52" DLP Mitsubishi HD TV; Timer Light (Green) continues to flash - unable to turn on TV
  • 8,617 Answers
You need the V26 DM repair kit available at the following link, which contains the replacement high temp capacitors and instructions. Its listed under the repair Kit category.
http://servicemanuals.vstore.ca/
Posted on Sep 25, 2008
  • 4,234 Answers
I can;t look this up without the model number, but indications like this usually mean that the lamp needs to be changed. Look in the owner's manual for a listing of these indicators.
Dan
I have a Mitsubishi WD-52725 DLP TV and green light (timer) is rapidly blinking after a power outage and set will not turn on. The bulb was replaced a month ago and it has worked fine since. Now it will...
Hello
make a System Reset process. To do this;
If the TV will not respond to either the remote control or the front panel controls and/or will not power Off, press the SYSTEM RESET button with a pointed item like the end point of a paperclip. The TV will turn Off and the TIMER light will flash quickly for about one minute. When the TIMER light stops flashing, you may again turn on the TV. The changes you made the last time the TV was on before you used the SYSTEM RESET button may be lost, however, the changes that were previously saved are not lost.
OK.
Apr 23, 2011 | Mitsubishi WD-52725 52". Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Timer light continues flashing; won't turn on/off
Could be an open internal fuse or power supply failure
Jun 25, 2017 | Mitsubishi WD-65731 65" HDTV
Have a 52 inch Mitsubishi TV. Just replaced the
Call Mitsubishi the chassis needs to be rebuilt on this set they have been paying for the parts but you will have to pay the labor.
Oct 13, 2009 | Mitsubishi WD-52725 52". Rear Projection...
I have a mitsubishi tv model # WD 52525 DLP and the timer light just keeps flashing and the TV will not go on
i have a mitsubishi ws-55859 rear projection tv. the green timer light just keeps flashing and the tv will not turn on.
Aug 09, 2009 | Televison & Video
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Flashing green timer light, no image on TV
4 capacitors on the DM board causes this they are 1000uf @35 volts replace these capacitors and that should take care of your problem
Mar 19, 2008 | Mitsubishi WD-52628 52" Projection HDTV
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Constant green blinking timer light
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Suspect the DM PCB part # 934C116002
Jan 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Open Questions:
I have horizontal white lines across the display of my LCD Tv, I've included more info in the details section below I have an Insignia model# NS-46L780A12 LCD TV MFG date July, 2011 , recently the display has been acting very strangely because the issue comes and goes consistently dependent to whether or not there's caption writing on the screen - examples being programming information , channel , time etc.....these info blocks are each in their own particular areas on the display , where this gets odd is when your watching live TV ,these info blocks are always filled in with whichever program that's on, the best description of this issue is from these individual blocks of written captions on the screen example - from the top , there will be a continuous vertical row of horizontal lines starting directly underneath said caption all the way to the bottom , this will happen consistently wherever there happens to be writing on the screens display, so you get multiple rows of these horizontal lines from top to bottom of the display and they'll stay there for the entire time you watch your show , some shows have more ,some less ,depending on the writing for that show , this is all on cable TV / live TV I guess you can call it , and when I use my Fire TV stick with certain apps , I'll get no vertical rows horizontal white lines on the display with the exception that I push the mute button or change the level of the volume and the lines start to want to show up and do partially just for a little while ,but almost as soon as the info on the screen disappears as far as mute/ no mute or the volume level , the vertical rows of horizontal lines go away , I should also say that in either case Fire TV stick or cable , these vertical rows of horizontal lines take a little time to develope all the way from where the caption lettering begin and same process for when they go away , it's not instant in either case , it can take up a couple of minutes for either process to happen , one other oddity I guess you could say , in watching a cable tv program where you may get let's say 5 vertical rows of horizontal lines top to bottom at the beginning of the process , if you happen to try to watch that show ,those individual vertical rows of horizontal lines of varying widths will eventually connect with each other horizontally across the display
Feb 18, 2018 | Insignia Televison & Video
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
