD DRIVE and restore ur OS thru backup disk u got
Pls take care of ur notebook from bumps and falls and hard impacts during operation and carrying bcoz the disk inside the HDD is very sensitive and gets damaged easily by impacts
pls rate me FIXYA for my diagnosis
Mar 09, 2009 | Acer Aspire 4720 Notebook
Hard disk i/o error solution
Be sure the HARDDRIVE JUMPER is set in right place TO MASTER SETTING(If this is only harddrive you are using?),What bios options do you have?(BIOS AUTODETECT?),lastly what changes did you do B4 yu got this error?
Oct 08, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Toshiba MK8034GSX Hard disk Drive Problem
sounds like you'll need to reinstall the operating system, from the recovery cd...or use F8 for safe mode, and see if it's a virus issue
Apr 23, 2008 | Toshiba MK8034GSX 80 GB SATA Hard Drive
Error loading operating system
An error message as you have posted would indicate:
1. The hard disk does not contain a valid operating system. Alternately, it may have the OS installed but some files are missing or corrupted;
2. The partition of your hard disk may have been deleted/missing;
3. The hard disk is no longer recognized by the computer;
4. Your CMOS/BIOS is set to boot from the CD/DVD only but it does not contain a bootable disc;
Corrective measures may include any or all of the following:
a. Load and use the restore/recovery CD of your PC if it came with one;
b. Repair or re-partition of hard disk;
c. Repair or re-format of hard disk;
d. Repair or re-install the Operating System;
e. Re-configure CMOS/BIOS to boot from the hard disk (HD) first;
f. Worst case scenario is replaced hard disk and re-install Operating System.
It is possible that you would loose most if not all of your documents, files and/or data unless you can do a back-up.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 09, 2007 | Sony VAIO V2M (VGCV2M) PC Desktop
Computers & Internet Logo
131 people viewed this question
David Payne
David Payne
