Question about Waring Pro WC1000 Coffee Maker
The coffee maker leaks out of the bottom when in use
  • Anonymous Oct 31, 2008
    How do you get to the tube?
I found the issue after about one hour taking the unit apart. Anyhow, in my unit there was a crack in the plastic spout portion. This spout partially goes into the hot water tank. After a bit of time the heat causes the spout to develop a crack, which leaks. I repaired the crack with some epoxy I had on hand and also added some aluminum tape to the area surrounding the spout. I hope the aluminum tape helps keep some of the heat away from the spout and prevent further cracks from developing. Its just a poor design, material wise, it should have been stainless steel from day one.
Posted on Oct 11, 2008
  • 4 Answers
SOURCE: Unit leaks out of the bottom
Mine just developed the same problem. Me being an engineer, I decided to take it apart and found the problem. There is an aluminum tube shaped like a "C" with a heating element inside of it. Water flows through this metal tube, is heated, and then pushed via steam pressure. There is a metal brace that holds this "C" piece securely to the bottom of the machine. This brace is sharp and overtightened, which caused a small hole to form in the metal, causing the leak (in my machine of course). I am currently researching how to patch aluminum so I can hopefully fix it.
Posted on Jan 06, 2008
Coldcut
  • 1554 Answers
SOURCE: coffee leaks from the bottom of the coffee maker
Remove the inner basket that holds the coffee filter and look at the bottom. is the spring and plastic lever intact, the lever redirects the coffee from the bottom port over to the pot. if it is missing or damaged then the coffee will dump all over the place.
Posted on Jan 26, 2008
SOURCE: Bunn Coffee Maker Leaks out the bottom
Contact Bunn and they will send you a free repair kit with good illustrated instructions.
Posted on Aug 17, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: cuisinart Grind and Brew 10
Replacement time. a certain percentage of thse have this problem. There is a small, non-replaceable tube in the inside toward the bottom that has become melted/damaged.
Posted on Dec 17, 2008
  • 189 Answers
SOURCE: Bunn coffee maker leaking from underneath the bottom
Please get the model and the date code from the bottom of the machine and contact customer serivce. Depending on the date code, there might be a seal kit available or the machine can be replaced at no cost if 3 years old or less. If it is over 3 years old and the seal kit isn't available, the machine will be replaced at a reduced price.
Posted on May 19, 2010
Mr. Coffee CG13 12-cup coffee maker. Have used it
There is high temp tubing that may have come loose or become dammaged fromheat or the coil that heats the water may be leaking if you are using strong cleaning chemicals to remove scale from the unit. The bottom is held on with screws. Remove these and look to see what is the source of the leak.
Nov 21, 2009 | Mr. Coffee CGX20 12-Cup Coffee Maker
Water leaking out the bottom of the coffee maker
If it leaks DURING brewing, you may have to decalcify it (aka, run through a cycle of 4 cups vinegar, fill to the top with water, 2-3 times and see if it helps).
If it leaks before you even start brewing a pot of coffee, something is broken on the inside of the coffee maker, and I would recommend contacting Waring--they may be able to get you a replacement coffee maker (and if you're under warranty, usually a replacement would be free!).
Their phone number (according to their website, www.waringproducts.com ) is 1-800-4WARING (1-800-492-7464)
Good luck! :)
Aug 27, 2009 | Waring Pro WC1000 Coffee Maker
Water leaks
unds like there is a leak in the tank. Take it back for a refund/exchange.
Jun 12, 2009 | Black & Decker TCM700 Coffee Maker
Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
Jan 12, 2009 | Bunn VPR Coffee Maker
Coffee maker leaking from bottom
I have had a few of these machines leak.
I pulled off the bottom and found Mr Coffee is using low quality tubing that melts or leaks where it attaches to the heater element that boils the water. I replaced the tubes with higher quality silicone tubing that I bought directly out of China on Ebay and the problem was solved.
Dec 26, 2008 | DeLonghi Caffe Nabucco BCO70...
Water leak
just had the same problem the heater ring at the bottom has a whole in it or the hoses have got a crack in it. use a no 9 torx driver to take the bottom off. the check hold it up get water in it and look for the leak. the heat ring should have white corrosion on it, that should be were the leak is
Jun 24, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Leaks at bottom
look for leaks up at the top by the top hinge.
mine leaks there. apparently a gasket is missing or just not tight enough.
you should see bubbles come out and see water go into the filter cone but some of it leaks down the inside (near the pot inside) and out the bottom of the maker and appears to be leakng from the bottorm.
Mar 23, 2008 | Cuisinart DCC-1200 Coffee Maker
Steam leak in GB Mia Espresso Coffee maker
I had the same trouble before and probable causes were:
too much coffee powder in the funnel?
or
the coffee beans are ground
too much, makes the power clogging in the bottom of the steam tube?
Jan 02, 2008 | Guido Bergna Mia Coffee Maker
Waring Pro WC1000 Coffee Maker Logo
381 people viewed this question
Top Waring Coffee Makers & Espresso Machines Experts
Douglas Dinnebeil
Douglas Dinnebeil
George Scott
George Scott
Are you a Waring Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
