Question about Bosch Axxis WFL 2060 Front Load Washer
Washer fills and will drain but not wash.
I have a WFL 2060 Axxis Washer.
It just stopped washing. It fills okay but then nothing happens.
I'm able to select drain and it will drain.
No wash or spin.
After it fills, about every 40 seconds or so there is a very faint buzz then click that seems to be coming from the program select dial location.
  • Anonymous Sep 28, 2008
    my washer drum just stopped spinning a few days ago. the drain is clean. i took the motor out and there is a lot of carbon on the inside of the motor. one of the spring loaded brushes stick out twice as much as the other and is very loose. how would i purchase just the brush fixtures? or even just replace the motor. does anyone sell these parts?
  • info670 Sep 28, 2008
    how do i get new brushs
I found brushes at this site.
http://www.appliancepartspros.com/modelsearch_model.aspx?part_id=2822714&&model_id=232480
You might want to confirm your model number etc.
I'm told I can get a whole new motor for about $207.00.
I wonder if it would be any quieter than this one.
Got that "jet taking off" sound during spin in my present motor.
Posted on Oct 02, 2008
    President:
  • 1,462 Answers
I remember click is the motor relay engaging.
reason for no rotation may be the motor brushes.
take back panel off, disconnect motor elec plug, undo fixing bolts and withdraw motor and you can then check brushes. also check condition of commutator - series of copper segments brushes run on
Posted on Sep 25, 2008
What are WFL 2060 fault codes
Bosch WFF washing machine error codes:
E1
- The door is not closed and cannot therefore lock.
E2 - Washer will not fill with water.
E3 - Washing machine not heating.
E4 - Washing machine won't empty.
E5 - Fault in the motor drive circuit.
E6 - Unexpected heating.
E7 - NTC thermistor open or short circuit.
Please note that the codes for the WFF range of Bosch machines differs from other ranges.
Sep 04, 2014 | Bosch Axxis WFL 2060 Front Load Washer
Bosch wfl 2060 washing machine makes a funny rattling sound when it should be spinning or draining. why
Check the filter behind the flap (Bottom right of kickplate) souns like you have a coin or other foreign object in the pump.
Feb 18, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 won't spin or drain. Still full of water
Have you checked for any blockages, in the drain pipe? If that doesn't help you might have a bad pump, here's the part:
http://www.appliancepartspros.com/modelsearch_model.aspx?model_id=232480&pkw_=pump
Mar 05, 2011 | Bosch Axxis WFL 2060 Front Load Washer
Bosch axxis washer fills door locks then nothing no agitate or spin it dose drain when the control is set to spin
The timer/controller is faulty.
Replacement is the only fix.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 25, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Is used Bosch Axxis WFL 2060 with door replaced a safe bet
not a bad price (poss a little bit high) but i would want to see it running on a warm wash first.
Mar 18, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Washing instructions
My book says for the Axxis WFL 2050/WFL 2060 : from the left while looking at it from the front: detergent for wash, stain remover, middle: fabric softener, fabric conditioner, right one: detergent for soaking agent. (Do not use chlorice bleach in this wasking machine).
Oct 11, 2008 | Bosch Axxis WFL 2060 Front Load Washer
My washer stops!
You should check and clean the outgoing water screen to make sure your washer can drain properly. Sounds like you have a restriction in your system.. could be a filter screen or the pump itself. Try the screen first and then cycle a load of wash without any clothes in it to see if it empties the drum completely.
Hope that helps...
Aug 13, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer--Tub won't move
what a bogus website you are. you offer no free support and you should say so
Jul 12, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
226 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
