Question about Dell Inspiron 8100 Notebook
Can I use a 1978u replicator with my 8100 if I remove the locking arm?
The 8100 physically attaches to the replicator properly [I did remove the arm] but I am concerned about the electronics and have not powered on the notebook with the notebook attached. My notebook uses the PA-6 power supply as does the 1978u.
  • 71 Answers
Try to turn it on ... it should have no problem with the "electronics"
if you got message that the docking is not compatible, then you will have to flash your notebook bios to the latest 8100 BIOS.
If same case still happen after updating your BIOS, use C840 bios (which AFAIK will not harm your notebook). It will then read the docking/port replicator correctly.
Both BIOS can be found here
Give it a shot ...
Posted on Oct 28, 2008
  • voidzzz Oct 28, 2008
    note : to find bios download, just type in your laptop service tag or product type and model.
Blackberry phone sim unlock
To remove the sim lock in your Blackberry Pearl 8100 use unlock code.Which country and network it is locked now?Get the unlock code from the site Unbblock.com and unlock it from network lock step by step.
Jul 17, 2013 | RIM BlackBerry Pearl 8100
Tip
How to replace a chain with master link on a Schwinn Airdyne
Airdyne Chain Replacement with Master link
This video will demonstrate how to replace the chain with master link on a Schwinn Airdyne.
  • First remove the cotter pin and clevis pin from the user's right handlebar. Then lower the connecting arm and handlebar.
Caution: be sure to hold the handlebar as it will come loose after removal of the above parts.
  • Remove the connecting arm and pedal and crank arm by removing the wedge pin. To simplify this process loosen the nut and tap on it with a small hammer until the pin is loosened.
  • Remove the nut, wedge pin, crank arm and connecting arm.
  • Next remove the chain guard; there are three screws attaching it as shown in the video.
  • Remove the chain by locating the master link. Remove the lock pin and the cover, and then disconnect the chain.
  • Place the new chain on the sprockets as shown in the video.
  • Install the master link, cover and lock.
  • Re-install the chain guard and attaching screws.
  • Re-assemble the connecting arm to the handlebar and eccentric.
  • Be sure the brass bushing is installed in the front inner side of the connecting arm before installing the clevis pin and cotter pin.
  • Install the crank arm with pedal.
Be sure when completing this step that the crank arm is installed in the opposite position as the users left side crank arm.
  • Install the nut onto the wedge pin and tighten.
  • This completes the procedure.
Replacing Schwinn Airdyne Chain with Master Link
on May 23, 2016 | Schwinn Airdyne Exercise Bike
Can a Dell Dimension 3000 connect to 5.1 surround sound
If your Laptop has a "Latitude C/Port Advanced Port Replicator" Then this Port Replicator connects Dell Latitude notebooks to peripheral devices such as a monitor, printer, keyboard and mouse. To accomplish this, connect your peripheral devices to the Dell port replicator itself, and leave them connected to it. Then connect your notebook to the port replicator to access the devices without having to attach them individually each time you want to use them. You can also set up speakers on the Dell Latitude C/Port port replicator to provide improved quality audio.
Follow following steps:
1) Place your Dell Latitude notebook in your C/Port Advanced Port Replicator and turn on the notebook using the power button.
  • 2) Place the speakers you want to connect to the port replicator on either side of the port replicator according to the Left and Right (L and R) labels on the speakers.
  • 3) Plug the audio line connector from the speakers into the audio line out plug on the port replicator. The audio line out plus is on the right-hand side of the port replicator base next to the infrared port, directly opposite the notebook ejection lever.
  • 4) Plug the power cable from the speakers into a power outlet if needed. Battery-powered speakers will not require this. Turn on the speakers following the manufacturer's instructions.
  • 5) Open your preferred music or audio software (such as Windows Media Player or iTunes) on your Dell Latitude notebook and play an audio file to hear the newly-attached speakers.
  • Dec 01, 2011 | Dell Dimension 3000 PC Desktop
    Computer suddenly shutdown totaly..i already check clean its heat sink, changed thermal cooling paste and reformat but still problem exist.my laptop A300 toshiba satelite
    I suggest try to isolate the problem first what could be the cause, If its software or hardware. I suggest try doing these steps and see if it works.
    NO POWER
    1. Verify the status indicator.
    The power status indicator anespera.gif is illuminated whenever the computer is on.
    2.Check all power connections.
    3. Inspect the AC Adapter
    See if there are physical damage, and ensure the power cable is firmly attached to the power brick and the system.
    4. Remove the machine from any docking station or port replicator.
    5. Remove all devices and then test for system power with minimal devices attached.
    You might need these things; Philips Screw Driver, Tweezer and any Flat Bladed tool.
    5.1. Disconnect the AC adapter.
    5.2. Remove the battery pack.
    5.3. Remove any externally or internally installed options and other devices.
    5.3a. Remove the memory module (DIMM).
    5.3b. Remove the Mini PCI and Communications Daughter Cards if applicable.
    5.3c. Remove the Ultrabay devices, usually CD-ROM, CD-RW, or DVD drives, that are customer replaceable.
    5.3d. Remove the hard drive.
    4. Wait for 30 seconds before reconnecting the devices and power sources.
    5. Reinstall only the memory DIMM and the known good battery pack or AC adapter to test the system with minimal devices attached first.
    6. Reinstall each device one at a time that was removed in the steps above.
    NOTE:
    If happens you're not comfortable doing those steps I suggest try to get help from someone who's capable doing those steps or go to any local computer center.
    Hope it helps.
    AnEspera
    May 08, 2011 | Computers & Internet
    I need to adjust the wiper arm on a 1997 suburban, it hits the side of the window.
    Wiper Arm & Blade (Front) Removal & Installation Wiper Blade To Remove:
    1. Turn ignition switch to ACCY position.
    2. Turn wiper switch to PULSE position and turn ignition OFF when wipers are stopped in the innerwipe position.
    3. Push the wiper blade clip button IN and remove wiper blade from wiper arm.
    To Install:
    1. Insert wiper arm hook through opening in wiper blade.
    2. Place wiper blade pivot in the inside radius of wiper arm hook.
    3. Pull on wiper blade pivot into hook until it locks into place.
    4. Check wipers for proper operation.
    Wiper Arm To Remove:
    NOTE: Mark position of wiper blade on windshield to ensure proper position upon reassembly.
    1. Remove washer hose.
    2. Lift wiper arm from windshield and use a screwdriver to disengage retaining latch.
    3. Remove wiper arm from shaft.
    To Install:
    1. Place wiper arm on shaft so that wiper arm aligns with marks placed on windshield.
    2. Press arm assembly on shaft and push retaining latch IN.
    3. Connect washer hose.
    4. Remove windshield markings and check wipers for proper operation.
    Oct 26, 2010 | Chevrolet Suburban 1500 Cars & Trucks
    How do you remove and replace windshield wiper 2007 Honda Civic
    the Windshield wiper blades have little clips that lock them in place. Most replacements have direction on how to release these, as they are common to all models, and remove and install the new ones. If you are talking about the Windshield wiper motor itself i recommend you get a Haynes repair manual on your vehicle so you have the step by step instruction on how to remove and replace this part.
    Nov 22, 2009 | 2007 Honda Accord Sedan
    The C V H T and B keys on my other Dell laptop, an Inspiron 1545 have stopped working
    Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Reseat the Keyboard Connector to the Motherboard Caution: Before performing any of the procedures in this section, read and follow the safety instructions in Dell Knowledge Base Article: "Precautionary Measures for Personal Safety" Article ID: 339031. Reseat the keyboard connector to the motherboard. Be sure to handle only the connector and not the cable. For information about how to open the chassis and remove, reseat, and replace components, please refer to your Online User's Guide and browse to the Replacing and Removing Parts section. Remove All Power Sources and Reset the Computer Remove the battery and disconnect the AC power adapter from the computer. Note: For information about how to open the chassis and remove, reseat, and replace components, refer to the Online User's Guide. Click Systems, then the make and model of the computer. Download the Owner's Manual or User's Guide and refer to the Adding and Replacing Parts section. Press and hold the power button for 10 seconds. Reattach the AC power adapter to the computer. Power the computer on. Replace the Internal Keyboard
    Nov 07, 2009 | Dell 0Y3740 Keyboard
    How do i get the tab out to tighten the wiper arm ?
    I assume that you are speaking of the pivot arm. If I have this wrong please let me know so that I can provide the proper diagram. You have to lift the wiper arm off the windshield and pry the small tab in the diagram aside and let the tension on the wiper arm hold it aside. Here is a link to the pivot arm diagram ~ http://s219.photobucket.com/albums/cc270/anubiscycle/?action=view&current=wiperpivot.jpg
    Jun 06, 2009 | 1999 Ford Crown Victoria
    Metal fatigue has messed up the driver side door lock latch
    remove door panel,remove plastic nylon, You will see inside part of lock drum, with a center arm screwed in, remove arm carefully and look for a "U" Grooved,lock around bottom attaching drum to panel clipped from the top, pride up with flat screw driver and lock drum will fall out, get new drum from junk yard or better with dealer
    Jan 25, 2009 | 1994 Chrysler Town & Country
    Dell 8100 ethernet will not connect off the port replicator
    Let me give it a try ...
    There are a few possibilities but i'll cover 2 of them :
    1. There is a program that comes with your DELL that will save battery life by turning off your Network Card (LAN) I forgot what is the program name. But usually when you plug the power cable out, there will be notification at bottom right corner of your screen that told you so.
    2. I don't know if your port replicator connected to power adapter (is port replicator = docking ?). The fact that your LAN connected when it's on port replicator make my first conclusion more acceptable. Since port replicator got it's own power adapter, it will just turn the LAN on.
    Now if you want to check if thats the cause, just plug your notebook to it's power adapter/charger and plug your LAN Cable in. If it works than the problem is the nasty program from DELL.
    If you want to disable the program just go to Startup Tab at msconfig and disable (clear the check mark) for that nasty program
    Hope it helps
    Oct 28, 2008 | Dell Inspiron 8100 Notebook
    Dell Inspiron 8100 Notebook Logo
    80 people viewed this question
    Alun Cox
