I am having problems with my wireless connection. When I try to connect to a wireless connection such as an airport, coffee shop, etc. I get a connection to the network but am unable to connect to the internet. I have wireless at my home and have no problem connecting to it but since I set-up my wireless at home I have had problems connecting to other wireless networks outside my home. Any suggestions on what is going on? Thanks, Dena
  • 38 Answers
Tht is becasue u odnt have heir WEP or WAP password if it has a password then ur adapter will seem to connect to it but wont give u internet access to the router which means no intenet
Posted on Sep 26, 2008
Why will my pavilion dv9000 only connect to public access networks, and not wirelessly to any home networks?
sounds like
a. wpa or wps needs to be reconfigured at router
b. firmware for router needs attention
c. router is truly unhappy about wireless settings
check router website for management access and adjustment procedures
not an hp issue
May 30, 2012 | HP Computers & Internet
Not connecting wirelessly to mac
Thank you for contacting Fixya Support, I am glad to assist.
Depending on what type of Internet service you are using, your Intel iMac comes standard with an Airport Extreme wireless card built in. As a result, if you are unable to connect wirelessly to the Internet, you will need to try this:
- Click on the Apple menu icon, located in the upper left corner of your screen and select System Preferences from the drop down menu.
- Now locate Network from within System Preferences.
- In the side window, make sure you see Airport and check also to see that it is turned on. If it is, then check the left side window to see if the AirPort connection is active.
Keep in mind, your modem or connection router of course, has to be able to provide wireless connectivity, otherwise, if you do not, there will be no need to try connecting via your AirPort Extreme card.
If your network has been physically set as a wireless network, then just turning on the AirPort card in System Preferences>Network will start discovering all networks within its range, including your own network.
So whether you are using an Airport Extreme, Express or a 3rd party (non-Apple-branded) router, you should be able to connect wirelessly.
If you are still unable to connect with these basic steps, here are a few articles you will need to review from Apple Support informational database:
Requirements for wireless Internet access with AirPort
Airport & Bluetooth interference (for connectivity issues)
So here are some basic steps and resources you can try.
If you have more questions please feel free to post a comment.
I hope this information helps.
Regards,
-Mactechtrainer
Aug 29, 2010 | Apple iMac Z0CY Desktop
I need a 5.1 v dc power supply for an older airport base station
There are universal multi-voltage adapters available at electronic hobby shops, they are available with various adapter plugs. Make sure you connect the adapter plug that matches the power socket for the airport AND also make SURE you connect it with the right polarity and set it for 5 volt setting. If you reverse the polarity you could destroy the airport.
Sep 12, 2009 | Apple AirPort Extreme Base Station...
Wont connect to each other
connect the airport extreme to the voyager using a network cable... factory reset the extreme and then connect to it using the airport utility... you should get a setup screen where you can switch the extreme to "bridge mode" .. everything else should happen automatically.. you will then have 2 wireless networks?
May 03, 2009 | Apple AirPort Extreme Base Station...
Airport Extreme Bases Station not detectable with utility
This depends... Reaching them wirelessly may be unreliable for a number of reasons, so, I'll proceed on the assumption that you are attempting to test in the simplest lowest-variable situation:
First, make sure that you have the latest Airport Utility for your Mac.
Connect your Mac to the Airport via a single Category 5 (or 5e or 6) cable. Factory-reset the Airpot and then wake up the Mac. If the utility still can't discover your airport, it's probably time for a trip to your local Genius bar as you most likely have a hardware problem.
Lather, rinse, repeat for each of the two airports.
Apr 28, 2009 | Apple AirPort Extreme Base Station...
Router/Modem IP
Try 192.168.1.1 or 172.16.1.1
Mar 14, 2009 | Apple AirPort Extreme Base Station
Airport extreme / Windows XP with VPN problem
have you reset the airport extreme? theres a tiny hole you can push in w a paperclip. Also, do you have the latest firmware?
Mar 10, 2009 | Apple AirPort Extreme Router
I can't connect apple airport expresses with a siemens 587 route
Login to your airport express using Apple's airport utilities (either in it's current configuration or after resetting it).
Using the airport utility do not choose manual setup, just select continue.
Adjust (as required) the airport express station name and password and select continue.
Select "I have a wireless network and I want to add AirPort Express or replace an existing device on my network and select continue.
Select I want Airport Express to wireless join my current network and select continue.
Choose if you want to extent the rance of your network or just join the network and select continue.
Choose the network you wish to join... etc etc etc....
You should be fine.
Jan 31, 2009 | Apple AirPort Extreme Base Station
Wireless not working
Check for the wireless security settings in your modem.. and check if your airport is connected properly, if it is connected properly, then you would get a valid ipaddress, try resetting the modem and reconfigure your wired and wireless settings, if possible , try to upgrade the latest firmware for your modem and then reconfig it..
Jan 21, 2008 | 2wire (1000-000057-000) Modem
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
