Question about Frigidaire Refrigerators
FRIGIDAIRE NOT KEEPING FOOD COLD OR COOL
I am curious on the control knob if you turn it to 6 if that is warmer or colder. My knob goes from 1 to 6. I have turned the knob to 4 1/2 and it seems like it isn't getting any colder.
  • Frigidaire Master
  • 5,568 Answers
Higher settings always equal 'colder.' I've never seen a refrigerator/freezer that was in good condition and didn't perform well with the control set to only half of the scale available.
I don't know how old your unit is, or if it has ever been moved, but you may have lost coolant over time or the fan that forces air through the condenser coils under the cabinet may not be running.
You should feel some warm air coming through the front grill while the compressor is running. If you don't, then the coils are unable to dispose of the heat collected from inside the cabinet. These coils do gather a ton of dust over time that reduces their efficiency so you might want to check behind that grill to see how much has accumulated there and carefully remove as much as you can without disturbing the coils too much since they are kind of fragile.
Removing the grill for access is always kind of a challenge but most are held in place by spring clips.
Posted on Sep 25, 2008
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
My refigerator is not keeping things cool. It was working ok until, the other day, I turned down the termostat by 1 from 5 to 4, and there was an audible click. Sounded like a fuse blew or something, the...
Sounds like you just happened to be near the defrost cycle timer as it was ready
to start the cycle and the movement was just enough to start it. You should actually
be turning the cold to a higher number (from 5 to 6 instead) and make sure that
if you have an adjustment knob in the freezer that it is set to the middle and not
to "colder" This knob controls the vent which allows cold air into the fresh food
compartment below. If it is set all the way to "colder" it will almost completely
cut off cold air flow to the lower compartment. Also if you have a thermometer
use it to set the temperature between 36 degrees and 39 degrees in the fresh
food compartment, it should stay in the fridge for 24 hours for an accurate reading.
hope this helps.
Apr 10, 2011 | Frigidaire Refrigerators
My food is freezing in the refrigerator section. It is a GE adora
yes try lowing your number on your t-stat knob. and also the other knob should control the amount of cold air coming from the freezer to the ref. u want to make freezer colder that makes ref. section warmer. and that help. try this ok. later gator.
Feb 17, 2011 | GE Adora (DSF25KGTBG) Side by Side...
I need to make the refrigerator warmer. It has an Amana Temp Assure numbered 1 through 6 with a snow flake near the 6. Is 1 colder or is 6 colder?
Turn it to a lower number to make it warmer...
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 18, 2010 | Amana Easy Reach AFD2535DE Bottom Freezer...
Why is my refrigerator not working properly? well , since I got it I have problems because it never seems to get cold or work properly. I think it might be cause it is digital.
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A "d" in the freezer temperature window and "F" in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. "d" and "F" will be displayed until the defrost cycle is complete. (approx. 8 minutes)
Nov 26, 2010 | Frigidaire Microwave Ovens
I have a HSBO3 compact refrigerator and all my food is freezing. Which way is colder on the settings?
Hi, normally the lower the number, the colder the temp. But, if its not numbered, I would suggest to listen to it when it is on first. Then slowly turn the stat knob all the way left and see if the unit comes to a halt. If it continues to run, turn it slowly to the right. Which ever direction shuts it off will be the warmer direction to turn the temp up or down.Let me know how it goes as you may have a faulty stat control also. Keep me posted and good luck,
Shastalaker7
Jan 11, 2010 | Haier HSB03 Compact Refrigerator
Freezer section is working but refridge not very cold.
check the vent that lets air from the freezer goes to the refrigerator. A control knob operates the amount of opening through the vent with a flap. makes the flap is not stuck, and responds to the knob, this is all mechanically link.
Jun 30, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Refrigerator does not get cold
In your freezer section, there should be a "control" for the freezer temp. I say "control" because the knob is attached to a flap that only controls airflow the the lower section. If the knob is turned to coldest it will block almost all of the air from getting into your fresh food section.
Jun 14, 2009 | Frigidaire Freezers
Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is colder...it makes sense that the darker the blue the colder the temperature but why keep us guessing?
Mar 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Refrigerators Logo
281 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
