Question about Visioneer OneTouch 5800 Flatbed Scanner
Error message: enable to connect with scanner
I installed the driver, but the computer gives me the message: Unable to connect with scanner. What else can I do? Thanks
Dora
  • 2 more comments
  • SC_Gal74 Oct 25, 2008
    I have the same problem. I installed the driver off the visioneer website and sometimes my computer will say unable to connect with scanner and sometimes it connects but does not scan
  • messanicgent Feb 01, 2009
    I have the same problem I alsol own a visionneer one touch 5800.I downloaded the software driver from the manufactor 's page and it was successful and all the wires our rightly connected and it still says not connected to scanner.
  • rollergirl20 Feb 03, 2009
    error message unable to connect with scanner
  • dirtybrokenw Feb 17, 2009
    it says scanner is not connected. I don't understand, because it is connected. help.
Part of the problem may be that Visioneer did not develop any drivers for Vista considering that the 5800 had reached E-O-L.
Posted on May 15, 2009
My Usb driver do not recognize error 0000002b I have already tried many types of solution but always says usb did not recognize or an unknown port connected tu yr Computer please tell me easy way of...
Deploying endpoint software to Windows 2000 clients returns the error 0000002b to the console Symptom
You are unable to deploy client-applications to Windows 2000 client-computers. The following error message is displayed in console:
0000002b The installation credentials you entered in the 'Protect computers wizard' are either incorrect or do not give administrator access to the computer over the network
Known to apply to the following Sophos product(s) and version(s)
Enterprise Console 4.7.0
Enterprise Console 4.7.1
Sophos Enterprise Manager 4.7.0
Sophos Control Center 4.1
Sophos Control Center 4.0.1
Enterprise Console 4.5.0
Enterprise Console 4.5.1
when one or other of these consoles is installed on any of the following operating systems:
  • Windows Vista
  • Windows 7
  • Windows 2008
  • Windows 2008 R2
What to doPlease refer to the Microsoft Knowledgebase article http://support.microsoft.com/kb/239869.
NTLMv2 must be enabled on Windows 2000 clients. This can be done in one of the following ways:
  • Enabling NTLMv2 in the registry:
    open the following registry key,
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa
    and ensure that the value of 'LMCompatibilityLevel' is set to a value of '1' or above.
  • Enabling NTLMv2 via Local or Group Policy:
    This is described in the Microsoft Knowledgebase article: http://msdn.microsoft.com/en-us/library/ms814176.aspx.
Sep 11, 2011 | Computers & Internet
When I try to scan I get a message - connect to Twain source but I don't know what they are talking about?
The TWAIN device is the scanner itself. The program seems to be saying it can't see the scanner.
Is this scanner new to your computer?
Have you installed the driver for it?
Which program is giving you the error message?
Apr 12, 2010 | Canon CanoScan 5000F Flatbed Scanner
Lenovo 3000 N 100 integrated cam not coming in device manager
fistly you check ur bios setting & registry setting.
is that possible cam is disable by bios or registry, so kindly check it & reinstall ur cam driver.
Nov 17, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Scanner twain driver will not install
Dear sir,I am sory for your problem.Please format your oparating system i mean you install new windows.some times optical driver did not read properly data cab file,So hardware driver is not support properly.Windows xp SP3 is not complite version some messing.
Thanks You are success
Tareq
Aug 27, 2009 | Epson Perfection V300 Film Flatbed Scanner
Can't use scanner
  • Hi there,
    • Unplug the Scanner cable from the computer.
    • Unistall the Scanner drivers from Device manager and also unistall the all the Scanner appications
    • restart the computer
    • try to download drivers from the website
    • after installing drivers and software it will ask you to connect the Scanner.
    • then you can connect the Scanner and and try to Scan.
    Hope this help. Please Rate My Response! Thanks!
    GF
Apr 27, 2009 | Office Equipment & Supplies
Scanner will not connect to computer
'Twain' only means 'Technology without an important name', as this is refering to your printer/scanner, i would suggest that you disconnect the printer and remove any driver from Add/Remove programmes. Re-install printer software/driver and re connect printer when prompted and if possible in a different usb port, if that's how it's connected. If the problem persists and the pc is unable to communicate with the printer the fault will lie with the hardware. Hope it's only a driver glitch.
Nov 27, 2006 | HP PSC 1510 All-In-One InkJet Printer
How to clear error code 0000003d
Is it a USB scanner? Look in System information\device manager to see if your scanner is at all recognized by the computer. If not, install the drivers that came with the scanner. If the drivers are already installed, use it with another USB cable to see if your own is the culprit. If the problem persists, replace the USB card.
Jan 30, 2006 | Panasonic KV SS905C Path-Through Scanner
Visioneer OneTouch 5800 Flatbed Scanner Logo
330 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
TomHighRidge
Mark Gough
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
