Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
Kenmore bagless upright Model # 116.35726401
My vacuum just stopped working completely. It will not turn on. I've tried several different outlets in the house and made sure there were no circuit breakers tripped. There's a new filter in it and not a lot of dirt I just emptied the canister. How can I troubleshoot this problem?
Thank you,
L
    Problem Solver:
  • 7 Answers
There is actually an internal fuse in the vacuum. You may have blown this. The circuit board connected to the ON/OFF touch pad may be bad too but probably unlikely. There is also an overheat sensor that trips the vacuum off when it gets too hot. This could be bad preventing it from coming on too. All of these solutions, require you to open the vacuum to fix.
Posted on Dec 05, 2008
Stop working. brush was cloged. It there a reset button?
i had a similar thing happen and just got off the phone with dyson. there is a resettable switch on the handle. they told me to start the vacuum in the upright position, put it in the non upright position, then push and hold in the beater bar switch which is located next to the on/off button for 10 seconds and the beater bar should start to function once again
Jul 15, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I plug my vacuum in and turn it on and nothing happens. checked different outlets and still the same problem.
Check the following:
- The handle may not be installed properly, causing a loss in the power connection. Remove the handle completely. Slide the handle back into place on the lower section of handle and tighten the screw.
Jun 15, 2010 | Bissell Healthy Home HEPA Bagless Upright...
Bissle vacuum and stopped working
bad cord or motor. not cost effective to repair.
May 06, 2010 | Bissell 6594 PowerForce Bagless Upright...
It electrically stopped- no blockage or horrid noise just won't work! About 4 years old - and yes I have changed the fuse. Any answers?
have an electrician check the switch on the vac. probably went bad. also look for broken wires or connections.
you have tried a different outlet, right? also inspect power cord for any damage.
Apr 19, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The roller brush at the bottom of the vacuum is not spinning, hence it isn't picking up the dirt. I am unable to find a way to access it so that I can see what is stopping it from turning. Can you help me?
Hello. uUsually when the roller brush stops spinning the belt is broken. TIp the machine upside down and look for several screws which hold the bottom together. Mark the location of each screw when you remove it as different lengths are common and replacement in the same hole is vital. Joe
Apr 02, 2010 | Kenmore Progressive Bagless Upright with...
My vacuum (Eureka Bagless Model 2961 AVZ) will not START!
Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871.
Jun 11, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
Kenmore upright model number 86039259990. The
don'thave to smell, the belt just snapped in half.unplug the vacuum and try to turn the brush roller by hand,if it turns real freely the belt is broke.it should be kind of hard to turn by hand if the belt was good
Mar 04, 2009 | Kenmore Progressive Bagless Upright with...
Bissell won't turn on
the motor could be ceased up. do you hear a buzzing noise? if you dont hear a buzzing noise, turn it on for about 1 minute, unless it starts smelling hot or starts smoking. if nothing happens after that, try replacing the power cord.
Feb 01, 2009 | Bissell 6594 PowerForce Bagless Upright...
Stopped working
It cooled down and worked 20 minutes later
Aug 28, 2008 | Dyson DC14 Animal Bagless Upright Cyclonic...
Kenmore 33721 does not start
Same thing happened to me. After taking the cover off I noticed a wiring diagram on the inside cover. There is a fuse between the on/off button and the motor, sure enough the fuse had blown. There is no mention of a fuse in the manual! The vacuum works great again.
Apr 23, 2007 | Kenmore 33721 Upright Vacuum
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
353 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
