Question about Philips 37PF9631D 37 in. LCD HDTV
TV is dead now after 2 years of work. What happened? Thank you.
  • Philips Master
  • 5,568 Answers
If it just fails to turn on, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board. Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.   If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy it and install it yourself. If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
Posted on Sep 25, 2008
Sony kp-57hw40 double picture. regular and the other right next to it is red. tried auto focus and nothing happens. while holding auto focus btton down get red cross and white next to it. tv is 9 years...
Auto Focus button no longer work.Tv have a problems known as a convergence problems,it dead.Tv have colors lnes R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts,must be replaced on the tv convergnce board to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 13, 2010 | Sony KP-57HW40 57" Rear Projection...
When I use the remote to turn the television on, nothing happens.
This problems happen to all LCD and Plasma tvs.In to 1 or 2 maybe 3 to 4 years old in used.The power supply board have these componnents parts call the capacitors,it will started to bulges up on it top,or puff up on it top.These capacitors are leaking gases and it dead.The tv will not power up and the LED power lite indicator start continuous flashing LED light.U know basic electronic's and soldering?Take the tv aparts where the power cord plug into it that ur power supply board.Searches all around the power supply board and it supporting boards,replaced all those dead gas leakage capacitors.Ur tv will power up normal again and work.Or Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
May 24, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Have a WD-52725 Mitsubishi TV. Notices lines
Ur tv have convergence problems before,that why tv getting colors lines somtimes alot,sometimes not.The 2 STK convergence ICS was defective.Now the 2 STK convergence ICS are now totally dead.The shop will cost u $300-350 for parts and labors for the 2 STK convergence ICS,and it supporting resistors.
May 12, 2010 | Mitsubishi WD-52725 52". Rear Projection...
My monitor suddenly appear a 'dead line' horizontally..
anything can be repaired if you have the money and are willing to spend it. However it would be better to get a quote and weigh up the pros and cons of replacing it cheaper than the repair A new monitor wilol also have 3 years warranty ( Samsung)
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Gateway FPD2275W LCD Monitor
My protron 32" lcd tv was playing and just died no power. I tried unplugging the tv to reset and nothing happen
Your power supply is dead. You can get one from POWER-ON.COM for about $64.00 including shipping and handling. My 32 inch went dead after only one year and I just got a new power supply and it works fine.
Nov 05, 2009 | Protron PLTV-32 Television
Wow - same thing happened to mine
I woke up one morning and the tv was dead, only a dark blue screen. remote works and that's it. i was thinking about doing the rca reset but don't know how to. this tv is only 2 years old when i brought it. I think it's time for a new flat screen with what the techs are asking for to fix it.
Jul 30, 2009 | RCA 32V420T 32" TV
Protron 42
on the back of the TV where the power cord plugs into the back of the tv there is a small black on/off switch- it's not as obvious as you would think.... but that was turned off. Not sure how that happened since the back of the Tv was never touched when it went dead- but I unplugged the cord from the back of the tv and from the outlet and reset that switch and it worked.
Jul 10, 2008 | Protron PLTV-4250 42 in. LCD Television
TV does not turn on
it will cost around 400 to fix. its the power supply. it happened to every akia like this and astar 26 lcd. just a crappy tv. i would have to say they all lasted about 1 year when this started. i sold these tv s for a while at my work.
Oct 14, 2007 | Akai LCT2660 26 in. HD-Ready LCD...
Philips 37PF9631D 37 in. LCD HDTV Logo
300 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
